magrinds
Second bridge - no internet access
Sun May 21, 2023 7:32 am
I am setting up a new hap ax3. My second bridge (Bridge22) can't access the internet (it has TVC-Guest wifi networks connected to it). The TVC-Guest clients get an IP address via DHCP - so that's working fine - but no access to the internet. I have setup this in a similar fashion before - but not sure why it's not working this time. The other networks aren't fully setup yet (until I figure this issue out). Thanks for any help!!!
Config:
# may/20/2023 21:21:08 by RouterOS 7.9
# software id = 5HP3-MTXY
# model = C53UiG+5HPaxD2HPaxD
# serial number = XXXXXXXXXXXX
add name="Guest-Bridge(22)"
add admin-mac=48:A9:8A:48:64:B6 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=\
yes ft-mobility-domain=0x1234 ft-over-ds=yes name="TVC-Guest(22)"
yes ft-mobility-domain=0x1234 ft-over-ds=yes name=MikroTik
yes ft-mobility-domain=0x1234 ft-over-ds=yes name=TVC-IoT
/interface wifiwave2 configuration
add datapath.bridge="Guest-Bridge(22)" disabled=no interworking.internet=no \
mode=ap name="TVC-Guest(22)" security="TVC-Guest(22)" ssid=TVC-Guest
add disabled=no mode=ap name=MikroTik security=MikroTik ssid=MikroTik
add country="United States" disabled=no mode=ap name=TVC-IoT security=TVC-IoT \
security.ft=yes .ft-mobility-domain=0x1234 .ft-over-ds=yes ssid=TVC-IoT
add country="United States" disabled=no name="TVC-IoT(2.4GHz)-Only" security=\
TVC-IoT security.ft=yes .ft-mobility-domain=0x1234 .ft-over-ds=yes ssid=\
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration=MikroTik configuration.mode=ap \
disabled=no name="MikroTikWiFi(2.4GHz)" security.authentication-types=\
wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration=MikroTik configuration.mode=ap \
disabled=no name="MikrotikWiFi(5GHz)" security.authentication-types=\
wpa2-psk,wpa3-psk
add configuration="TVC-Guest(22)" configuration.mode=ap disabled=no \
mac-address=4A:A9:8A:48:64:BB master-interface="MikroTikWiFi(2.4GHz)" \
name="TVC-Guest(2.4GHz)"
mac-address=4A:A9:8A:48:64:BA master-interface="MikrotikWiFi(5GHz)" name=\
"TVC-Guest(5Ghz)"
add configuration="TVC-IoT(2.4GHz)-Only" configuration.mode=ap disabled=no \
mac-address=4A:A9:8A:48:64:BE master-interface="MikroTikWiFi(2.4GHz)" \
name="TVC-IoT(2.4GHZ)-Only"
add configuration=TVC-IoT configuration.mode=ap disabled=no mac-address=\
4A:A9:8A:48:64:BD master-interface="MikroTikWiFi(2.4GHz)" name=\
"TVC-IoT(2.4GHz)"
/ip dhcp-server option sets
add name=DHCP-Guest
add name=Guest-DHCP ranges=192.168.22.2-192.168.22.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=Guest-DHCP interface="Guest-Bridge(22)" name=Guest-DHCP
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface="MikrotikWiFi(5GHz)"
add bridge=bridge comment=defconf interface="MikroTikWiFi(2.4GHz)"
add bridge="Guest-Bridge(22)" interface="TVC-Guest(2.4GHz)"
add bridge="Guest-Bridge(22)" interface="TVC-Guest(5Ghz)"
add address=192.168.88.1/24 comment=Mikrotik interface=bridge network=\
192.168.88.0
add address=192.168.22.1/24 comment=TVC-Guest interface="Guest-Bridge(22)" \
network=192.168.22.0
/ip dhcp-client
add address=192.168.22.0/24 comment=DCHP-Guest dns-server=192.168.88.1 \
gateway=192.168.22.1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Los_Angeles
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
anav
Re: Second bridge - no internet access
Tue May 23, 2023 4:56 pm
(1) MISSING!~
add interface="Guest-Bridge(22)" list=LAN
Note Interface lists are very handy for use in firewall rules, they are not just a pretty face. They have purpose.
Hence none of your bridge22 folks had access to DNS resolving.
Users browsing this forum: djvabe, Mr47, NetworqAndy and 62 guests
