seventh
hAP ax2 5GHz running but not running
Sun May 21, 2023 12:36 pm
Hi!
Can't setup Wi-Fi 5GHz on my hAP ax2. The interface shows that it is running in UI, but not running in console. And I don't see this Wi-Fi it in my phone.
v7.9
How can I enable it?
UPD: Hm, I disabled 2,4 interface and 5 GHz is up immediately. Then I enabled 2,4 and now both is Running.
Looks like some bug
UPD2: Now if I change any settings of interface 5, it don't start again. And I need to do this manipulation again.
seventh
Re: hAP ax2 5GHz running but not running  [SOLVED]
Sun May 21, 2023 5:23 pm
/interface wifiwave2 set seventh2 disable-running-check=yes
/interface wifiwave2 set wifi1 disable-running-check=yes
is helped. Didn't see this options in UI
Users browsing this forum: No registered users and 31 guests
