CamJam
Home AP Dual Client comms between different SSID on same network
Mon May 22, 2023 6:14 am
Hey,
I have a hap ac lite running Home AP Dual default config with no additional changes. There are 2 separate SSIDs for the 2Ghz and 5Ghz.
Currently on the default setup I cannot ping/talk to devices which are connected on the other SSID. Is there a setting that allows client to client comms between different wireless SSID/networks. Currently both SSIDs are on the same subnet.
I did see there is a post about something similar if running CAPsMAN - viewtopic.php?t=189107
Is there something similar to this that can be added to the default Home AP Dual config?
holvoetn
Re: Home AP Dual Client comms between different SSID on same network
Tue May 23, 2023 10:56 pm
Post config between code quotes [ ] so we can have a look.
CamJam
Thu May 25, 2023 12:03 am
Hopefully this makes sense?
# may/25/2023 08:54:26 by RouterOS 6.49.7
# software id = AMII-MWMC
# model = RouterBOARD 952Ui-5ac2nD
# serial number = 6CBA06DDC49E
add admin-mac=6C:3B:6B:3E:9F:CB auto-mac=no comment=defconf fast-forward=no \
    name=bridge
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
    ether2-master
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
/interface pppoe-client
add add-default-route=yes default-route-distance=0 disabled=no interface=\
    ether1 keepalive-timeout=60 name=pppoe-out1 password= \
    use-peer-dns=yes user=
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
    20/40mhz-Ce country="new zealand" disabled=no distance=indoors frequency=\
    auto frequency-mode=manual-txpower mode=ap-bridge multicast-helper=full \
    name=2Ghz ssid=2GHz station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac \
    channel-width=20/40mhz-Ce country="new zealand" disabled=no distance=\
    indoors frequency=auto frequency-mode=manual-txpower mode=ap-bridge \
    multicast-helper=full name=5Ghz ssid=5Ghz station-roaming=enabled \
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key= \
    wpa2-pre-shared-key=
add name=dhcp ranges=192.168.88.10-192.168.88.149
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
    bridge name=defconf
/interface bridge filter
add action=drop chain=forward in-interface=!2Ghz src-mac-address=\
    !88:19:08:35:F2:D7/FF:FF:FF:FF:FF:FF
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=2Ghz
add bridge=bridge comment=defconf interface=5Ghz
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=2Ghz list=discover
add interface=5Ghz list=discover
add interface=bridge list=discover
add interface=pppoe-out1 list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
/interface wireless access-list
add signal-range=-80..80 vlan-mode=no-tag
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
    192.168.88.0
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=pppoe-out1
    out-interface=pppoe-out1
/ip ssh
set forwarding-enabled=remote
/system clock
set time-zone-name=Pacific/Auckland
/system routerboard settings
set auto-upgrade=yes boot-device=nand-only
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
holvoetn
Thu May 25, 2023 6:46 am
Does it happen from both sides ?
2GHz to 5Ghz and 5Ghz to 2GHz ?
I am wondering why this is in default config.
MAC address seems to point to Apple.
Remove that setting if you don't need it.
erlinden
Thu May 25, 2023 9:58 am
Though choosing as accesspoint, you are running the Lite as router. That makes no sense, unless choosen deliberately.
Being in the default config...please don't choose wpa-psk...it is nearly as bad as having no security at all...
CamJam
Fri May 26, 2023 7:44 am
@Holvoetne - Yes, happens both ways. That was probably me playing with limiting a device on the wifi at some point.
@erlinden - The device is setup as a home internet router and access point. I would imagine that's what 'Home AP Dual' is for? Fair enough about WPS-PSK - i didn't realise it was enabled by default.
holvoetn
Re: Home AP Dual Client comms between different SSID on same network  [SOLVED]
Fri May 26, 2023 7:48 am
Did you already remove that line ?
As it is now it will block all forwarding traffic over bridge for all devices not having that MAC address for all incoming interfaces not being 2GHz.
(and it has some consequences too for return traffic)
CamJam
Mon May 29, 2023 1:50 am
Looks like I should have had the drop rule in the firewall settings no the bridge.
Thanks for your help.
rextended
Mon May 29, 2023 11:49 am
Already reported ...
The other not (just I do)
I wonder how the moderators approve it, and why it's not deleted immediately...
When I did it, 5 minutes didn't pass from a report, and I kept an eye on new members whether or not they wrote valid things in the first post...
holvoetn
Mon May 29, 2023 11:52 am
When I used to be a moderator on another board, that was my approach as well.
Watched new users, watched the IP address they used (all too often it always came from the same sources and phpBB has the possibility to use blacklist, so I used that quite a bit), watched reports, ...
BartoszP
Mon May 29, 2023 12:15 pm
It's a matter of involvment of moderators.
bpwl
Mon May 29, 2023 12:26 pm
To separate SSID's on one AP, with WLAN interfaces and even ethernet interfaces bridged together, I use the same bridge port "horizon" value.
Same usage for the Powerbox connecting (bridging) the different AP's.
This also stops broadcasts from one to the other. The network forms a tree structure.
So all downstream links (WLAN, wifi, ether,...) have the same horizon, the uplink has no horizon or different horizon set.
All will communicate with the uplink, the uplink can reach all downlinks, no communication among the downlinks.
Many client devices are very curious and chat (broadcast, multicast) a lot. (Windows, Dropbox, Bonjour, mDNS, Skype, ....)
And those broadcasts are a heavy load on the wifi air time, as they are sent at basic rate.
Disabling "forwarding" in the wifi authorization is working within that SSID instance only.
rextended
Mon May 29, 2023 12:33 pm
Today I'll help you ;)
holvoetn
Mon May 29, 2023 12:34 pm
I am aware and as already indicated in some other posts, much respect for those taking up this task.
Since I've done it myself for several years, I know how much time and dedication can be involved.
rextended
Mon May 29, 2023 12:36 pm
That's why I apologized to @BartoszP for mistreating him (in the past)...
I've been do that too and it's quite tiring...
When you're on the other side, and you care, then you realize it...
Users browsing this forum: FurfangosFrigyes, sybadi and 92 guests
