Having my nose deep in Mikrotik's youtube channel and others I dicovered that I can make use of a fancy interface for monitoring uptime through a dynamic web page. This ultimately lives in a container.
The container is attached to a bridge called dockers and marked as a LAN interface with its own private IP range as 10.0.4.0/24. VPN clients are handed an IP address in the 10.0.5.0/24 range. When I ping any of the VPN clients from the ping tool in Winbox I am getting a ping reply without trouble and netwatch provides the same level of reliability.
To accommodate ICMP from dockers bridge to VPN IP address range I have added the following rules to no success:
Code: Select all
/interface/list/member/add list=LAN interface=docker
/interface/list/member/add list=LAN interface=ppp-alpha-002-internal
/ip/firewall/filter/ add chain=forward src-address=10.0.7.0/24 dst-address=10.0.5.0/24 protocol=ICMP action=accept
/ip/firewall/filter/ add chain=forward src-address=10.0.5.0/24 dst-address=10.0.7.0/24 protocol=ICMP action=accept
Any help is greatly appreciated
LJB
