pooliip
Cisco IPsec To Mikrotik
Mon May 22, 2023 3:45 pm
Hi Guys
I have config on cisco router and ip want to transfer it to mikrotik
any one can help me how to config this on mikroitk please:
Crypto isakmp enable
crypto siakmp policy 10
encr 3des
hash md5
authenticatio pre-share
crypto isakmp key ix979738686 address 10.10.10.1
crypto ipsec transform-set tets-ipsec esp-3des esp-sh-hmac
mode transport
crypto ipsec profile test-ipsec
pooliip
Re: Cisco IPsec To Mikrotik
Wed May 24, 2023 10:05 am
no one can help me ?
onnoossendrijver
Wed May 24, 2023 10:45 am
It is probably not that difficult... Here is a good example:
https://help.mikrotik.com/docs/display/ ... Ev1)tunnel
And please.. upgrade your security to IKEv2, AES(preferably AES-GCM), etcetera...
3DES / MD5 is a joke.
pooliip
Wed May 24, 2023 4:01 pm
I do this but not work
can you help me please:
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=3des hash-algorithm=md5 name=Profile-Test
/ip ipsec peer
add address=78.39.x.x/32 local-address=185.x.x.x name=Profile-Test \
passive=yes profile=Profile-Test
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add auth-algorithms=md5 enc-algorithms=3des name=Profile-Test
/ip ipsec identity
add peer=Profile-Test secret=secret
/ip ipsec policy
add dst-address=78.39.x.x/32 level=unique peer=Profile-Test proposal=\
Profile-Test src-address=185.x.x.x/32
onnoossendrijver
Wed May 24, 2023 4:24 pm
Are you sure about the source and destination addresses in the ipsec policy?
You should configure here the subnets being routed through the ipsec tunnel.
pooliip
Thu May 25, 2023 10:56 am
I have Gre tunnel and i want to work on gre:
Gre tunnel:
source address:185.x.x.x /32
Dst address :78.39.x.x/32
Tunnel IP: 192.168.1.2/30
/ip ipsec profile
/ip ipsec peer
/ip ipsec proposal
/ip ipsec identity
/ip ipsec policy
own3r1138
Long time Member
Long time Member
Thu May 25, 2023 2:18 pm
try this
/ip ipsec peer
add address=78.39.x.x/32 name=Profile-Test profile=Profile-Test send-initial-contact=yes
/ip ipsec policy
add dst-address=78.39.x.x/32 src-address=185.x.x.x/32 protocol=47 level=require peer=Profile-Test proposal=Profile-Test
pe1chl
Thu May 25, 2023 3:13 pm
... or do not bother about IPsec config on the MikroTik and just create the IPsec tunnel with an IPsec password. That will auto-generate the settings.
However, getting IPsec to work between different manufacturers is not so simple. You need experience and persistence.
"can nobody help me" usually brings you nothing because it is not possible to verify these things from the outside, especially when you make so many typing mistakes (rather than using cut/paste).
Also of course you (should) know that IPsec in transport mode cannot work over NAT. So when your MikroTik is not directly connected but behind some ISP-provided NAT router, it is never going to work!
Kentzo
Long time Member
Long time Member
Fri May 26, 2023 9:35 pm
Well one could try a network simulator…
But some low-effort posts do seem like a waste of someone's time. It's not clear what's even broken here. Is there no association or no routing?
Users browsing this forum: mquan1984 and 85 guests
