OldGuy
Problems Setting Up DHCP
Mon May 22, 2023 8:47 pm
Hello All,
I am trying to set up DHCP using the microtik routerboard RB3011.
Using Winbox and following the setup instructions (https://help.mikrotik.com/docs/display/ ... figuration)
using the DHCP setup button succeeds and appears to be running. However, my attached computer does not receive an IP address. I have set up DHCP using the plus icon in Winbox and that succeeds and the attached computer receives an IP address but will not route between subnets.
I have to be doing something wrong, yes? How should I be setting up these DHCP pools correctly.
Thanks in advance!
Edit* was incorrect link shared. corrected link
k6ccc
Re: Problems Setting Up DHCP
Mon May 22, 2023 10:46 pm
So we're not trying to guess, please post your configuration. To export and paste your configuration (and I'm assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) "/export hide-sensitive file=any-filename-you-wish". Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
OldGuy
Tue May 23, 2023 8:11 pm
I am currently using the default config. I have modified ports 9 and 10 with their own DHCP server in an attempt to guarantee a predicable IP address to any devices attached to those ports. This router will never be connected to the internet and will only be used for automated testing of devices. Current config is below.
# may/23/2023 09:51:58 by RouterOS 6.48.6
# software id = 52YK-F3F9
# model = RB3011UiAS
# serial number = HDF08K87RZ0
add admin-mac=48:A9:8A:08:00:66 auto-mac=no comment=defconf name=bridge
add name=bridge9
add name=bridge10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.10-192.168.88.19
add name=dhcp_pool1 ranges=192.168.10.22-192.168.88.20
add name=pool9 ranges=192.168.9.10-192.168.9.12
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=pool9 disabled=no interface=bridge9 name="DHCP server9"
add address-pool=dhcp_pool1 disabled=no interface=bridge10 name=server10
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf disabled=yes interface=ether8
add bridge=bridge9 comment=defconf interface=ether9
add bridge=bridge10 comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
    192.168.88.0
add address=192.168.9.1 interface=bridge9 network=192.168.9.0
add address=192.168.88.20 interface=bridge10 network=192.168.88.20
/ip arp
add address=192.168.9.1 interface=bridge9 published=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.9.0/24 dns-server=192.168.9.1 domain=test gateway=\
    192.168.9.1 netmask=24 wins-server=192.168.9.1
add address=192.168.88.20/32 dns-server=192.168.88.1 gateway=192.168.88.1 \
    netmask=24 wins-server=192.168.88.1
set allow-remote-requests=yes servers=192.168.9.1
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add distance=1 dst-address=192.168.9.0/24 gateway=bridge
add distance=1 dst-address=192.168.88.0/24 gateway=bridge9
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
OldGuy
Wed May 24, 2023 1:08 am
Think I have it working. Corrected the pool1 DHCP range I only noticed after posting this. I am now able to ping across the subnets, which wasnt happening before.
Going to test it tomorrow and see what happens.
Users browsing this forum: MauriceW, scooterpl, SpOuK3 and 110 guests
