Coussa
Multiple SSID's?
Sun Jan 30, 2005 9:01 am
Is it possible to create multiple SSID's on one wireless interface? Eventually, I would like to assign one SSID to one VLAN. Can this be done with MT (Cisco 1200AP can do it)?
Thanks for the assistance.
blue
Sun Jan 30, 2005 11:38 am
Just add VirtualAP device, choose which wlan card to use and enter SSID...
denialsander
Re: Multiple SSID's?
Sun Jan 30, 2005 1:03 pm
Create a viritual AP, and assign it to your master WLAN interface. Then you add a VLAN and assign it to the Viritual AP (WLANx).
sten
Forum Veteran
Forum Veteran
Sun Jan 30, 2005 9:34 pm
Yes RouterOS can do this.
Add VirtualAP to master interface (real wireless interface) and add vlan on say ether1 (if vlan switch is connected to ethernet). Bridge traffic from virtualap interface with vlan interface and you effectivly "assign a vlan to an ssid".
Coussa
Mon Jan 31, 2005 10:15 am
Many thanks guys...
