int
[discovery] lldp-med-net-policy-vlan not working on CCR2116
Tue May 23, 2023 2:15 am
Hello, new here.
Scenario:
CCR2116 — eth4 — Yealink Phone — PC
Yealink Phone doesn’t receive tagged VLAN Voice from LLDP-MED and therefore remains on untagged VLAN without join tagged VLAN voice.
lldp-med-net-policy-vlan is correctly enabled and configured with voice VLAN.
Yealink Phone works like a charm receiving Voice VLAN with others switch vendors and LLDP-MED.
Any ideas? At the moment the workaround to put phone on correct Voice VLAN is to use DHCP Option 132.
add name=discovery_list
add interface=ether4 list=discovery_list
set discover-interface-list=discovery_list lldp-med-net-policy-vlan=5 protocol=lldp,mndp
add bridge=bridge1 comment="IP Phone" interface=ether4 pvid=10
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether4 vlan-ids=5
Thanks,
Gianremo
ryba84
Re: [discovery] lldp-med-net-policy-vlan not working on CCR2116
Thu May 25, 2023 9:45 am
In the docs there is:
When used together with the bridge interface, the (R/M)STP protocol should be enabled with protocol-mode setting.
Additionally, other neighbor discovery protocols (e.g. CDP) should be excluded using protocol setting to avoid LLDP-MED misconfiguration.
int
Thu May 25, 2023 11:01 am
Hello, thanks for answer.
Yes, already tried that but with no luck.
add ether-type=0x8100 fast-forward=yes frame-types=admit-all ingress-filtering=yes name=bridge1 priority=0x1 protocol-mode=rstp pvid=1 vlan-filtering=yes
int
Mon Jun 05, 2023 8:03 pm
update from MikroTik support #[SUP-115696]
Thank you for the report!
We have managed to reproduce the issue locally in our labs and look forward to fixing it on upcoming RouterOS versions, unfortunately, I cannot provide a release date now.
If you downgrade to RouterOS 7.7, the LLDP-MED should reply with VLAN ID.
Best regards,
Edgars P.
