sokeada
RB951Ui-2HnD Storage Issue
Tue May 23, 2023 5:54 am
Dear All,
I've four of RB951Ui-2HnD running the same Router Board OS 7.9.1 with the same firewall configuration. My problem is, one of those four is using 98.x MiB of 12MiB of storage space while the others only use around 37MiB to 40MiB of 128MiB. I tried to find the way to check the used space or other way to fix the storage issue but seems no luck.
Anyone please share me some tips.
NOTE: those four routers are placing at remote location that I can't perform netinstall or reset.
Regards,
Sokeada
holvoetn
Re: RB951Ui-2HnD Storage Issue
Tue May 23, 2023 8:25 am
Too bad about your last remark because my first suggestion would be netinstall ...
sokeada
Tue May 23, 2023 12:44 pm
Thanks for your comment, bro. If there is only option, I'll try to replace router then.
holvoetn
Tue May 23, 2023 12:49 pm
Why replace it ?
If the storage is no issue (apart from the fact it is lower) and there is no other symptom of problems ??
sokeada
Wed May 24, 2023 6:11 am
Why replace it ?
so far there is no problem of the slowness of other but in monitoring system keeping alert of low storage space so I'm afraid of one day it stuck or hang.
Users browsing this forum: No registered users and 24 guests
