lihku
Low dBm on a 13km PTP link
Tue May 23, 2023 3:38 pm
Hi
I am having problems getting good enough signal strength (dBm) with a wireless radio link I mounted recently using Netmetal 5shp coupled with a 37x37cm square panel antenna.
I am shooting from a mountaintop down to a barge on the sea. I've tried to align it to the best of my ability, but approximately -62/-62 dBm is the best I can achieve. I am aware of the complications emerging with these over the sea links.
My questions are:
Is this the best a Netmetal 5shp can achieve at this distance?
Or is this the best I can hope for with the sea reflections and all?
Maybe my configuration can be better?
This is the setup:
Antenna:
Configuration and status:
MASTER
name="wlan1" mtu=1500 l2mtu=1600 mac-address=x arp=enabled interface-type=Atheros AR9888 mode=ap-bridge ssid="x" frequency=5400
band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee secondary-channel="" scan-list=default wireless-protocol=nstreme vlan-mode=no-tag vlan-id=1 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
interface=wlan1 radio-name="x" mac-address=x ap=no wds=no bridge=yes rx-rate="6Mbps" tx-rate="585Mbps-80MHz/2S" packets=213543,155250
bytes=175487796,77056496 frames=213543,155250 frame-bytes=174237870,76124996 hw-frames=407107,11928285 hw-frame-bytes=293044148,624870978 tx-frames-timed-out=0
uptime=1h20m43s last-activity=0ms signal-strength=-63dBm@6Mbps signal-to-noise=41dB signal-strength-ch0=-71dBm signal-strength-ch1=-64dBm
strength-at-rates=-63dBm@6Mbps 0ms,-62dBm@9Mbps 1h20m42s510ms,-62dBm@12Mbps 1h20m41s420ms,-62dBm@18Mbps 1h20m40s230ms,-64dBm@24Mbps 1h20m38s840ms,-61dBm@36Mbps
28m55s440ms,-62dBm@48Mbps 12m27s720ms,-65dBm@54Mbps 12m35s960ms
tx-ccq=84% p-throughput=8318 nstreme=yes nstreme-plus=yes framing-mode=none routeros-version="6.47.3" last-ip=x 802.1x-port-enabled=yes
management-protection=no compression=no wmm-enabled=yes tx-rate-set="OFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9"
SLAVE
mode=station-bridge ssid="x" frequency=auto band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee
secondary-channel="" scan-list=default wireless-protocol=nv2-nstreme vlan-mode=no-tag vlan-id=1 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
interface=wlan1 radio-name="x" mac-address=x ap=yes wds=no bridge=yes rx-rate="6Mbps"
tx-rate="468Mbps-80MHz/2S" packets=155120,207034 bytes=74387083,174674120 frames=155120,207034
frame-bytes=73490179,173431916 hw-frames=314319,11434208 hw-frame-bytes=124102559,699231225 tx-frames-timed-out=0
uptime=1h16m40s last-activity=10ms signal-strength=-62dBm@6Mbps signal-to-noise=44dB signal-strength-ch0=-66dBm
signal-strength-ch1=-64dBm tx-signal-strength-ch0=-68dBm tx-signal-strength-ch1=-64dBm
strength-at-rates=-62dBm@6Mbps 10ms,-62dBm@9Mbps 1h16m33s60ms,-62dBm@12Mbps 1h16m32s150ms,-62dBm@18Mbps 1h16m32s80ms,-
63dBm@24Mbps 1h16m31s650ms,-62dBm@36Mbps 20m46s960ms,-63dBm@48Mbps 2m4s610ms,-64dBm@54Mbps 1s810ms
tx-signal-strength=-63dBm tx-ccq=90% rx-ccq=97% p-throughput=413323 nstreme=yes nstreme-plus=yes framing-mode=none
routeros-version="6.48.6" last-ip=x 802.1x-port-enabled=yes management-protection=no compression=no
Users browsing this forum: grusu, ivicask, massinia and 70 guests
