sebamikrotik
DHCP option 82 not predictable  [SOLVED]
Tue May 23, 2023 8:11 pm
we use RouterOS 7.9 with CRS354-48P-4S+2Q+.
We would like to use DHCP option 82 to allow access via the Circuit-id, now the problem is the Circuit-id is not predictable.
It is the same bridge with DHCP snooping and the Option82 activated, same bridge port configuration etc.. but even if the differ, in my opinion the Circuit-id should be predictable.
In one case it adds 13 in the other case it adds 14.
ether9 + 13 ( in case one ether9 + 13 = 22:10)
DHCP options:
[82] Relay agent information: len = 35
[1] Circuit-id: SWITCH02 eth 0/22:10
[2] Remote-id: ether9
In the other case the Circuit-id is ether43 + 14 = 57)
[82] Relay agent information: len = 36
[1] Circuit-id: SWITCH02 eth 0/57:10
[2] Remote-id: ether43
I've downgrade to 7.7 but all the version show this behavior, I see in wireshark the CRS354 send the "wrong" Circuit-id:.
Any ideas?
Thank you
Seb
sebamikrotik
Re: DHCP option 82 not predictable
Wed May 24, 2023 9:04 am
I found the problem.
/interface/ethernet/switch/port print show-ids
* NAME SWITCH STORM-RATE
*25 ether24 switch1 100
*26 ether25 switch1 100
*28 ether26 switch1 100
*29 ether27 switch1 100
*27 was missing, this caused the problem with the ports starting from ether26.
Reason was a missing delay in the .rsc file after reset-configuration
ssystem/reset-configuration no-defaults=yes run-after-reset=
After I insert several delays everything works as it should, option 82 is reliably predictable.
Seb
Users browsing this forum: Ramirocuei and 149 guests
