ronajon
Spotify and Chromecast error
Wed May 24, 2023 11:13 pm
since a couple of days, i'm having a weird problem with both spotify and chromecast.
my router is a RB4011iGS+RM
i have an Arcam SA30 amplifier wired connected to LAN port 7, and a Chromecast to LAN port 3
both devices are assigned to VLAN110
when i'm trying to connect with my mobile phone (also on VLAN110, which connects wireless with an Ruckus AP on LAN port 10) the phone sees both devices, tries to setup the connection, but won't connect.
i've already tried with different phones and laptops, reinstalling spotify but unfortunately to no avail.
I've got an HP Microserver with Logitech Music Server in an LXC container, and connecting through upnp with the amplifier works flawlessly. also bubble upnp connects from my phone to the amp.
is there anything in my config that can block the connection to the Chromecast and Spotify ?
# may/24/2023 21:34:46 by RouterOS 7.9.1
# software id = 3RDL-S6FU
# model = RB4011iGS+
# serial number = xxx
add fast-forward=no ingress-filtering=no name=bridge-local vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] comment=192.168.110.16 name=ether2-TV
set [ find default-name=ether3 ] name=ether3-Chromecast
set [ find default-name=ether6 ] comment=meterkast name=ether6-switch
set [ find default-name=ether7 ] comment="arcam SA30" name=ether7-arcam
set [ find default-name=ether9 ] name=ether9-RB260GSP
set [ find default-name=ether10 ] name=ether10-R500 poe-priority=1
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface veth
add address=172.17.0.2/24 gateway=172.17.0.1 name=veth1
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard
/interface vlan
add interface=ether1-WAN name=vlan-internet vlan-id=300
add comment=servers interface=bridge-local name=vlan105 vlan-id=105
add comment="IOT network" interface=bridge-local name=vlan110 vlan-id=110
add comment="guest network" interface=bridge-local name=vlan120 vlan-id=120
add comment="guest network" disabled=yes interface=bridge-local name=vlan172 vlan-id=172
add comment="WAN interface" name=WAN
add name=LAN
/interface lte apn
add interface=vlan105 lease-time=10m name=dhcp-vlan105
add name=dhcp-local ranges=192.168.0.180-192.168.0.254
add name=pool-vlan110 ranges=192.168.110.180-192.168.110.249
add name=pool-vlan120 ranges=192.168.120.180-192.168.120.254
add name=pool-vlan172 ranges=172.16.0.3-172.16.0.10
add address-pool=dhcp-local interface=bridge-local lease-time=5m name=dhcp-local
add address-pool=pool-vlan110 interface=vlan110 lease-time=5m name=dhcp-vlan110
add address-pool=pool-vlan120 interface=vlan120 lease-time=5m name=dhcp-vlan120
add address-pool=pool-vlan172 disabled=yes interface=vlan172 lease-time=10m name=dhcp-vlan172
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
add disabled=no name=default-v3 version=3
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add disabled=yes instance=default-v3 name=backbone-v3
/routing table
add fib name=""
/container
add envlist=repeater_envs hostname=mdns-repeater interface=veth1 start-on-boot=yes
/container envs
add key=REPEATER_INTERFACES name=repeater_envs value="eth0.110 eth0.120"
add bridge=bridge-local ingress-filtering=no interface=ether2-TV pvid=110
add bridge=bridge-local ingress-filtering=no interface=ether3-Chromecast pvid=110
add bridge=bridge-local ingress-filtering=no interface=ether4 pvid=110
add bridge=bridge-local ingress-filtering=no interface=ether5 pvid=110
add bridge=bridge-local ingress-filtering=no interface=ether6-switch pvid=110
add bridge=bridge-local ingress-filtering=no interface=ether7-arcam pvid=110
add bridge=bridge-local ingress-filtering=no interface=ether9-RB260GSP
add bridge=bridge-local ingress-filtering=no interface=ether10-R500
add bridge=bridge-local ingress-filtering=no interface=sfp-sfpplus1
add bridge=bridge-local ingress-filtering=no interface=ether8
add bridge=bridge-local interface=veth1
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set accept-router-advertisements=no max-neighbor-entries=8192
/interface bridge vlan
add bridge=bridge-local tagged=ether10-R500,ether9-RB260GSP,bridge-local,veth1 untagged=ether2-TV,ether3-Chromecast,ether5,ether4,ether7-arcam,ether6-switch vlan-ids=110
add bridge=bridge-local tagged=ether10-R500,ether9-RB260GSP,bridge-local,veth1 vlan-ids=120
add bridge=bridge-local disabled=yes tagged=ether9-RB260GSP,ether10-R500,bridge-local untagged=ether7-arcam vlan-ids=172
add bridge=bridge-local tagged=bridge-local,ether9-RB260GSP,ether4 vlan-ids=105
add interface=bridge-local list=LAN
add interface=vlan-internet list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.0.0.2/32 comment="" interface=wireguard public-key="xxx"
add allowed-address=10.0.0.3/32 comment="" interface=wireguard public-key="xxx"
add address=192.168.0.1/24 interface=bridge-local network=192.168.0.0
add address=192.168.110.1/24 interface=vlan110 network=192.168.110.0
add address=192.168.120.1/24 interface=vlan120 network=192.168.120.0
add address=172.16.0.1/12 interface=vlan172 network=172.16.0.0
add address=10.0.0.1/24 interface=wireguard network=10.0.0.0
add address=192.168.105.1/24 interface=vlan105 network=192.168.105.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1d
/ip dhcp-client
add interface=vlan-internet use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.110.20 comment="Chromecast" mac-address=44:09:B8:FE:EB:8C server=dhcp-vlan110
add address=192.168.110.57 mac-address=aa:bb:cc:dd:ee:ff server=dhcp-vlan110
add address=192.168.110.51 mac-address=aa:bb:cc:dd:ee:ff server=dhcp-vlan110
add address=192.168.110.52 mac-address=aa:bb:cc:dd:ee:ff server=dhcp-vlan110
add address=192.168.110.14 mac-address=aa:bb:cc:dd:ee:ff server=dhcp-vlan110
add address=192.168.110.15 comment="Arcam SA30" client-id=1:0:1b:7c:8:3b:24 mac-address=00:1B:7C:08:3B:24 server=dhcp-vlan110
add address=172.16.0.0/24 dns-server=1.1.1.1 gateway=172.16.0.1
add address=192.168.0.0/24 dns-server=192.168.0.12,192.168.0.11 domain=lan gateway=192.168.0.1
add address=192.168.105.0/24 dns-server=192.168.0.12,192.168.0.11 domain=lan gateway=192.168.105.1 netmask=24
add address=192.168.110.0/24 dns-server=192.168.0.12,192.168.0.11 domain=lan gateway=192.168.110.1 netmask=24
add address=192.168.120.0/24 dns-server=192.168.0.12,192.168.0.11 domain=lan gateway=192.168.120.1 netmask=24
set cache-max-ttl=1d
/ip firewall address-list
add address=192.168.100.0/24 list=localNet
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 list=not_in_internet
add address=192.168.0.0/16 list=not_in_internet
add address=169.254.0.0/16 list=not_in_internet
add address=127.0.0.0/8 list=not_in_internet
add address=224.0.0.0/4 list=not_in_internet
add address=198.18.0.0/15 list=not_in_internet
add address=192.0.0.0/24 list=not_in_internet
add address=192.0.2.0/24 list=not_in_internet
add address=198.51.100.0/24 list=not_in_internet
add address=203.0.113.0/24 list=not_in_internet
add address=100.64.0.0/10 list=not_in_internet
add address=240.0.0.0/4 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=not_in_internet
add address=255.255.255.255 list=lan_ip
add address=192.168.0.0/24 comment="Trusted LAN " list=trusted-LAN
add address=192.168.110.0/24 list="untrusted VLAN"
add address=192.168.120.0/24 list="untrusted VLAN"
add address=192.168.0.0/16 list=mynetwork
add address=192.168.0.12 list=pihole
add address=172.16.0.0/12 list="untrusted VLAN"
add address=10.0.0.0/24 list=vpn
add address=192.168.0.10 disabled=yes list=extDNS
add address=172.16.0.20 disabled=yes list=extDNS
add address=192.168.0.128 disabled=yes list=extDNS
add address=192.168.105.0/24 list="untrusted VLAN"
add address=192.168.110.105 comment=homeassistant list=acl_postgres
add address=192.168.110.107 comment=teslamate list=acl_postgres
add address=192.168.110.118 comment=miniflux list=acl_postgres
add address=192.168.110.104 comment=grafana list=acl_influx
add address=192.168.110.105 comment=homeassistant list=acl_influx
add address=192.168.110.107 comment=teslamate list=acl_influx
add address=192.168.110.104 comment=grafana list=acl_postgres
add address=192.168.0.1 comment=snmp list=infra
add address=192.168.0.2 comment=snmp list=infra
add address=192.168.0.5 comment=snmp list=infra
add address=172.21.0.2 comment=docker list=acl_mariadb
add address=192.168.110.216 list=acl_influx
add address=192.168.0.183 list=acl_influx
add address=192.168.110.5 comment=docker list=acl_postgres
add address=192.168.0.11 list=pihole
add address=192.168.110.103 comment=spotweb list=acl_postgres
add address=192.168.110.119 comment=invidious list=acl_postgres
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="servers to LAN" dst-address-list=mynetwork in-interface=vlan105
add action=accept chain=forward comment=postgres dst-address=192.168.105.11 dst-port=5432 protocol=tcp src-address-list=acl_postgres
add action=accept chain=forward comment=influxdb dst-address=192.168.105.12 dst-port=8086 protocol=tcp src-address-list=acl_influx
add action=accept chain=forward comment=mysql disabled=yes dst-address=192.168.105.15 dst-port=3306 protocol=tcp
add action=accept chain=input comment="telegraf snmp" dst-address=192.168.0.1 protocol=udp src-address=192.168.105.14
add action=accept chain=forward comment="telegraf snmp" dst-address-list=infra protocol=udp src-address=192.168.105.14
add action=accept chain=input comment="api access from homeassistant" dst-port=8728 protocol=tcp src-address=192.168.110.105
add action=accept chain=forward dst-address=192.168.120.0/24 protocol=tcp src-address=192.168.110.105
add action=accept chain=forward dst-address=192.168.120.0/24 protocol=udp src-address=192.168.110.105
add action=accept chain=forward comment="VLAN DNS" dst-address-list=pihole dst-port=53 protocol=udp src-address-list="untrusted VLAN"
add action=accept chain=forward comment="VLAN DNS" dst-address-list=pihole dst-port=53 protocol=tcp src-address-list="untrusted VLAN"
add action=accept chain=forward comment="sensecap M1" disabled=yes dst-address=192.168.0.10 dst-port=44158 protocol=tcp src-port=44158
add action=accept chain=input comment=wireguard dst-port=13231 log-prefix=wireguard protocol=udp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="Accept from VPN to LAN" connection-state=established,related dst-address-list="untrusted VLAN" src-address-list=vpn
add action=drop chain=input comment="defconf: accept ICMP" protocol=icmp
add action=drop chain=forward comment="Drop from VLAN to LAN" connection-state=!established dst-address-list=trusted-LAN src-address-list="untrusted VLAN"
add action=drop chain=forward comment="Drop from VLAN to VLAN" dst-address-list="untrusted VLAN" src-address-list="untrusted VLAN"
add action=drop chain=input comment="defcon: drop all not coming from LAN" in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="redirect port for Sensecap M1" disabled=yes dst-port=44158 protocol=tcp to-addresses=192.168.0.10 to-ports=44158
add action=dst-nat chain=dstnat comment="bypass pihole" disabled=yes dst-port=53 protocol=udp src-address-list=extDNS to-addresses=1.1.1.1
add action=dst-nat chain=dstnat comment="bypass pihole" disabled=yes dst-port=53 protocol=tcp src-address-list=extDNS to-addresses=1.1.1.1
add action=masquerade chain=srcnat src-address=172.17.0.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set active-flow-timeout=1m cache-entries=64k
/ip upnp
set enabled=yes
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 nd
/snmp
set enabled=yes trap-generators="" trap-version=2
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name="MikroTik RB4011iGS+RM"
/system logging
add topics=dns
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=64.99.80.121
add address=20.101.57.9
/system resource irq rps
set sfp-sfpplus1 disabled=no
/system scheduler
add interval=1w name=run-7d on-event=backup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=aug/19/2021 start-time=09:07:12
/system script
add dont-require-permissions=no name=backup owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="xxx"
/tool bandwidth-server
set enabled=no
/tool graphing
set page-refresh=60
/tool graphing interface
/tool netwatch
add comment="update DNS when Ubound is down" disabled=no down-script="xxx"
ronajon
Re: Spotify and Chromecast error
Fri May 26, 2023 12:29 pm
issue solved
pihole was blocking dealer.spotify.com domain
after whitelisting everything worked again
Users browsing this forum: Amazon [Bot], emunt6, Majestic-12 [Bot] and 83 guests
