It is clear that you can cut off the phrase using
:local numbers [:pick "text" <start>[<count>]]
The cut phrase is also easy to put in an array like this
:local newNumbers [:toarray $numbers]
[10[2,125]]
[2[1,80]]
[7[0,8080]]
[10[2,125]]
[2[1,80]]
[7[0,8080]]
bla-bla 10,2,,125
43800200437043C043E04360435043C043E002107918350000014F0600ED0D63739500030C07070438043C04300439043C043E0441044F00210020042004300437043E043C0020043C06C7EBBCB0008221120513141803C0
bla-bla 2,1,,80
BBCB0008221120513141808C0500030C070104140440044304370456002C0020044707918350000014F0400ED0D637396C7E04350440043504370020043F043E043204420443E0440043E0433043000200432002004340435044F043A0438044500200440043504330456043E043D0430044500200423043A044004300457043D043800200432045604340441044304423E0440043D04560020043004420430043A0438002004320
bla-bla 7,0,,8080
120513141808C0500030C070207918350000014F0400ED0D637396C7EBBCB0008221043D045400200435043B0435043A004470430043D043D044F002E0020041C043E0436044304420440043E043F043E044104420430442044C002004320438043D0438043A043004420438002004423E0432045600200441043A043B04300434043D043E044904560020043704560020043704322019044F0437043A0438043C04470430044104
:local start [0,197,552]
:local len [18,17,19]
For your example:That is, so that the first numbers are of the index typeCode: Select all[ [10[2,125]] [2[1,80]] [7[0,8080]] ]
# init main array
:local arr {"10"={2;125}; "2"={1;80}; "7"={0;8080}}
# extracts inner array for index 10 (actually is key)
:local arr10 ($arr->"10")
# adds 1345 into inner array
:set arr10 ($arr10, 1345)
# sets updated inner array to main array
:set ($arr->"10") $arr10
# init new inner array
:local arr44 {77;0}
# sets new inner array to main array at index 44
:set ($arr->"44") $arr44
:local arr {"10"={"1"={2;125}; "2"={3;34}}};
:put ($arr->"10"->"1")
:put ($arr->"10"->"2")
{ :local newarr {2,125;1,80;0,8080} :put ($newarr->0->0) :put ($newarr->0->1) :put ($newarr->1->0) :put ($newarr->1->1) :put ($newarr->2->0) :put ($newarr->2->1) } { :local newarr [:toarray ""] :set ($newarr->10) {2;125} :set ($newarr->2) {1;80} :set ($newarr->7) {0;8080} :put ($newarr->10->0) :put ($newarr->10->1) :put ($newarr->2->0) :put ($newarr->2->1) :put ($newarr->7->0) :put ($newarr->7->1) } { :local newarr {"10"=2,125;"2"=1,80;"7"=0,8080} :put ($newarr->"10"->0) :put ($newarr->"10"->1) :put ($newarr->"2"->0) :put ($newarr->"2"->1) :put ($newarr->"7"->0) :put ($newarr->"7"->1) }
Your answer helped a lot to create an array that contains the length of the phrase. That is, the array lenI've already answered this:
Yeah, I was editing my post with additional examples, you were faster... Arrays and maps can be created and manipulated in ros script in various ways.This is example of little "nested" () array of arays of arrays and other non array inside other arrays...
viewtopic.php?p=973659&hilit=json#p973295
for convert this
[10[2,125]]
[2[1,80]]
[7[0,8080]]
to
new array with on index 2 another array of values 1 and 80, on index 7 another array of values 0 and 8080, on index 10 another array of values 2 and 125
there are some ways to convert that on one array of arrays:
Good fortune...I just want to get some information about sms.
I guess I need to update my sms2email script with this.Good fortune...I just want to get some information about sms.
viewtopic.php?p=797583#p797583
I just done this two parts:
Function to convert Hex GSM7 to CP1252 string (for decode the PDU message part on GSM7)
viewtopic.php?t=177551#p992792
and
Function to convert one CP1252 (or simply ASCII-7-bit) string to one Hex GSM7 string (for create the PDU message part on GSM7)
viewtopic.php?t=177551#p992677
and also this two for UCS-2
Function to convert UCS-2 to UTF-8 (for decode the PDU message part on UCS-2)
viewtopic.php?p=983695#p983695
Function to convert UTF-8 to UCS-2 (for create the PDU message part on UCS-2)
viewtopic.php?p=985041#p985041
But only the author on the first link have patience to decode the rest of the PDU message....
Thank you. I have seen this thread. It contains a lot of redundant information. And there is no one that interests me. But I already said that I don't need someone else's function. I want to figure it out myself. Maybe later I will want to forward the SMS somewhere, but for now it's enough for me to read the SMS. And in my opinion it would be much more correct to put the read SMS in an array. So it would be more convenient for further work with him. The author of that project does not do this. The structure is more rigid than I would like. Maybe I'm wrong and I don't understand all the code in that thread. In any case, I would like to learn how to read SMS myself.Good fortune...
Thanks for your examples. I'm starting to understand a little. Of course, I'm still far from fully understanding, but these examples are beginning to help.For your example:
In ROS script you have one dimensional array in formatThanks for your examples. I'm starting to understand a little. Of course, I'm still far from fully understanding, but these examples are beginning to help.For your example:
{val1; val2; val3; ...}
{"key1"=val1; "key2"=val2; "key3"=val3; ...}
I more or less understand this, but how can I access the internal data index in key 10 directly?# extracts inner array for index 10 (actually is key)
foreach a,k in=$arr do={
:put "$a=$k";
10=2;10=125
2=1;2=80
7=0;7=8080
:local key10 ($arr->"10")
:put $key10
2;125
# init 2 main multy array
:local multy {"10"={k1={2};k2={125}}; "2"={k1={1};k2={80}}; "7"={k1={0};k2={8080}}}
:put $multy
:local multy1 {"10"={k1=2;k2=125}; "2"={k1=1;k2=80}; "7"={k1=0;k2=8080}}
:put $multy1
10=k1=2;k2=125;2=k1=1;k2=80;7=k1=0;k2=8080
:local mu ($multy->"10"->"k1")
:put $mu
:local mu1 ($multy1->"10"->"k1")
:put $mu1
2
2
foreach aa,kk in=$multy do={
:put "$aa=$kk";
foreach aaa,kkk in=$multy1 do={
:put "$aaa=$kkk";
:local smsList {{"phone"="+123456787"; "message"="sms message 1"; "timestamp"="May/25/2023 18:08:09 GMT -0"; "type"="class-0"}; {"phone"="+4356546456"; "message"="sms message 2"; "timestamp"="May/25/2023 18:08:09 GMT -0"; "type"="class-0"}}
#to get single sms at index 0
:local sms ($smsList->0)
#to get sms phone property
:put ($sms->"phone")
#to get sms message property
:put ($sms->"message")
# etc...
#or to process whole list:
:foreach sms in=$smsList do={
Maybe you're right. I haven't decided yet how it will be. In this tutorial, I'm trying to understand what arrays can do in Mikrotik scripts. One of the goals is to display a table like this:You can achieve that with inner array instead of using properties map and get certain property by index of inner array, but for me this approach has less cognitive complexity code.
№ | SCA | timestamp |status| Body |
Unfortunately, I haven't had time to take a closer look at your example yet. Hope to do it tonight.You have to use the 3rd example here.
Why lost time to call first value (index 0) k1 and second value (index 1) k2?
Simply call the value...
viewtopic.php?t=196458#p1004142
then for each column you can have map property key per sms message like in my example, either you are using sms tool inbox or extracting PDU directly from modem.Code: Select all--------------------------------------------------------------------------------| № | SCA | timestamp |status| Body | --------------------------------------------------------------------------------|
also in example: ($smsList->0), index can be variable also, ($smsList->$index)And I understand that your foreach loop can theoretically accomplish this.
But I also want to have access to any part of the SMS from anywhere and using any index, to understand which SMS it belongs to.
Depends how you look at mapsPerhaps your solution will be sufficient. Am I understanding correctly that it is a two-dimensional array?
#The variable where all the unprocessed SMS messages go
:local modemOutput ( [ /interface lte at-chat lte1 wait=yes input="AT+CMGL=4" as-value ]->"output" );
#Four variables for the counter.
:local matchPosition -1;
:local matchCount 0;
:local previous 0
:local continue true;
#The array where all occurrences of the found line endings are collected.
:local whereEnd ([:toarray ""]);
#The array where all the values of the phrase length, such as "+CMGL: 15,1,,155", are collected
:local arrayLen ({})
#An array where all positions of the occurrence of the phrase go
:local arrayHead ({})
#An array where all trimmed data from a phrase like "15,1,,155" should go
:local arrayStat ({})
#The loop for finding all the identified line ending characters.
while ( $continue ) do={
:set matchPosition [ :find $modemOutput $search $matchPosition ];
:if ( [ :typeof $matchPosition ] != "nil" ) do={
:set matchCount ( $matchCount + 1 );
# :put ( "Find position #" . [ :tostr $matchCount ] . " at: " . $matchPosition );
:set $whereEnd ($whereEnd, $matchPosition)
} else={ :set continue false; };
#The loop for creating an array where all the calculated lengths of phrases like "+CMGL: 15,1,,155" are stored.
:foreach key,num in=$whereEnd do={
if (($key % 2) = 0) do={
:put "$($num - $previous)"
:set $arrayLen ($arrayLen, $num - $previous)
} else={
:set previous $num
#:put "Find position #$key at:$num"
#Checking the result
:put $whereEnd
:put $arrayLen
#The loop for searching and creating an array from the results of trimming the phrase "+CMGL: 15,1,,155".
:set matchPosition [ :find $modemOutput $searchHead $matchPosition ];
:put $arrayLen
:set $arrayHead ($arrayHead, $matchPosition)
:set $arrayStat ($arrayStat, [:pick $modemOutput ($matchPosition+7) ($arrayLen->$matchCount) ] )
:put $arrayHead
:put $arrayStat
Okay, I'll fix this. I have inserted a few lines for clarification in the code. I forgot to add them when I did the translationAs already written on another post, never use ({}) the result is unexpected.
The only way to create empty array is [:toarray ""] and without ( ).
+CMGL: 0,1,"",48\r\n07912180958739F1040B917120069876F000009140503223218A21D4F29C0E6A97E7F3F0B90CA2BF41412A68F86EB7C36E32885A9ED3CB72\r\n +CMGL: 1,1,"",40\r\n07912180958739F1040B917120069876F000009140503223438A17D4F29C9E769F4141EA6AD83C3241C377BB1D769341\r\n +CMGL: 2,1,"",38\r\n07912180958739F1040B917120069876F000009140503233048A15D272980C0AB3D9A069730A6A97E7F3F0B93C07\r\n OKDo not split at \n (or more precisely to \r\n), split at +CMGL:
Unfortunately, I did not have time to notice that there is a carriage return symbol here. This makes the job easier to some extent.Do not split at \n (or more precisely to \r\n)
As far as I understand, in MikroTik there is no built-in way to split by a specific character. Maybe I haven't found it, but it seems that it only splits by comma.split at +CMGL:
:local matches [:toarray $modemOutput]
:foreach chast in=$matches do={
:put $chast;
I actually know what parts a SMS consists of. I even know that the phone number needs to be rearranged in pairs of digits. At the moment, my goal is to learn how to split the SMS into parts. However, I didn't understand two things: 1. How you split the modem response into a multidimensional array, and 2. Why there is an error in my code, as the other arrays are being filled.array of arrays: on each array the 1st value (0) is the index number, the 2nd (1) the message status, the 3rd (2) the used memory, and on the 4th (3) the PDU message.
07 91 2180958739F1 (sms center, length and international format, F is a filelr without value)
PDU HEADER: 04 (SMS-DELIVER)
TP-OA: 0B 91 7120069876F0 (sender number length and international format, F is a filelr without value)
TP-PID: 00 (no extra data)
TP-DCS: 00 (message text on GSM-7 format)
TP-SCTS 09140503223218A (date and time) (19-04-05 23:32:12 TZ
TP-UDL: 21 (message lenght)
TP-UD: D4F29C0E6A97E7F3F0B90CA2BF41412A68F86EB7C36E32885A9ED3CB72 (message)
:set $arrayStat ($arrayStat, [:pick $modemOutput ($matchPosition+7) ([ :find $modemOutput "\n" $matchPosition ] -1 ) ] )
:local search1 "+CMGL:";
:local search2 "\r\n";
:local arrayStat [:toarray ""]
:set matchPosition [ :find $modemOutput $search1 $matchPosition ];
:set $arrayStat ($arrayStat, [:pick $modemOutput ($matchPosition+7) ([ :find $modemOutput $search2 $matchPosition ] ) ] )
:put $arrayStat
I'm still thinking and deciding what would be more convenient. But your option looks if not exactly how I want it, then very close to what I wantOk, if you want one hand, since now the goal is sufficently precise:
I did not have time to check, but does it find the first occurrence in this form?at the start is :local start -2 because the first record start with "+CMGL: " that have 2 less characters: \r\n
If I output an AT command, then of course there is, but here in the script I did not notice it. This "OK" does not seem to be present when displaying the contents of the SMS."\r\nOK" is the end of AT output, so must be removed at the end.
You do not have noticed the "OK" at the end of AT+CMGL on your tests?
That is, if I save a number on the SIM card, for example, John Carter, and receive SMS from this number, will this field be filled in as John Carter?2)
this field is for the SIM that have in the internal SIM phonebook the number, also return the phonebook name... not all modem support that.
:local smsArray [:toarray ""]
:set $arrayStat ($arrayStat, [:pick $modemOutput ($matchPosition+7) [ :find $modemOutput $search2 $matchPosition ] ] )
:set matchPosition [ :find $modemOutput $search2 $matchPosition ];
:set smsArray ( $smsArray , [ :pick $modemOutput ( $matchPosition + 1 ) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] );
:put $arrayStat
:put $smsArray
foreach key,sms in=$smsArray do={
:put "$key=$sms";
:set smsArray ( $smsArray , [ :pick $modemOutput ( $matchPosition+1) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] );
to
:set smsArray ( $smsArray , [ :pick $modemOutput $matchPosition ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] );
I don't understand what you mean, in the first line only "+CMGL: " must be removed, because there is no \r\n at the start, so skip "\r\n+CMGL: " length - 2I did not have time to check, but does it find the first occurrence in this form?at the start is :local start -2 because the first record start with "+CMGL: " that have 2 less characters: \r\n
Try withIf I output an AT command, then of course there is, but here in the script I did not notice it. This "OK" does not seem to be present when displaying the contents of the SMS.You do not have noticed the "OK" at the end of AT+CMGL on your tests?
It seems to me that I have already written everything clearly.That is, if I save a number on the SIM card, for example, John Carter, and receive SMS from this number, will this field be filled in as John Carter?this field is for the SIM that have in the internal SIM phonebook the number, also return the phonebook name... not all modem support that.
This is what I was talking about. In such a situation, I see "OK". But if I do thisTry with
:put ([ /interface lte at-chat lte1 wait=yes input="AT+CMGL=4" as-value ]->"output" )
and you see the "OK" at the end.
:local search "\r\nOK";
The thing is, I'm not sure if Google translate is correct.It seems to me that I have already written everything clearly.
Later I will try to check and formulate my question in a different way to be more confident in the google translation.I don't understand what you mean, in the first line only "+CMGL: " must be removed, because there is no \r\n at the start, so skip "\r\n+CMGL: " length - 2
:set smsArray ( $smsArray , [ :pick $modemOutput ( $matchPosition+2) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] );
:put $arrayStat
:put "-----------";
:put $smsArray
Thanks, I'll take a look anyway. But now I have a problem with arrays. I can't figure out how to work with them.@DyadyaGenya
If you still have troubles with parsing PDU, here is mine script if you find it useful:
Of course your code works. But I'm learning and trying to do the same and use my experience. Below is my attempt to do something similar without taking into account phonebook data. How to substitute them I understand. But I can't put the SMS text into the array. Although I can either place it in a separate array or print it.Ok, if you want one hand, since now the goal is sufficently precise:
:local tmpStat [:toarray [:pick $modemOutput ($matchPosition+7) [ :find $modemOutput $search2 $matchPosition ] ] ]
:local subarray [:toarray ""]
:set ($subarray->"index" ) [:tonum ($tmpStat->0)]
:set ($subarray->"status") [:tonum ($tmpStat->1)]
:set ($subarray->"length") [:tonum ($tmpStat->2)]
#The line below is just for checking
:put [ :pick $modemOutput ( $matchPosition+2) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ];
:local tmpStat2 [:toarray [ :pick $modemOutput ( $matchPosition+2) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] ];
:set ($subarray->"sms" ) [:tonum ($tmpStat2->0)]
:set ($arrayStat->$matchCount) $subarray
:put $arrayStat
{ :local smsstatus [:toarray "REC UNREAD,REC READ,STO UNSENT,STO SENT,ALL"] :put ([/interface lte at-chat lte1 wait=yes input="AT+CMGL=$[:find $smsstatus "ALL" -1]" as-value ]->"output") }
{ :local smsstatus [:toarray "REC UNREAD,REC READ,STO UNSENT,STO SENT,ALL"] :local txtSMSpdu ([/interface lte at-chat lte1 wait=yes input="AT+CMGL=$[:find $smsstatus "ALL" -1]" as-value ]->"output") :local endsrch1 "\r\n+CMGL: " ; :local endsrch2 "\r\nOK" :local start -2; :local tmppos 0 ; :local index 0 :while (([:typeof [:find $txtSMSpdu $endsrch1 $start]] = "num") or ([:typeof [:find $txtSMSpdu $endsrch2 $start]] = "num")) do={ :if ([:typeof [:find $txtSMSpdu $endsrch1 $start]] = "num") do={ :set tmppos [:find $txtSMSpdu $endsrch1 $start] } else={ :set tmppos [:find $txtSMSpdu $endsrch2 $start] } :put [:pick $txtSMSpdu ($start + [:len endsrch1] + 1) $tmppos] :set index ($index + 1) :set start $tmppos } }
{ :local smsstatus [:toarray "REC UNREAD,REC READ,STO UNSENT,STO SENT,ALL"] :local txtSMSpdu ([/interface lte at-chat lte1 wait=yes input="AT+CMGL=$[:find $smsstatus "ALL" -1]" as-value ]->"output") :local endsrch1 "\r\n+CMGL: " ; :local endsrch2 "\r\nOK" :local start -2; :local tmppos 0 ; :local index 0 :while (([:typeof [:find $txtSMSpdu $endsrch1 $start]] = "num") or ([:typeof [:find $txtSMSpdu $endsrch2 $start]] = "num")) do={ :if ([:typeof [:find $txtSMSpdu $endsrch1 $start]] = "num") do={ :set tmppos [:find $txtSMSpdu $endsrch1 $start] } else={ :set tmppos [:find $txtSMSpdu $endsrch2 $start] } :local tmparray [:toarray [:pick $txtSMSpdu ($start + [:len endsrch1] + 1) $tmppos]] :put $tmparray :set index ($index + 1) :set start $tmppos } }
{ "smsc"="07912180958739F1"; "type"="04"; [this determines what other fields there will be after, for type="04" they are:] "sender"="0B917120069876F0"; "extra-data"="00"; "aplhabet-class-and-others"="00"; "date"="9140503223218A"; "timezone"="8A"; "length"="21"; "message"="D4F29C0E6A97E7F3F0B90CA2BF41412A68F86EB7C36E32885A9ED3CB72" }
{ "smsc"="+12085978931"; "type"="SMS-DELIVER"; [this determines what other fields there will be after, for type="SMS-DELIVER" they are:] "sender"="+17026089670"; "class"="standard"; [from aplhabet-class-and-others] "aplhabet"="GSM-7"; [from aplhabet-class-and-others] .... .... (some other decoded values from aplhabet-class-and-others and extra-data are possible, but I do not studied the full list) .... for example "SMS ID" and "SMS 1 of 2" for SMS with lenght > 160 characters. ..... "date"="19-04-05 23:32:12" "timezone"=-28"; (is GMT-7, so 28 times -15 minutes) "length"=21; "message"="Test message to AT Command Tester" }
Apparently all the same Google translator translates incorrectly. You misunderstood me. I'm just trying to do it step by step. And I built the steps for myself in my head approximately the same as you described. In my last post, I complained that I was missing one step. It was approximately at your step 3. Now I made it and went through all the steps that you wrote for step 6.You want to do too many things at once without knowing how to code.
:local smsStatus [:toarray "REC UNREAD,REC READ,STO UNSENT,STO SENT,ALL"]
:if ( [:len $tmpStat]=3 ) do={
:set ($subarray->"status") ($smsStatus->[:tonum ($tmpStat->1)])
:set ($subarray->"alpha") ("")
} else={
:set ($subarray->"length") [:tonum ($tmpStat->3)]
:set ($subarray->"alpha") [:tonum ($tmpStat->2)]
# :put [ :pick $modemOutput ( $matchPosition+2) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ];
:set ($subarray->"sms" ) ( [ :pick $modemOutput ( $matchPosition+2) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] )
:put $arrayStat
:put "-----------";
Please see my version.sms-read script is mostly created from scripts at
You need to decode PDU line from sms key in $arrayStat values map from offsets described at post #23 or see here: https://www.gsmfavorites.com/documents/sms/pdutext/. A lot of work is a front of you if you want to create all from scratch (there is a 1077 lines in sms-read script!). In that script this is handled by several functions, $extracted array contains PDU line for each sms (like from your array under value sms key), examine rest of a code from that point (Please see my version.sms-read script is mostly created from scripts at
:local extracted [$smsReadExtractPDUs]
{ :local smsStatus [:toarray "REC UNREAD,REC READ,STO UNSENT,STO SENT,ALL"] :local modemOutput ([/interface lte at-chat lte1 wait=yes input="AT+CMGL=4" as-value]->"output") :local search1 "+CMGL:" :local search2 "\r\n" :local matchPosition -1 :local matchCount 0 :local arrayStat [:toarray ""] while ([:typeof [:find $modemOutput $search1 $matchPosition]] != "nil") do={ :set matchPosition [:find $modemOutput $search1 $matchPosition] :local tmpStat [:toarray [:pick $modemOutput ($matchPosition + 7) [:find $modemOutput $search2 $matchPosition]]] :local subarray [:toarray ""] :set ($subarray->"index" ) [:tonum ($tmpStat->0)] :set ($subarray->"status") ($smsStatus->[:tonum ($tmpStat->1)]) :if ([:len $tmpStat] = 3) do={ :set ($subarray->"alpha" ) "" :set ($subarray->"length") [:tonum ($tmpStat->2)] } else={ :set ($subarray->"alpha" ) [:tonum ($tmpStat->2)] :set ($subarray->"length") [:tonum ($tmpStat->3)] } :set matchPosition [:find $modemOutput $search2 $matchPosition] :set ($subarray->"sms") ([:pick $modemOutput ($matchPosition + 2) [:find $modemOutput $search2 $matchPosition]]) :set ($arrayStat->$matchCount) $subarray :set matchCount ($matchCount + 1) } :foreach item in=$arrayStat do={ :put "SMS index=$($item->"index"), status=$($item->"status"), phonebook name=$($item->"alpha"), pdu length=$($item->"length")\r\n*** START PDU ***" :put ($item->"sms") :put "*** END PDU ***\r\n\r\n" } }If I continue to fix your code, at the end is identical to the mine.
And to continue to do that for several hundreds of lines for proper implementation... this will be a long thread
Very strange. I check the result of your script and mine and they have identical results in my opinion. Could you show what exactly is missing in my version? What symbols?Results:
ERROR: missing everytime last PDU hex value...
I have not yet begun to decode the body of the SMS itself, that is, such an excerpt as you showed. But I can even translate it a little with my hands. For example, the phone is SCA 12085978931, and the sender is 17026089670, TP-DCS is a 7-bit compressed encoding, the possible date of sending is 2019/04/05 23:32:12 A 8 time zone (probably China). Naturally, I'm not an expert and I'm not very good at decoding and I can make mistakes in this data, but I just started doing it.At the start try to convert just the string
ignoring all previous code, is useless at this step....
Example:Very strange. I check the result of your script and mine and they have identical results in my opinion. Could you show what exactly is missing in my version? What symbols?Results:
Could be a problem at line that matches expressionVery strange. I check the result of your script and mine and they have identical results in my opinion. Could you show what exactly is missing in my version? What symbols?
.*\$matchPosition[[:space:]]][[:space:]]-[[:space:]]1[[:space:]]\)[[:space:]]][[:space:]]\)$
If I do such a check, then these gaps are also clearly visible.
Even if I replace I will do this replacement:Code: Select allforeach key,sms in=$smsArray do={ :put "$key=$sms"; }
Code: Select all:set smsArray ( $smsArray , [ :pick $modemOutput ( $matchPosition+1) ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] ); to :set smsArray ( $smsArray , [ :pick $modemOutput $matchPosition ( [ :find $modemOutput $search2 $matchPosition ] - 1 ) ] );
You are really right. This is my carelessness. I corrected the starting point in one place, because I began to use "\r\n" instead of "\n" and forgot in another. This is how it works rightExample:
using my code
usin your (unaltered or clean, no difference) code
do not notice the mising 2 at the end?
:global printValue;
} else={
:set ($subarray->"sms" ) [ :pick $modemOutput ( $matchPosition+2) ( [ :find $modemOutput $search2 $matchPosition ] ) ]
:put $arrayStat
I think I went down the same path that you suggested looking for my mistake.Could be a problem at line that matches expressionwhich extracts one character less at the end...Code: Select all.*\$matchPosition[[:space:]]][[:space:]]-[[:space:]]1[[:space:]]\)[[:space:]]][[:space:]]\)$
Managed to watch. Here you are absolutely right. So the code will be more correct and shorter. I should have guessed it myself, even though I did a draft.:set ($subarray->"index" ) [:tonum ($tmpStat->0)]
} else={
I read somewhere that the "find" command is the most expensive and energy intensive. In my version, it is used only once.while ([:typeof [:find $modemOutput $search1 $matchPosition]] != "nil") do={
We are talking about at most 25 SMS, not a log of 1000 items or a firewall with 10,000 items...I read somewhere that the "find" command is the most expensive and energy intensive. In my version, it is used only once.
{ :local CMGLstatus [:toarray "REC UNREAD,REC READ,STO UNSENT,STO SENT,ALL"] :local CMGLoutput ([/interface lte at-chat ([find]->0) input="AT+CMGF=0;+CMGL=$[:find $CMGLstatus "ALL" -1]" wait=yes as-value ]->"output") # Future check: If CMGLoutput value is "OK" only, there is no results. :set CMGLoutput "$[:pick $CMGLoutput 7 ([:len $CMGLoutput] - 2)]+CMGL: " :local SMSarray [:toarray ""] :local separator "\r\n+CMGL: " :local lenCMGLsep [:len $separator] :local findStart (0 - $lenCMGLsep) ; :local tempPos 0 ; :local smsIndex 0 ; :local alphaIndex 0 ; :local rawIndex 0 :local findPosSeparator [:find $CMGLoutput $separator $findStart] :while ([:typeof $findPosSeparator] = "num") do={ :set tempPos $findPosSeparator :local tempArray [:toarray [:pick $CMGLoutput ($findStart + $lenCMGLsep) $tempPos]] # Future check: if on SIM phonebook the name containing comma, and the Modem reply with the name on SIM phonebook, prevent this problem :if ([:len $tempArray] = 4) do={:set alphaIndex 2 ; :set rawIndex 3} else={:set alphaIndex 4 ; :set rawIndex 2 ; :set ($tempArray->4) ""} :local subArray [:toarray ""] :set ($subArray->"index" ) [:tonum ($tempArray->0)] :set ($subArray->"status" ) ($CMGLstatus->[:tonum ($tempArray->1)]) :set ($subArray->"alpha" ) "\"$($tempArray->$alphaIndex)\"" :set ($subArray->"length" ) [:tonum [:pick ($tempArray->$rawIndex) 0 [:find ($tempArray->$rawIndex) "\r\n" -1]]] :set ($subArray->"PDU" ) [:pick ($tempArray->$rawIndex) ([:find ($tempArray->$rawIndex) "\r\n" -1] + 2) [:len ($tempArray->$rawIndex)]] :set ($SMSarray->$smsIndex) $subArray :set smsIndex ($smsIndex + 1) :set findStart $tempPos :set findPosSeparator [:find $CMGLoutput $separator $findStart] } :foreach item in=$SMSarray do={ :put "SMS index=$($item->"index"), status=$($item->"status"), phonebook name=$($item->"alpha"), pdu length=$($item->"length")" :put "*** START PDU ***" :put ($item->"PDU") :put "*** END PDU ***\r\n" } }
Do you have more examples explaining how to decipher some of the meanings? I can't figure out how to deal with the sender number and SMS type (SMS-DELIVER,SMS-STATUS REPORT,SMS-SUBMIT REPORT,RESERVED)You need to decode PDU line from sms key in $arrayStat values map from offsets described at post #23 or see here
Your code is really good, I didn't argue with that. But my task was first of all to learn different ways of working with arrays using the example of working with SMS. And I always keep your option in front of my eyes. If I understand correctly, then with the correction of my mistake about cutting off the last SMS character, there are no special comments on my version?I've updated my script by changing the variable names to be more consistent,
I've reformatted the code for clarity,
optimized the internal operations to execute as few instructions as possible
and make everything easier to understand how it works.
By the way, can you tell me the link where it is written about this?As already written on another post, never use ({}) the result is unexpected.
Just try it. It's a syntax error in recent V7 at least. But {} is [:nothing] (or nil), not an array.As already written on another post, never use ({}) the result is unexpected.
https://wiki.mikrotik.com/wiki/Manual:S ... mpty_arrayBy the way, can you tell me the link where it is written about this?
Or, for example, what is the type of SMS if it is encrypted as 44 or 60 or 40?
It's not entirely clear how I'm supposed to figure out which encoding to choose for my language. Here, it seems that the message is written in English, but it can only be translated by your UCS2toUTF8 function into some other numbers and percent signs, and the second function says that there is an error. Although the text in the SMS is written in English.TP-UDL: 21 (message lenght on septept, because is on GSM-7 format. Are octects if the mesage is on UCS-2)
(message encoded on octect, but internally is on septept for GSM-7, is on octect if is ASCII-8 or UCS-2)
Decode the GSM-7 or eventually the UCS-2 part is easy with my already existent functions.
Even from utf8 terminal over ssh? I've seen characters correctly displayed from scripts which are not in 7 bit ascii when connecting over ssh, still cli input is ascii always...RouterOS can display only 7 bit ascii standard characters, not GSM-7 UCS-2 or UTF-8
I'm not talking about third-party programs.Even from utf8 terminal over ssh? I've seen characters correctly displayed from scripts which are not in 7 bit ascii when connecting over ssh, still cli input is ascii always...RouterOS can display only 7 bit ascii standard characters, not GSM-7 UCS-2 or UTF-8
Ok, just saying, if you use remote terminal for cli connection (I'm always using cli like that) you can get proper output from script if terminal encoding is setup correctly.I'm not talking about third-party programs.
It's that program that shows them to you, not RouterOS...
With mine script when UCS-2 is converted to UTF8, that string variable is directly passed to /tool/e-mail/send and in received email body UTF8 characters are displayed correctly, doesn't matter if script is triggered over terminal, winbox or scheduler. For telegram I guess is needed to be url escaped, did not send over it to know, but I guess if is http api...I know, thanks, but it depends too much on the program used, and in general when you want to send an SMS via email or telegram, etc., don't go through SSH...
That is, it only concerns the creation of an empty array. If the array is created not empty, then it can be written in this way?Just try it. It's a syntax error in recent V7 at least. But {} is [:nothing] (or nil), not an array.
Please don't try to interpret what I write like someone do with the bible and the like.That is, it only concerns the creation of an empty array. If the array is created not empty, then it can be written in this way?Just try it. It's a syntax error in recent V7 at least. But {} is [:nothing] (or nil), not an array.
Sure, if there are values inside in {} – that's allowed. It's just the specific case of "{}" is NOT an empty array.If the array is created not empty, then it can be written in this way?
Can you provide an example of multiple SMS messages that consist of several parts?Maybe also checking UDH header for joining splitted messages will be nice![]()
You can create examples from here: https://www.smsdeliverer.com/online-sms ... coder.aspx, there is also PDU decoder: https://www.smsdeliverer.com/online-sms ... coder.aspx. These are for sms-submit PDUs, but decoding TP-UHDI and UHD part from TP-UD is the same as for deliver.Can you provide an example of multiple SMS messages that consist of several parts?
Unfortunately I don't understand your example. I see that it works for you, but I can't figure out how to use it myself. If possible, explain from the beginning. Here I received a PDU fragment "C8329BFD065DDF72363904". I write in the PDU that 7-bit encryption is used. What should I do next?viewtopic.php?t=177551#p993440
C8329BFD065DDF72363904 => 48656C6C6F20576F726C6421 => Hello World!
:put [$pdutogsm7 ("\C8\34\88\FE\06\05\D9\EC\50\28\04")]
:put [$HexGSM7toCP1252 ("48656C6C6F20576F726C6421")]
I can already parse SMS. I have two problems left: re-encode and glue if the SMS consists of several parts. These parts I can draw out separately. And when I print the array, they are clearly visible and the unique SMS number and serial number. But still unable to connect. In any case, the first priority is to recode. And for starters, I would like to understand the algorithm, if it is encoded using GSM 7, that is, the DCS field is equal to "00"@DyadyaGenya
IED3 is actually part number, join messages with same IED1 ordered by IED3.59 - IED1 (unique number), 03 - IED2 (number of parts), 03 - IED3 (serial number of the SMS part
I understand it. I can't write a function for this yet. Or insert the procedure into an existing function. And I have not yet wondered how to make such a function. For me, it's in the background. This was said only to demonstrate that the rest of the tasks have already been dealt with. Only these two remained. Although it still needs to be printed beautifully. But that's later.IED3 is actually part number, join messages with same IED1 ordered by IED3.
:put [$pdutogsm7 ("C8329BFD065DDF72363904") ]
:put [$HexGSM7toCP1252 ([$pdutogsm7 ("C8329BFD065DDF72363904") ] )]
how aboutBut I'm more concerned about the decoding issue.
I am trying to do something like this:orCode: Select all:put [$pdutogsm7 ("C8329BFD065DDF72363904") ]
But I'm getting bullshit.Code: Select all:put [$HexGSM7toCP1252 ([$pdutogsm7 ("C8329BFD065DDF72363904") ] )]
:put [$HexGSM7toCP1252 "C8329BFD065DDF72363904"]
how about?Code: Select all:put [$HexGSM7toCP1252 "C8329BFD065DDF72363904"]
Invalid 7-bit value (200)
You did not implement something right, I tried with functionLooks like I need to start a new thread.Code: Select all> :put [$HexGSM7toCP1252 "C8329BFD065DDF72363904"] Invalid 7-bit value (200)
smsReadConvert7bitToUtf8
> :put [$smsReadConvert7bitToUtf8 instring="C8329BFD065DDF72363904"];
Hello World!
:local arrayStat ( {
"01_index"=1;
"16_phoneSender"="+380000000000";
"19_SCTStime"="23-06-09 00:23:10 UTC = 3:0";
"20_TP-UDL"=2;
"21_UDH LENGTH"="0";
"22_UDH"=[];
"23_IEI"=[];
"24_IEDL"=[];
"25_IED1"=[];
"26_IED2"=[];
"27_IED3"=[];
"28_TEXT"="SMS01/"
"01_index"=2;
"19_SCTStime"="23-06-09 14:45:41 UTC = 3:0";
"20_TP-UDL"=160;
"21_UDH LENGTH"=5;
"22_UDH"="0003590301";
"23_IEI"="00";
"24_IEDL"="03";
"25_IED1"="59";
"26_IED2"="03";
"27_IED3"="01";
"28_TEXT"="SMS02/"
"01_index"=3;
"19_SCTStime"="23-06-09 14:45:43 UTC = 3:0";
"20_TP-UDL"=160;
"21_UDH LENGTH"=5;
"22_UDH"="0003590302";
"23_IEI"="00";
"24_IEDL"="03";
"25_IED1"="59";
"26_IED2"="03";
"27_IED3"="02";
"28_TEXT"="SMS03/"
"01_index"=4;
"19_SCTStime"="23-06-09 14:45:44 UTC = 3:0";
"20_TP-UDL"=18;
"21_UDH LENGTH"=5;
"22_UDH"="0003590303";
"23_IEI"="00";
"24_IEDL"="03";
"25_IED1"="59";
"26_IED2"="03";
"27_IED3"="03";
"28_TEXT"="SMS04/"
"01_index"=7;
"19_SCTStime"="23-06-12 19:22:55 UTC = 3:0";
"20_TP-UDL"=34;
"22_UDH"=[];
"23_IEI"=[];
"24_IEDL"=[];
"25_IED1"=[];
"26_IED2"=[];
"27_IED3"=[];
"28_TEXT"="SMS05/"
"01_index"=8;
"19_SCTStime"="23-06-12 19:31:09 UTC = 3:0";
"20_TP-UDL"=40;
"22_UDH"=[];
"23_IEI"=[];
"24_IEDL"=[];
"25_IED1"=[];
"26_IED2"=[];
"27_IED3"=[];
"28_TEXT"="SMS06/"
:local parsedArray [ :toarray "" ];
:local tempReadedSplitedSmsID [ :toarray "" ];
:local smsCounter 0;
:local successCounter 0;
:while ( ( [ :typeof ( $arrayStat->$smsCounter ) ] = "array" ) and ( [ :len ( $arrayStat->$smsCounter ) ] > 5 ) ) do={
:if ( [ :typeof ( $arrayStat->$smsCounter->"25_IED1" ) ] = "nil" ) do={
# full sms in one
:local splitedSms ( {
"16_phoneSender"=( $arrayStat->$smsCounter->"16_phoneSender" );
"19_SCTStime"=( $arrayStat->$smsCounter->"19_SCTStime" );
"TEXT"=( $arrayStat->$smsCounter->"28_TEXT" )
:set ( $parsedArray->$successCounter ) $splitedSms;
:set successCounter ( $successCounter + 1 );
} else={
# splitted sms ( 25_IED1 - id of full, 26_IED2 - parts count, 27_IED3 - current part )
:local smsID ( $arrayStat->$smsCounter->"25_IED1" );
# check if this ID already readed
:local readed false;
:foreach readedID in=$tempReadedSplitedSmsID do={ :if ( $smsID = $readedID ) do={ :set readed true; }; };
:if ( !$readed ) do={
:local partsCountFull [ :tonum ( $arrayStat->$smsCounter->"26_IED2" ) ];
:local partsCountReal 0;
:foreach partOfSms in=$arrayStat do={
:if ( ( $partOfSms->"25_IED1" ) = $smsID ) do={ :set partsCountReal ( $partsCountReal + 1 ); };
:if ( $partsCountFull = $partsCountReal ) do={
# if received all parts of full sms
"19_SCTStime"="";
"TEXT"=""
# read every part from 1
:for partcounter from=1 to=$partsCountFull do={
:if ( ( ( $partOfSms->"25_IED1" ) = $smsID ) and ( [ :tonum ( $partOfSms->"27_IED3" ) ] = $partcounter ) ) do={
:set ( $splitedSms->"19_SCTStime" ) ( $partOfSms->"19_SCTStime" );
:set ( $splitedSms->"TEXT" ) ( ( $splitedSms->"TEXT" ) . ( $arrayStat->$partcounter->"28_TEXT" ) );
} else={
:if ( $partsCountFull < $partsCountReal ) do={
:put "Have duble"
:local uniqueElements [ :toarray "" ]
:if ( ( ( $partOfSms->"25_IED1" ) = $smsID ) and ( [ :tonum ( $partOfSms->"27_IED3" ) ] = $partcounter ) and ([:len ($uniqueElements->( [ :tonum ( $partOfSms->"27_IED3" ) ] ) )] = 0) ) do={
:set ($uniqueElements->( [ :tonum ( $partOfSms->"27_IED3" ) ] ) ) 1
} else={
:put "Need wait"
:set tempReadedSplitedSmsID ( $tempReadedSplitedSmsID , $smsID );
:set smsCounter ( $smsCounter + 1 );
} else={
:put "Need wait"
