Wojdusz
Mikrotik 4011 ethernet 6-10 link down
Thu May 25, 2023 7:31 am
i have problem with my mikrotik 4011rb. everyday my slots eth 6-10 just suddenly drops down ( link down ). I even bought new mikrotik and problem is the same. Can you help me find issue? After reboot it works fine, but after about one day it happens again. I attach log file.
DRAKK
Re: Mikrotik 4011 ethernet 6-10 link down
Fri Nov 10, 2023 5:45 pm
Which version RouterO? I have same problem with 7.11.2 and port 1-5
erlinden
Fri Nov 10, 2023 5:51 pm
Have been running my RB4011 with nearly all versions...never had this problem.
Can you share your config (just to be sure)?
/export file=anynameyoulike
Remove serial and any other private information, and place it in between code tags: </>
Have you tried using a different power supply?
Could it be related to the DHCP offers?
Users browsing this forum: BoraHorza, syadnom and 54 guests
