nichky
{ASK} BGP-def route
Thu May 25, 2023 7:57 am
The topology is very simple
ISP==eBP===R1==ibgp==R2==ibgp==R3==ebgp==CPE
In this implementation i'm expecting R3 to learn default route from R1 via BGP signaling.
i'm providing export of R1 and R3
R2 has the same config with MPLS=ticked and vpn4=ticked
On v6 this is working perfectly fine , unlike v7. Can anyone assist plus?
happy to provide more details if need be
[admin@R1] > interface/list/export
#RouterOS 7.9
add name=list-vrf_cpe-pub
[admin@R1] > routing/bgp/export
# may/25/2023 04:48:34 by RouterOS 7.9
/routing bgp template
add address-families=ip,vpnv4 as=65000 disabled=no name=AS65000 router-id=10.0.88.10 routing-table=main
/routing bgp connection
add address-families=ip as=65000 connect=yes disabled=no listen=yes local.role=ebgp name=bgp-ISP output.network=eBGP remote.address=180.22.11.1/32 .as=1011 router-id=180.22.11.2 \
    routing-table=main templates=AS65000
add address-families=ip,vpnv4 as=65000 connect=yes disabled=no listen=yes local.address=10.0.88.10 .role=ibgp name=bgp-R3 output.default-originate=always remote.address=10.0.88.3/32 .as=65000 \
    router-id=10.0.88.10 routing-table=main templates=AS65000
/routing bgp vpn
add disabled=no export.redistribute=connected,static,bgp .route-targets=150:150 import.route-targets=150:150 label-allocation-policy=per-vrf name=bgp-mpls-vpn-1 route-distinguisher=150:150 \
    vrf=vrf-cpe-pub
[admin@R1] > ip route/print detail  where dst-address=0.0.0.0/0
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn; H - hw-offloaded; + - ecmp
   DAb   dst-address=0.0.0.0/0 routing-table=main gateway=180.22.11.1 immediate-gw=180.22.11.1%ether1 distance=20 scope=40 target-scope=10 suppress-hw-offload=no
 1  As   dst-address=0.0.0.0/0 routing-table=vrf-cpe-pub pref-src="" gateway=180.22.11.1 immediate-gw=180.22.11.1%ether1 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
[admin@R3] > routing/bgp/export
# may/25/2023 04:49:35 by RouterOS 7.9
# software id =
add address-families=ip,l2vpn as=65000 disabled=no name=AS65000 router-id=10.0.88.3
add address-families=ip as=65000 disabled=no name=cpe_public router-id=103.220.80.21 routing-table=vrf-CPE-Public vrf=vrf-CPE-Public
add address-families=ip,vpnv4 as=65000 connect=yes disabled=no listen=yes local.address=10.0.88.3 .role=ibgp name=bgp-R1 nexthop-choice=default remote.address=10.0.88.10/32 .as=65000 \
    router-id=10.0.88.3 routing-table=main templates=AS65000
add address-families=ip as=65000 connect=yes disabled=no listen=yes local.role=ebgp name=bgp-CPE_pub output.default-originate=always remote.address=103.220.80.22/32 .as=100 router-id=\
    103.220.80.21 routing-table=vrf-CPE-Public templates=cpe_public vrf=vrf-CPE-Public
/routing bgp vpn
add disabled=no export.route-targets=150:150 import.route-targets=150:150 label-allocation-policy=per-vrf name=bgp-mpls-vpn-1 route-distinguisher=150:150 vrf=vrf-CPE-Public
[admin@R3] > /ip/route/print where dst-address=0.0.0.0/0
Flags: D - DYNAMIC; A - ACTIVE; b, y - BGP-MPLS-VPN
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS  GATEWAY     DISTANCE
DAb 0.0.0.0/0    10.0.88.10       200
nichky
Re: {ASK} BGP-def route
Thu May 25, 2023 8:15 am
further on that:
i have replaced R1 with v6, just for testing, and yes it does send the default route via BGP signaling to R3 -VRF table
wiseroute
Thu May 25, 2023 8:22 am
hello nichky,
what do you mean by
ebgp==cpe?
which router actually hold the 0/0? r1? r3?
nichky
Thu May 25, 2023 8:32 am
1. eBGP to the client
2. R1
wiseroute
Thu May 25, 2023 8:44 am
aa.. you mean your pe as bgp to ce?
ok. so, from which router this pe has the bgp peering info? directly to rr or just from regular neighbors?
nichky
Thu May 25, 2023 9:05 am
1- yes
2- see the topology
pretty sure that this is not implemented on v7 , but i want someone to confirm them.
wiseroute
Thu May 25, 2023 9:21 am
hello,
2- see the topology
well, i just want to make sure your network topology.
more over i saw that you already made it worked. from the second code.
i don't think i can give you any confirmation about your v7 thoughts since I have left the industry long enough. now I'm just sharing what I used to know with the community
maybe @mrz or others could give some light 👍🏻
spippan
Mon Sep 04, 2023 3:36 pm
is VRF import/export from one VRF to anothet VRF on the same router finally working on rOS v7??
nichky
Mon Sep 04, 2023 8:18 pm
was there any issues, i haven't noticed anything like that
spippan
Mon Sep 04, 2023 9:25 pm
since ros 7.9+ till 7.12b3 BGP VPN (VRF import/export) does not work
if anything of that helps... the routes are not getting propagated among the VRFs/routing tables
[admin@RRZ] > ip vrf export terse
# 2023-09-04 18:18:58 by RouterOS 7.12beta3
# software id =
/ip vrf add interfaces="e1.151(rz),Lo0" name=rz
/ip vrf add interfaces="e1.1113(39390)" name=39390
/ip vrf add interfaces="e1.1125(39496)" name=39496
/ip vrf add interfaces="e1.1128(39510)" name=39510
[admin@RRZ] > rou bg vpn export terse
# 2023-09-04 18:19:37 by RouterOS 7.12beta3
# software id =
/routing bgp vpn add disabled=no export.route-targets=65990:39390 import.route-targets=65990:1,65990:39390 \
 .router-id=39390 label-allocation-policy=per-prefix name=39390 route-distinguisher=65990:39390 vrf=39390
/routing bgp vpn add disabled=no export.route-targets=65990:39496 import.route-targets=65990:1,65990:39496 \
 .router-id=39496 label-allocation-policy=per-prefix name=39496 route-distinguisher=65990:39496 vrf=39496
/routing bgp vpn add disabled=no export.route-targets=65990:39510 import.route-targets=65990:1,65990:39510 \
 .router-id=39510 label-allocation-policy=per-prefix name=39510 route-distinguisher=65990:39510 vrf=39510
/routing bgp vpn add disabled=no export.route-targets=65990:1 import.route-targets=65990:1,65990:39390,65990:39496,65990:39510 \
 .router-id=rz label-allocation-policy=per-prefix name=rz route-distinguisher=65990:1 vrf=rz
[admin@RRZ] > rou rou pri
Flags: A - ACTIVE; c - CONNECT, s - STATIC, d - DHCP; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
DST-ADDRESS               GATEWAY               AFI   DISTANCE  SCOPE  TARGET-SCOPE  IMMEDIATE-GW
Ad  0.0.0.0/0                 192.168.77.1          ip4        111     30            10  192.168.77.1%ether5-mgmt
Ac  192.168.77.0/24           ether5-mgmt           ip4          0     10                ether5-mgmt
Ac  172.16.122.0/29           e1.1125(39496)@39496  ip4          0     10                e1.1125(39496)
Ac  172.16.121.152/29         e1.1128(39510)@39510  ip4          0     10                e1.1128(39510)
As  10.58.2.88/32             e1.1113(39390)@39390  ip4          1     30            10  e1.1113(39390)
Ac  172.16.121.208/29         e1.1113(39390)@39390  ip4          0     10                e1.1113(39390)
As  0.0.0.0/0                 192.168.77.1          ip4          1     30            10  192.168.77.1%ether5-mgmt
Ac  10.58.151.0/24            e1.151(rz)@rz         ip4          0     10                e1.151(rz)
Ac  172.16.105.1/32           Lo0@rz                ip4          0     10                Lo0
Ac  fe80::%ether1-RBGK/64     ether1-RBGK           ip6          0     10                ether1-RBGK
Ac  fe80::%ether2/64          ether2                ip6          0     10                ether2
Ac  fe80::%ether3/64          ether3                ip6          0     10                ether3
Ac  fe80::%ether4/64          ether4                ip6          0     10                ether4
Ac  fe80::%ether5-mgmt/64     ether5-mgmt           ip6          0     10                ether5-mgmt
Ac  fe80::%e1.1125(39496)/64  e1.1125(39496)@39496  ip6          0     10                e1.1125(39496)
Ac  fe80::%e1.1128(39510)/64  e1.1128(39510)@39510  ip6          0     10                e1.1128(39510)
Ac  fe80::%e1.1113(39390)/64  e1.1113(39390)@39390  ip6          0     10                e1.1113(39390)
Ac  fe80::%e1.151(rz)/64      e1.151(rz)@rz         ip6          0     10                e1.151(rz)
Ac  fe80::%Lo0/64             Lo0@rz                ip6          0     10                Lo0
A H ether1-RBGK                                     link         0
A H ether2                                          link         0
A H ether3                                          link         0
A H ether4                                          link         0
A H ether5-mgmt                                     link         0
A H e1.1125(39496)                                  link         0
A H e1.1113(39390)                                  link         0
A H e1.151(rz)                                      link         0
A H Lo0                                             link         0
[admin@RRZ] > ip add pri
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS            NETWORK         INTERFACE
0   172.16.121.209/29  172.16.121.208  e1.1113(39390)
1   172.16.122.1/29    172.16.122.0    e1.1125(39496)
2   172.16.121.153/29  172.16.121.152  e1.1128(39510)
3   10.58.151.3/24     10.58.151.0     e1.151(rz)
4   172.16.105.1/32    172.16.105.1    Lo0
5 D 192.168.77.138/24  192.168.77.0    ether5-mgmt
spippan
Mon Sep 04, 2023 9:33 pm
here the rOS v7.8 in contrast with the same configuration
# sep/04/2023 18:28:37 by RouterOS 7.8
# software id =
# sep/04/2023 18:28:44 by RouterOS 7.8
# software id =
/routing bgp vpn add disabled=no export-route-targets=65990:39390 import-route-targets=65990:1,65990:39390 label-allocation-policy=per-prefix route-distinguisher=65990:3
9390 vrf=39390
/routing bgp vpn add disabled=no export-route-targets=65990:39496 import-route-targets=65990:1,65990:39496 label-allocation-policy=per-prefix route-distinguisher=65990:3
9496 vrf=39496
/routing bgp vpn add disabled=no export-route-targets=65990:39510 import-route-targets=65990:1,65990:39510 label-allocation-policy=per-prefix route-distinguisher=65990:3
9510 vrf=39510
/routing bgp vpn add disabled=no export-route-targets=65990:1 import-route-targets=65990:1,65990:39390,65990:39496,65990:39510 label-allocation-policy=per-prefix route-d
Flags: A - ACTIVE; c, s, d, y, a - SLAAC; H - HW-OFFLOADED
AyH 0.0.0.0/0                      192.168.77.1          ip4          0     30            10
Ay  10.58.151.0/24                 e1.151(rz)@rz         ip4          0     10             5  e1.151(rz)
Ay  172.16.105.1/32                Lo0@rz                ip4          0     10             5  Lo0
Ay  10.58.2.88/32                  e1.1113(39390)@39390  ip4          0     30            10  e1.1113(39390)
Ay  172.16.121.152/29              e1.1128(39510)@39510  ip4          0     10             5  e1.1128(39510)
Ay  172.16.121.208/29              e1.1113(39390)@39390  ip4          0     10             5  e1.1113(39390)
Ay  172.16.122.0/29                e1.1125(39496)@39496  ip4          0     10             5  e1.1125(39496)
Ay  65990:1                        192.168.77.1          vpn4         0     30            10  192.168.77.1%ether5-mgmt
Ay  10.58.151.0/24&65990:1         e1.151(rz)@rz         vpn4         0     10             5  e1.151(rz)
Ay  172.16.105.1/32&65990:1        Lo0@rz                vpn4         0     10             5  Lo0
Ay  10.58.2.88/32&65990:39390      e1.1113(39390)@39390  vpn4         0     30            10  e1.1113(39390)
Ay  172.16.121.208/29&65990:39390  e1.1113(39390)@39390  vpn4         0     10             5  e1.1113(39390)
Ay  172.16.122.0/29&65990:39496    e1.1125(39496)@39496  vpn4         0     10             5  e1.1125(39496)
Ay  172.16.121.152/29&65990:39510  e1.1128(39510)@39510  vpn4         0     10             5  e1.1128(39510)
A H ether2                                               link         0
A H ether3                                               link         0
A H ether4                                               link         0
A H e1.1128(39510)                                       link         0
A H Lo0                                                  link         0
Flags: D - DYNAMIC
Users browsing this forum: alibloke, Bing [Bot] and 125 guests
