Techsystem
How can i do that using Netwatch
Thu May 25, 2023 9:46 am
Hello My friends..!
so here is my scenario:
i want to apply a netwatch rule that goes like this:
if ping to 1.1.1.1 through my VPN router is goes down, i want the router to switch to rule ISP as you see in the picture below.
well my problem is that i couldn't do that..! because i have two internet up connection the router always ping to 1.1.1.1 even if the VPN is down, so i didn't find a way to make my router dedect the VPN failure..!
i try to increase the distance as you see below but also that's didn't work.
i try to make the host 192.168.30.1 -(that represent the VPN router ip)- but also that's didn't work becasue even if the internet is down the ping still up to 192.168.30.1 :-(
so any idea...!?
here is my down rule
routing rule set [ find comment="VPN"] disable=yes
routing rule set [ find comment="ISP"] disable=no
and here is my up rule
routing rule set [ find comment="VPN"] disable=no
routing rule set [ find comment="ISP"] disable=yes
Users browsing this forum: CGGXANNX, faxxe, Google [Bot], jaclaz, mrz, pmcsill, soulflyhigh and 112 guests
