hughrobbie
CCR2216 v7 route table crash
Fri May 26, 2023 10:20 am
Hi Guys,
I wanted to find out if anyone else has had a similar issue on their CCR2216 that does BGP and OSPF:
Issue: From boot after a few hours the route table crashes/hangs (does not update or remove routes), we can't view the route table in Winbox or terminal (hangs in the terminal when you run any command) and the same for bgp settings.
This only started after we upgraded from a CCR1072 v6 to the CCR2216 v7.
We have tested this on many v7 ROS versions up to 7.10
I have attached 2x pictures.
Any feedback from the Mikrotik community would be greatly appreciated.
Regards
Hugh
Users browsing this forum: DanMos79, dsfak, frankyees, jmszuch1, Qanon, Ramirocuei, tnperron, UkRainUa and 168 guests
