camulodunum
any method to get external DNS ip of a local dns?
Sat May 27, 2023 3:44 am
I have my local home network,wich has a server that,with other things,have multiple webpages wich have multiple dns.
since those dns point to my wan IP and wanted to get acces to those webpages from local network (reverse proxy) decided to declare my domains in the mikrotik local dns server.
the problem now is that I have dynamic IP ,so have few scripts to upgrade the IP when needed.
those scripts compare the resolved dns ip to my public IP to send a command to change IP only when needed.
the problems is that,thanks to my local dns changes,now those dns resolves to my local IP and not the true external IP that i need for the comparison.
hairpin is not possible since this involves port 80 and 443 and that will invalidate my access to websites outside the local network.
so there's some way to get the real external IP of my domain that does not implies using mikrotik dns resolver command?
abbio90
Re: any method to get external DNS ip of a local dns?
Tue May 30, 2023 1:14 am
you can enable ip Cloud and fetch the public ip with a script from that field
rextended
Tue May 30, 2023 10:02 am
Just specify the server you want to use for :resolve
example code
:put [:resolve www.example.com] ; # resolved locally
:put [:resolve www.example.com server=1.1.1.1] ; # resolved externally
camulodunum
Wed May 31, 2023 2:05 am
I just found the cloud option a bit earlier today (just lucky,my brain can't understand why a ddns server whould be in ip->cloud section of the interface,but anyway) and enabled it and did it as abbio90 said, but rextended option is much more elegant since don't have to rely on another ddns service,so gonna go with that.
thank you both for the help.
Users browsing this forum: brunolabozzetta, SGBIPL and 27 guests
