Smoerrebroed
Unlock WIFIWAVE2 CAP from CAPsMAN
Sat May 27, 2023 6:16 pm
Quick question: How do I clear the name of the CAPsMAN that a given CAP (WIFIWAVE2) is locked to? In CAPsMAN without WIFIWAVE2 it's as easy as setting lock to disable and then enable it afterwards to be open for a new CAPsMAN. Not so easy with WIFIWAVE2 it seems ...
Smoerrebroed
Re: Unlock WIFIWAVE2 CAP from CAPsMAN
Tue May 30, 2023 3:16 pm
Response from MikroTik support: Apparently it's not possible at this point (ROS 7.9.1), so other than completely resetting cAPs, you can only disable locking and limit CAPsMANs to associate with.
They will look into making this possible.
Smoerrebroed
Wed May 31, 2023 11:08 am
This is an automated message. Our bug tracker reports, that your issue has been fixed. This means that in the upcoming days, we plan to release a RouterOS update with this fix. Make sure to upgrade to the next release when it comes out soon. To be sure this specific fix is included, read the changelog when the next version comes out. If your issue is not mentioned, it might mean it will be in the next release.
:shock:
Smoerrebroed
Mon Jun 26, 2023 11:28 am
Looks like it'll arrive with 7.11. :)
viewtopic.php?t=197277
Users browsing this forum: No registered users and 31 guests
