McKajVah
How to disable 802.11b and slower rates on Wifiwave2?
Sun May 28, 2023 3:02 pm
How does one disable 802.11b and slower rates like 1mbit on wifiwave2 (hAP ax^2 in this case)?
This is from a ax^2 with 2.4GHz ax band enabled under channel config. I can't seem to find any settings related to disabling lower rates and older 802.11b protocol in wifiwave2 settings...
Thanks.
Kaj
maigonis
Re: How to disable 802.11b and slower rates on Wifiwave2?
Sun May 28, 2023 3:26 pm
Thanks.
Kaj
Afaik you cant. I hope it will be added later.
holvoetn
Sun May 28, 2023 3:27 pm
AFAIK b is not supported on AX device. I tested with map, it would not connect. G neither.
But good question. It used to be possible in legacy wifi settings.
So I'll wait as well for the answer :lol:
McKajVah
Sun May 28, 2023 7:43 pm
802.11b is listed in the specs and it's also showing in the Wireshark picture above I shared.
holvoetn
Sun May 28, 2023 7:48 pm
In the output of interface wifiwave2 radio detail I see on AX3, there is no mentioning of B.
G and N yes, but no B.
Users browsing this forum: No registered users and 82 guests
