slimprize
Wi-FI not visible
Sun May 28, 2023 6:13 pm
Hi all,
I am unable to see the wi-fi ssid on any device which I try to connect with my router.
If I connect a LAN cable to the router, it can access the internet without any problems.
The router is connected to another router which is the gateway to the internet.
Why is the wi-fi ssid not visible?
Here is the router configuration.
[admin@MikroTik] > export
# may/28/2023 20:08:31 by RouterOS 7.9.1
# software id = TREE-5IVV
# model = C52iG-5HaxD2HaxD
add name=bridge-lan
/interface wifiwave2 channel
add frequency="5180,5200,5220,5240,5260,5280,5300,5320,5500,5520,5540,5560,5580,5600,5620,5640,5660,5680,5700,5720,574\
5,5765,5785,5805,5825" name=ch-5ghz width=20/40/80mhz
add frequency=2412,2432,2472 name=ch-2ghz width=20mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk encryption=ccmp,gcmp,ccmp-256,gcmp-256 management-protection=allowed name=\
common-auth wps=disable
/interface wifiwave2 configuration
add country=India name=common-conf security=common-auth ssid=Periscope5G
# no supported channels
set [ find default-name=wifi1 ] channel=ch-2ghz configuration=common-conf configuration.mode=ap disabled=no
set [ find default-name=wifi2 ] channel=ch-5ghz configuration=common-conf disabled=no
/port
set 0 name=serial0
add bridge=bridge-lan interface=all
/ip settings
set ip-forward=no
/ipv6 settings
set max-neighbor-entries=15360
/ip dhcp-client
add interface=bridge-lan
/system clock
set time-zone-name=Asia/Kolkata
/system note
set show-at-login=no
Pranav
holvoetn
Re: Wi-FI not visible
Sun May 28, 2023 7:34 pm
In your export is already the remark there are no supported channels for the config you specified, both 2.4 and 5GHz.
So beter fix that first.
It's best to specify yourself which frequency needs to be used. Check your environment for a channel which is not used, or least used.
mkx
Sun May 28, 2023 9:34 pm
Since the requency list for 2GHz band is nothing special and yet wifi1 interface complains that none of channels is supported, check if your device might have 5GHz radio as wifi1 interface (and likewise 2GHz radio as wifi2) ... one can not assume that 2GHz radio will be the first interface and 5GHz radio the second interface.
holvoetn
Sun May 28, 2023 9:42 pm
In ax device wifi 1 = 5GHz.
So yes, that would be wrong.
OP
Best to start with default config.
And then change what you want if you know why and how.
slimprize
Mon May 29, 2023 3:07 am
Hi all,
Thanks for your comments. So, can I reset just the wifi wave 2 configuration and start a fresh?
I prefer using the commandline. I ran the reset command like
reset wifi1 and then reset wifi2
[admin@MikroTik] /interface/wifiwave2> export
# may/29/2023 05:34:57 by RouterOS 7.9.1
What else do I need to do?
Pranav
holvoetn
Mon May 29, 2023 10:47 am
I meant reset of full device.
slimprize
Mon May 29, 2023 2:41 pm
ok, I'll do that and update this thread.
Pranav
slimprize
Mon May 29, 2023 4:39 pm
I have reset the configuration.
I need to setup the router as a wireless access point. I have done this using the following set of commands.
/system reset-configuration no-defaults=yes
Create the bridge
/interface bridge add name=bridge-lan
Add all the interfaces to the bridge
/interface bridge port add bridge=bridge-lan interface=all
Add the dhcp client to the bridge
interface /ip dhcp-client add interface=bridge-lan disabled=no
After the above commands, I will ensure that the administrative user has a strong password.
I am now ready to configure wifi wave 2 since that is the package on the router.
Can anyone suggest a set of basic commands?
Users browsing this forum: No registered users and 52 guests
