mariuszelectro
My router doesn’t auto upgrade
Mon May 29, 2023 12:31 am
Hello. What are wrong in my router configuration.
I can’t upgrade to new software, I got message:
ERROR: could not connect - Host is unreachable
Please take a look in my configuration.
The configuration consists WireGuard VPN for some ports and VLAN.
I am really new. Please help me.
[admin@MT HexS] > export
# may/28/2023 21:48:55 by RouterOS 7.5
# software id = H9MH-TV79
# model = RB760iGS
# serial number = xxxxxxx
add admin-mac=18:FD:74:13:69:EB auto-mac=no comment=defconf name=bridge
add disabled=yes name=openVpn
/interface wireguard
add listen-port=13231 mtu=1420 name=wg1
/interface vlan
add interface=ether5 name=vlan11 vlan-id=11
add interface=ether5 name=vlan12 vlan-id=12
add interface=ether5 name=vlan13OpenVPN vlan-id=13
add interface=ether5 name=vlan55 vlan-id=55
/interface ovpn-client
add add-default-route=yes certificate=AZ24-client.crt_0 cipher=aes128 \
connect-to=xxx.xxx.xxx disabled=yes mac-address=02:BB:FF:8D:1B:69 mode=\
ethernet name=AZserwer user=AZ24-client
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.7.10-192.168.7.254
add name=poolVlan55 ranges=192.168.55.10-192.168.55.60
add name=poolVlan11 ranges=192.168.11.10-192.168.11.60
add name=poolVlan12 ranges=192.168.12.10-192.168.12.60
add name=dhcpOpenVPNvlan13 ranges=192.168.1.6-192.168.1.10
add address-pool=dhcp interface=bridge name=defconf
add address-pool=poolVlan55 disabled=yes interface=vlan55 name=VPN-to-PL
add address-pool=poolVlan12 interface=vlan12 name="MyWALAN K1"
add address-pool=poolVlan11 interface=vlan11 name="Local WiFi"
add address-pool=dhcpOpenVPNvlan13 interface=vlan13OpenVPN name=Guest
/port
set 0 name=serial0
/routing table
add disabled=no fib name=tablWG
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge interface=vlan55
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=xxx.xxx.xxx.xxx endpoint-port=\
13231 interface=wg1 persistent-keepalive=5s public-key=\
"IeQ0yrzJpnlyBRvJC8SGkWgTIze9YcmDs6NAB2QtFQk="
add address=192.168.7.1/24 comment=defconf interface=bridge network=192.168.7.0
add address=172.16.10.3/24 interface=wg1 network=172.16.10.0
add address=192.168.55.1/24 comment=VPN-toPL disabled=yes interface=vlan55 \
network=192.168.55.0
add address=192.168.12.1/24 comment="MyWlLAN K1 do PT" interface=vlan12 \
network=192.168.12.0
add address=192.168.11.1/24 comment="Local WiFI do PT" interface=vlan11 \
network=192.168.11.0
add address=192.168.1.5/24 interface=vlan13OpenVPN network=192.168.1.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.12.50 comment=Podlewaczka mac-address=FC:67:1F:C1:ED:4B \
server="MyWALAN K1"
add address=192.168.1.0/24 comment="addres fo open VPN" gateway=192.168.1.254
add address=192.168.7.0/24 comment=defconf dns-server=8.8.8.8 gateway=\
192.168.7.1 netmask=24
add address=192.168.11.0/24 gateway=192.168.11.1 netmask=24
add address=192.168.12.0/24 gateway=192.168.12.1 netmask=24
add address=192.168.55.0/24 gateway=192.168.55.1 netmask=24
set allow-remote-requests=yes servers=192.168.7.1
/ip dns static
add address=192.168.7.1 comment=defconf name=router.lan
add address=8.8.8.8 name=Google
add address=192.168.1.254 name=Az
established,related,untracked
invalid
add action=accept chain=input comment="allow LAN access" in-interface-list=LAN
add action=accept chain=input comment="allow wg acces for config" in-interface=\
wg1
add action=drop chain=input comment="drop all else"
add action=accept chain=forward comment="allow internet traffic" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat connection-state=""
add action=accept chain=forward comment="WG for net" dst-address=192.168.7.0/24 \
in-interface=wg1 src-address=192.168.1.0/24
add action=accept chain=forward dst-address=192.168.1.0/24 out-interface=wg1 \
src-address=192.168.7.0/24
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add disabled=no distance=2 dst-address=192.168.1.0/24 gateway=wg1 pref-src=\
0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wg1 pref-src="" \
routing-table=tablWG scope=30 suppress-hw-offload=no target-scope=10
add comment="dla OpenVPN" disabled=no dst-address=0.0.0.0/0 gateway=\
192.168.1.254 routing-table=main suppress-hw-offload=no vrf-interface=\
AZserwer
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/routing rule
add action=lookup disabled=no dst-address=192.168.7.0/24 table=main
add action=lookup-only-in-table disabled=no src-address=192.168.7.0/24 table=\
tablWG
/system clock
set time-zone-name=Europe/Lisbon
/system identity
set name="MT HexS"
/system scheduler
add name=startSkyptu on-event="/system script run zigbeeCheck" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-time=startup
/system script
add dont-require-permissions=no name=zigbeeCheck owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":gl\
obal i 0;\
\n:global k 1;\
\n:global x 0;\
\n:log info (\"Zigbee monitor start\");\
\n:delay 300s;\
\n:do {\
\n:if ([/ip dhcp-server lease find where active-mac-address=\"D8:1F:12:22:AC\
:42\"] != \"\" ) do={:set x (\$x+1)} else { \
\n:log info (\"rest Zigbee \" . \$i );\
\n:log info (\" time\" . \$x);\
\n:set i (\$i+1);\
\n/system routerboard usb power-reset duration=60s;\
\n:log info (\"USB power up\" );\
\n:delay 300s;\
\n}\
\n:delay 60s;\
\n:set (\$k+1);\
\n:if ( \$k>600 ) do={\
\n:set (\$k=0);\
\n:log info (\"Zigbee Stat \" . \$i);\
\n:log info (\" time \". \$x);\
\n}\
\n} while (1);"
/tool mac-server
/tool mac-server mac-winbox
[admin@MT HexS] >
holvoetn
Re: My router doesn’t auto upgrade
Mon May 29, 2023 1:06 am
When I see that message on a new device when trying to upgrade, I know I goofed (usually) with DNS settings.
Also your wireguard peer settings indicate all traffic go through the wireguard tunnel. Which means probably there is an issue there as well.
So I'd look in the DNS area first.
Perhaps disable wireguard peer first and then perform upgrade ?
You can enable it again afterwards.
rextended
Mon May 29, 2023 3:16 am
Nice, the router ask itself what is the IP of update.mikrotik.com...
And the ruoter ask itself...
mariuszelectro
Tue May 30, 2023 12:56 am
Thanks for responce.
ip address
Was defined in my configuration,
Setting was missing.
But it look like my router was strange behaviour…… no upgrade and lost 60% ping packets in WireGuard peer. So after reset was able take upgrade without any changes in settings, and no lost ping packets in WireGuard
Anyway the missing settings about dns was added.
Users browsing this forum: akakua, Amazon [Bot], Bing [Bot], che, unhuzpt and 62 guests
