own3r1138
Long time Member
Long time Member
Asking for scripting assistance - DoH Healthcheck
Mon May 29, 2023 1:48 am
I want to create a service health check script that monitors my DoHs. I couldn't get it done with my poor scripting skill.
I surely appreciate any help.
Original script
:log info "DNS HealthCheck Started"
:local currentDNS [/ip dns get use-doh-server]
:local DoHMain "https://record.domain-A.tld/dns-query"
:local DoHSec "https://record.domain-B.tld/dns-query"
:local TDomain "www.domain.tld"
:if ($currentDNS =$DoHMain) do={
    :do {
        :resolve $TDomain
    } on-error={
        /ip dns set use-doh-server=$DoHSec
		:log info message="DOH Server=$DoHSec"
:delay 180s
else={
    :do {
        /ip dns set use-doh-server=$DoHMain
        :resolve $TDomain
            :log info message="DOH Server=$DoHMain""
    } on-error={
:log info "DNS HealthCheck Done"
rextended
Re: Asking for scripting assistance - DoH Healthcheck
Mon May 29, 2023 3:10 am
Why you simply do not use the "original script" linked?
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 3:17 am
Hi, It doesn't work with DoH. :(
This command doesn't exist. :roll:
:put [resolve www.domain.tld use-doh-server="server" ]
rextended
Mon May 29, 2023 3:19 am
Mmm.... let me think.... (or better, let me search the post I already wrote...)
rextended
Mon May 29, 2023 3:21 am
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 4:40 am
I tried the final script, but it didn't work even with the default request record of www.example.com.
How should I encode the requested record? I have tried several online Base64url encoders, none of which worked with the error status "400 bad requests".
PS C:\Users\user> echo 'www.example.com' | openssl base64
d3d3LmV4YW1wbGUuY29tDQo=
PS C:\Users\user> echo -n 'AAABAAABAAAAAAAAA3d3dwdleGFtcGxlA2NvbQAAAQAB' | openssl base64 --decode
base64: Unknown cipher: decode
base64: Use -help for summary.
904E0000:error:0308010C:digital envelope routines:inner_evp_generic_fetch:unsupported:crypto\evp\evp_fetch.c:341:Global default library context, Algorithm (decode : 0), Properties (<null>)
:local dohServers {"https://record.domain.tld/dns-query";"https://record.domain.tld/dns-query";"https://record.domain.tld/dns-query"}
:local dohServerAvailable false
:foreach dohServer in=$dohServers do={
 :if ($dohServerAvailable=false) do={
  :local result yes
  :do {/tool fetch url="$dohServer\?dns=AAABAAABAAAAAAAAA3d3dwdleGFtcGxlA2NvbQAAAQAB" output=none dst-path=result http-header-field=accept:application/dns-message} on-error={:set result no}
  :if $result do={
   :if ([/ip dns get use-doh-server] != $dohServer) do={
    /ip dns set servers="" use-doh-server="$dohServer" verify-doh-cert=yes;
    :log warning "DNS over HTTPS => $dohServer"
   :set dohServerAvailable true
:if ( $dohServerAvailable = false) do={
  /ip dns set servers="1.1.1.1,8.8.8.8,1.0.0.1,8.8.4.4" use-doh-server="";
  :log warning "DNS over HTTPS switched off!"
rextended
Mon May 29, 2023 5:37 am
I can't test your own DoH server.
If is not configured correctly for support RFC 8484 like google or cloudflare, I can not help you...
About the base64... is not www.example.com converted on base64, but is the query on RFC 8484 format.....
Is written clearly, read more carefully
viewtopic.php?p=977576#p977769
The AAABAAABAAAAAAAAA3d3dwdleGFtcGxlA2NvbQAAAQAB is base64 encoded DNS query for A record of www.example.com
\00\00\01\00\00\01\00\00\00\00\00\00\03www\07example\03com\00\00\01\00\01
Use something that works ;)
viewtopic.php?p=989112#p989112
terminal code
[] > :global test [$base64dec "AAABAAABAAAAAAAAA3d3dwdleGFtcGxlA2NvbQAAAQAB"]
[] > /system script environment
[] /system script environment> print
 # NAME               VALUE
 0 base64dec          ;(eval / […]
 1 test               \00\00\01\00\00\01\00\00\00\00\00\00\03www\07example\03com\00\00\01\00\01
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 5:55 am
Okay, I will keep the default one for now. Can you check the functionality of the script? My DOH is an Adguard-home container. It responded to the default record in the terminal.
Well, thank you. I'm reading the viewtopic.php?p=977576#p977769 right now.
What are these [] in the value?
I can't understand how to construct my request record. :D
rextended
Re: Asking for scripting assistance - DoH Healthcheck  [SOLVED]
Mon May 29, 2023 11:02 am
(you use parameters from $str2base64 instead of the appropriate for $base64dec, "url" and "nopad" must not be used on DNS query)
the [] (really are not [ and ] but a special character that represent unprintable characters) are presents
because NULL 0x00, SOH 0x01 and other special characters really are hex values of the DNS query following RFC 8484.
For compose your own string, replace the value in this:
+ length of the next part on hex \03
+ next part "www"
+ length of the next part on hex \07
+ next part "example"
+ next part "com"
\00\00\01\00\01
for example for smtp.mypreferreddonmain.cloud = 4 + 18 (0x12) + 5
\00\00\01\00\00\01\00\00\00\00\00\00\04smtp\12mypreferreddonmain\05cloud\00\00\01\00\01
and for encode it:
viewtopic.php?p=988931#p988931
terminal code
[] > :put [$str2base64 ("\00\00\01\00\00\01\00\00\00\00\00\00\04smtp\12mypreferreddonmain\05cloud\00\00\01\00\01")]
AAABAAABAAAAAAAABHNtdHASbXlwcmVmZXJyZWRkb25tYWluBWNsb3VkAAABAAE=
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 2:21 pm
Thank you, Finally.
:put [$str2base64 ("\00\00\01\00\00\01\00\00\00\00\00\00\03wwww\07example\03com\00\00\01\00\01") "nopad"]
AAABAAABAAAAAAAAA3d3d3cHZXhhbXBsZQNjb20AAAEAAQ
:put [$str2base64 ("\00\00\01\00\00\01\00\00\00\00\00\00\03wwww\06google\03com\00\00\01\00\01") "nopad"]
AAABAAABAAAAAAAAA3d3dwZnb29nbGUDY29tAAABAAE
:put [$str2base64 ("\00\00\01\00\00\01\00\00\00\00\00\00\03www\06google\03com\00\00\01\00\01") "nopad"]
/tool fetch url="https://record.domain.tdl/dns-query\?dns=AAABAAABAAAAAAAAA3d3dwZnb29nbGUDY29tAAABAAE" output=user dst-pat
      status: finished
  downloaded: 0KiBC-z pause]
        data: ��wwwgooglecom�
                                    {��i�
                                             {��c�
                                                      {��g�
        {��h�
        {��j
Again @extended rescued me. <3
rextended
Mon May 29, 2023 2:25 pm
Thank you, Finally.
yes 8)
keskol
Wed Jan 10, 2024 12:17 pm
Hi @own3r1138 , could you please post your working script? This is exactly what I am trying to set up now as well and am failing at the check if doh works script part.
I am not using the certificate verification in my case
Thanks!
own3r1138
Long time Member
Long time Member
Wed Jan 10, 2024 5:31 pm
Script
:local dohServers {"https://record-a.domain.tld/dns-query";"https://record-b.domain.tld/dns-query";"https://record-c.domain.tld/dns-query";"https://record-d.domain.tld/dns-query"}
 :local resultDoH true
 :do {tool fetch url="$dohServer\?dns=AAABAAABAAAAAAAAA3d3dwZnb29nbGUDY29tAAABAAE" output=none dst-path=result http-header-field=accept:application/dns-message} on-error={:set resultDoH false}
  :if $resultDoH do={
   :log warning "The DoH server changed to $dohServer."
Users browsing this forum: abbio90 and 76 guests
