jibanes
Dynamic Firewall Address-List
Mon May 29, 2023 4:29 am
I have an interface on my router, ether1, which runs a dhcp client, and my ISP assigns it a public ip address, here 33.44.55.66.
I have a Firewall Address list that looks like this:
/ip firewall address-list
add address=33.44.55.66 list=unexpected-src-address-hitting-ISP
This address-list is used in a few places, one of them is to block traffic coming FROM "my" IP@ provided by my ISP.
Is it possible to have this address-list entry automatically updated, in the event ether1 gets a new ip address from my ISP?
I'm running 7.9.1
thank you for looking!
own3r1138
Long time Member
Long time Member
Re: Dynamic Firewall Address-List  [SOLVED]
Mon May 29, 2023 5:38 am
Enable the DDNS and use the record as an entry in your address list.
/ip cloud set ddns-enabled=yes
add address=33445566.sn.mynetname.net list="unexpected-src-address-hitting-ISP"
jibanes
Mon May 29, 2023 6:06 am
QQ: How frequently are the firewall rules refreshed, meaning, I doubt the dns lookup happens everytime, how long is it cached for?
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 6:56 am
Check the cached record ttl.
jibanes
Mon May 29, 2023 7:09 am
thanks, looks like 1mn here.
nichky
Mon May 29, 2023 7:18 am
pretty sure that by default is not specificated
jibanes
Mon May 29, 2023 7:46 am
Maybe /ip/cloud set ddns-update-interval=1m ?
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 8:41 am
Perhaps you could also use a script if the IP address changes too frequently. You can set an interval as you like.
:local currentIP [/ip dhcp-client get [find interface=ether1] value-name=address]
add address=$currentIP list="unexpected-src-address-hitting-ISP"
jibanes
Mon May 29, 2023 5:53 pm
In which case you would also have to remove the old one?
How do you set the crontab?
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 6:24 pm
Sorry, my mistake. I didn't think about this part.
/system scheduler add name=ip-list interval=00:00:15 on-event="script-name OR simply paste the below script"
/ip firewall address-list set [find where list="unexpected-src-address-hitting-ISP"] address=$currentIP
jibanes
Mon May 29, 2023 6:27 pm
I am not sure this would work because I have a lot of entries with the name "unexpected-src-address-hitting-ISP", they include things like rfc1918 ranges, etc.
One possibility is to add another Firewall Raw rule associated to a new name?
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 6:33 pm
Can you separate the list=name?
Because I can not create more complex scripts. :D W8 on that. :d
I rather not mess with your firewall. I don't feel comfortable enough for that.
You need to set a unique comment for this entry in your list=unexpected-src-address-hitting-ISP.
/ip firewall address-list set [find where comment="dhcp-client-address"] address=$currentIP
jibanes
Mon May 29, 2023 6:45 pm
I just set another name it works great, many thanks!
own3r1138
Long time Member
Long time Member
Mon May 29, 2023 6:49 pm
Good, you're welcome.
Users browsing this forum: Bing [Bot], fritzme, rsvrww, VirtualEvan and 63 guests
