sandi
WAN doesn't failover when it can no longer ping gateway. (check-gateway=ping with recursive routing)
Mon May 29, 2023 5:24 pm
Hi all! This is our first MikroTik box and I'm having trouble getting dual wan with DHCP working...
I have a dual WAN setup using two DHCP clients and recursive routing (see config below) . When I physically remove the cable from the main WAN the device fails over to the secondary WAN as expected. However if I sever the connection further down in the chain so the link is still up but the gateway can no longer be pinged, it doesn't failover. What am I doing wrong? Thanks for the help!
(Running v6.48.7)
Full config below...
# may/28/2023 18:16:01 by RouterOS 6.48.7
add name=bridge1-LAN
set [ find default-name=ether1 ] name=ether1-WAN1
set [ find default-name=ether2 ] name=ether2-WAN2
set [ find default-name=ether12 ] name=ether12-Other
add name=WAN
add name=LAN
add name=dhcp ranges=x.x.1.180-x.x.1.254
add address-pool=dhcp disabled=no interface=bridge1-LAN name=dhcp1
add bridge=bridge1-LAN interface=ether3
add bridge=bridge1-LAN interface=ether4
add bridge=bridge1-LAN interface=ether5
add bridge=bridge1-LAN interface=ether6
add bridge=bridge1-LAN interface=ether7
add bridge=bridge1-LAN interface=ether8
add bridge=bridge1-LAN interface=ether9
add bridge=bridge1-LAN interface=ether10
add bridge=bridge1-LAN interface=ether11
set enabled=yes
/ip settings
set tcp-syncookies=yes
add interface=bridge1-LAN list=LAN
add interface=ether1-WAN1 list=WAN
add interface=ether2-WAN2 list=WAN
add address=x.x.1.1/24 interface=bridge1-LAN network=x.x.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add add-default-route=no disabled=no interface=ether1-WAN1 script="if (\$bound\
    =1) do={ \\\r\
    \n/ip route set [find comment=\"VERIZON CF\"] distance=1 dst-address=1.1.1\
    .1/32 gateway=\$\"gateway-address\" scope=10\r\
    \n/ip route set [find comment=\"VERIZON GOOGLE\"] distance=1 dst-address=8\
    .8.8.8/32 gateway=\$\"gateway-address\" scope=10\r\
    \n}" use-peer-dns=no use-peer-ntp=no
add add-default-route=no disabled=no interface=ether2-WAN2 script="if (\$bound\
    =1) do={ \\\r\
    \n/ip route set [find comment=\"COMCAST-NAT CF\"] distance=2 dst-address=1\
    .0.0.1/32 gateway=\$\"gateway-address\" scope=10\r\
    \n/ip route set [find comment=\"COMCAST-NAT GOOGLE\"] distance=2 dst-addre\
    ss=8.8.4.4/32 gateway=\$\"gateway-address\" scope=10\r\
add check-gateway=ping comment="VERIZON DEFAULT CF" distance=1 gateway=\
    1.1.1.1
add check-gateway=ping comment="VERIZON DEFAULT GOOGLE" distance=1 gateway=\
    8.8.8.8
add check-gateway=ping comment="COMCAST-NAT ALT CF" distance=2 gateway=\
    1.0.0.1
add check-gateway=ping comment="COMCAST-NAT ALT GOOGLE" distance=2 gateway=\
    8.8.4.4
add comment="COMCAST-NAT CF" distance=2 dst-address=1.0.0.1/32 gateway=\
    x.x.0.1 scope=10
add comment="VERIZON CF" distance=1 dst-address=1.1.1.1/32 gateway=\
    x.x.x.1 scope=10
add comment="COMCAST-NAT GOOGLE" distance=2 dst-address=8.8.4.4/32 gateway=\
    x.x.0.1 scope=10
add comment="VERIZON GOOGLE" distance=1 dst-address=8.8.8.8/32 gateway=\
    x.x.x.1 scope=10
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
add address=x.x.1.0/24 gateway=x.x.1.1 netmask=24
set allow-remote-requests=yes servers=9.9.9.11,149.112.112.11
/ip firewall address-list
add address=x.x.1.2-x.x.1.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add address=0.0.0.0/8 comment="defconf: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=\
    bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=\
    bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=\
    bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=\
    not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ip firewall raw
add action=accept chain=prerouting comment="defconf: accept DHCP discover" \
    dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=\
    udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting dst-address-list=ddos-targets \
    src-address-list=ddos-attackers
add action=drop chain=prerouting comment="defconf: drop bogon IP's" \
    src-address-list=bad_ipv4
    dst-address-list=bad_ipv4
    src-address-list=bad_src_ipv4
    dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" \
    in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment=\
    "defconf: drop forward to local lan from WAN" dst-address=x.x.1.0/24 \
    "defconf: drop local if not from default IP range" in-interface-list=LAN \
    src-address=!x.x.1.0/24
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 \
    protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" \
    jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" \
    jump-target=bad_tcp protocol=tcp
add action=accept chain=prerouting comment=\
    "defconf: accept everything else from LAN" in-interface-list=LAN
    "defconf: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp \
    tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0 \
    protocol=tcp
add action=accept chain=icmp4 comment="defconf: echo reply" icmp-options=0:0 \
    limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" \
    icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 comment="defconf: host unreachable" \
    icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 comment="defconf: protocol unreachable" \
    icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" \
    icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" \
    icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo" icmp-options=8:0 limit=\
add action=accept chain=icmp4 comment="defconf: time exceeded " icmp-options=\
    11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" protocol=icmp
/lcd
set color-scheme=dark default-screen=stats
/system clock
set time-zone-name=America/New_York
/system identity
set name=RouterOS
/system package update
set channel=long-term
/system ups
add name="Network UPS" port=usbhid1
/tool bandwidth-server
set enabled=no
** Note: gateway addresses are obscured with "x.x" for public posting, they are proper addresses in the config.
sindy
Re: WAN doesn't failover when it can no longer ping gateway. (check-gateway=ping with recursive routing)
Sun Jun 04, 2023 10:27 pm
I cannot see anything wrong in your recursive routing setup, so first imitate the outage of the Verizon uplink and after 20 seconds, check whether the default routes via Verizon are still marked as Active. If they are, there is indeed something wrong with the setup. If they are not, maybe your expectations or the way you test the failover are incorrect?
E.g. if you test using a continous ping, it will fail once the primary uplink becomes unavailable even though the route via Comcast becomes active. The reason is the NAT - the first ping request creates a tracked connection that is src-nated to the IP address of the Verizon WAN, and the packets belonging to that connection keep being src-nated to that IP address even after they start being routed via Comcast. So either Comcast drops them because they come from a wrong address, or it lets them through but the responses are sent to the Verizon IP address which is not accessible. UDP connections like SIP or IPsec are affected by the same phenomenon if they are reattempted before the timeout for responded UDP connections (3 minutes by default) expires. So if you use such kind of connections, you need to add scheduled scripts that remove tracked connections whose reply-dst-address is the one of the unavailable uplink.
anav
Sun Jun 04, 2023 11:27 pm
I dont understand the purpose of your DHCP client script, It would appear perhaps to find the gateway IP??? My take is its doing too much and interfering with the recursive routing.
Forget the distance parameter as you want the dhcp client info to be found in both cases and the gateway to be found in both cases. Let the IP routes decide which route will be used.
Secondly not particularly fond of the recursive setup you have. Try it this way.....
add check-gateway=ping distance=3 dst-address=0.0.0.0/0 gateway=1.1.1.1 scope=10 target-scope=12
add distance=3 dst-address=1.1.1.1/32 gateway=Primary_ISP-gatewayIP scope=10 target-scope=11
add check-gateway=ping distance=4 dst-address=0.0.0.0/0 gateway=8.8.8.8 scope=10 target-scope=12
add distance=4 dst-address=8.8.8.8/32 gateway=Primary_ISP-gatewayIP scope=10 target-scope=11
add check-gateway=ping distance=5 dst-address=0.0.0.0/0 gateway=1.0.0.1 scope=10 target-scope=12
add distance=5 dst-address=1.0.0.1/32 gateway=SECONDARY_ISP-gatewayIP scope=10 target-scope=11
add check-gateway=ping distance=6 dst-address=0.0.0.0/0 gateway=8.8.4.4 scope=10 target-scope=12
add distance=6 dst-address=8.8.4.4/32 gateway=SECONDARY_ISP-gatewayIP scope=10 target-scope=11
Here is the script I use to ascertain gateway and then stick that into my IP ROUTES at the appropriate spot.
Add default route=YES, route distance=255
:if ($bound=1) do={
:local iface $interface
:local gw [ /ip dhcp-client get [ find interface=$"iface" ] gateway ]
/ip route set [ find comment="PrimaryRecursive" gateway!=$gw ] gateway=$gw
/ip route set [ find comment="SecondaryRecursive" gateway!=$gw ] gateway=$gw
The trick here is to use the comments on each of the routes. In my case I only use this for one ISP, with two recursive routes.
You would have something similar but in both IP DHCP Clients.
Here are my routes so you can see how the key words were used (in comments): Note this is from vers6, so no need to mess with scopes................
add check-gateway=ping distance=3 gateway=1.0.0.1
add check-gateway=ping distance=4 gateway=9.9.9.9
add comment=PrimaryRecursive distance=3 dst-address=1.0.0.1/32 gateway=..4.1 scope=10
add comment=SecondaryRecursive distance=4 dst-address=9.9.9.9/32 gateway=..4.1 scope=10
Thus in your case, it may be applied as follows
add distance=3 dst-address=1.1.1.1/32 gateway=Primary_ISP-gatewayIP scope=10 target-scope=11 comment=MainRC-V
add distance=4 dst-address=8.8.8.8/32 gateway=Primary_ISP-gatewayIP scope=10 target-scope=11 comment=AlternativeRC-V
add distance=5 dst-address=1.0.0.1/32 gateway=SECONDARY_ISP-gatewayIP scope=10 target-scope=11 comment=MainRC-H
add distance=6 dst-address=8.8.4.4/32 gateway=SECONDARY_ISP-gatewayIP scope=10 target-scope=11 comment=AlternativeRC-H
Verizon
:if ($bound=1) do={
/ip route set [ find comment="MainRC-V" gateway!=$gw ] gateway=$gw
/ip route set [ find comment="AlternativeRC-V" gateway!=$gw ] gateway=$gw
Horizon
:if ($bound=1) do={
/ip route set [ find comment="MainRC-H" gateway!=$gw ] gateway=$gw
/ip route set [ find comment="AlternativeRC-H" gateway!=$gw ] gateway=$gw
Users browsing this forum: patg, quezhou, vagrik and 206 guests
