DimebagDarrell
routeros-powerpc-7.9.1.npk missing, use ignore-missing or disable package(s)
Tue May 30, 2023 12:21 am
Hi, my RB1100AHx2 does not allow to download the update packages from v6 to v7. How is this solved? Also, is v7 already stable for that device model? Is it recommended to update to this version?
/system package update check-for-updates
            channel: upgrade
  installed-version: 6.49.8
     latest-version: 7.9.1
             status: New version is available
/system package update download
            channel: upgrade
             status: routeros-powerpc-7.9.1.npk missing, use ignore-missing or disable package(s)
normis
Re: routeros-powerpc-7.9.1.npk missing, use ignore-missing or disable package(s)
Tue May 30, 2023 8:59 am
Just use this file, copy into the router and reboot it with the reboot command:
https://download.mikrotik.com/routeros/ ... .1-ppc.npk
Yes, it's stable.
Users browsing this forum: baragoon, Bing [Bot], BoraHorza, Jetstream and 204 guests
