markom
RBwAPG-60adkit ROS6 or ROS7 ?
Tue May 30, 2023 10:29 am
does someone have experience with RBwAPG-60adkit performance and good or bad behavior with ROS 6 and ROS 7?
Should I stick to 6 or upgrade to 7?
once I install RBwAPG-60adkit on the top of the buildings I have no wishes to go on the roof again to change ROS upgrade or downgrade.
Rox169
Re: RBwAPG-60adkit ROS6 or ROS7 ?
Tue May 30, 2023 12:22 pm
upgrade to 7.10 there is bix fix for 60Ghz. Do not use on those devices ROS6 many bugs....
holvoetn
Tue May 30, 2023 1:40 pm
If you make sure your ethernet cable is accessible from downstairs, there is no need to climb up or down.
Users browsing this forum: davidvanrensburg and 118 guests
