deanMK
Android TV box dont get DHCP from hAP AX3
Wed May 31, 2023 8:43 am
Hi people
I have obe weird problem that cant fix myself even read too many threads here on mikrotik forum.
I use LAN 4 via cable to connect my Android TV box. When connect the box for first time it get connection and all works fine. But after i turn off my box and dont use it for some time, on another power on it dont get IP adress from DHCP Server. Read on forums and found this viewtopic.php?t=97755 and found the same situation that happens to me. Tryed almost everything, and as "solution" that read there buyed basic 100mbps switch from tp-link just to resolve this. But today power on the box again and same issue. Into the box settings Write that box get adress 192.168.88.25 but into Leases i dont see device associated with that IP.
And conf from Android box
So current connection is Hapax3- tplink100mbps switch - Android TV box. Router have RoS 7.8 stable
Some help here?
EDIT: Set Fixed IP from Mikrotik DHCP pool. But after lease expires, the box dont have internet and lease stuck at "waithing". Some help here?
deanMK
Re: Android TV box dont get DHCP from hAP AX3
Thu Jun 01, 2023 12:03 am
Someone to help here? Its really frustrating why Android Box dont renew lease in time. Tryed to set lower value in lease time, but after expiring, it dont renew again, until plug off the cable and pull on again from switch.
k6ccc
Thu Jun 01, 2023 12:19 am
Sounds strange. However without your configuration, we would be guessing. Please post your configuration.
To export and paste your configuration (and I'm assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) "/export hide-sensitive file=any-filename-you-wish". Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
Frederick88
Thu Jun 01, 2023 4:30 am
Could be a case of cheap Android trash?
To help eliminate some possibilities,
Have you tried removing TP-Link switch from the equation and connect directly to MT?
Have you tried disconnecting connection from TV and connect to another device, such as laptop. Does it experience same issue?
Amm0
Thu Jun 01, 2023 8:21 am
Try changing the lease-time setting in the DHCP server to 00:30:00 (or 30m). It's possible the Android box doesn't like the short lease time.
Also, under DHCP Server > Networks set the netmask for your network to 24 (or what your subnet CIDR is) – even though it's already specified in the DHCP network address= line. I've seen some devices need that set for some unknown reason (e.g. it should be inferred from the address, but not always it seems)
deanMK
Thu Jun 01, 2023 11:39 am
1. Yes i tryed first without switch, Android Box get IP just a first time, and works until box is power ON. When i power OFF, and power ON after some time, it dont get IP from DHCP anymore.
2. Yes other devices works normaly. Its brand new hAP AX3 old just one week.
https://androidpctv.com/review-mecool-m8s-pro-l/ is the Android TV Box i use.
Here is it:
# jun/01/2023 10:41:22 by RouterOS 7.8
# software id = MGL0-4L4W
# model = C53UiG+5HPaxD2HPaxD
# serial number = removed-private
add admin-mac=48:A9:8A:BA:EF:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-5G \
    disabled=no security.authentication-types=wpa-psk,wpa2-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20mhz configuration.mode=ap .ssid=MikroTik-2G disabled=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add disabled=no fib name=WAN1
add disabled=no fib name=WAN2
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=defconf interface=WAN1 list=WAN
    192.168.88.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=30m
/ip dhcp-client
add add-default-route=no comment=defconf interface=WAN1
add add-default-route=no interface=WAN2
/ip dhcp-server lease
add address=192.168.88.12 client-id=1:9c:14:63:7e:91:95 mac-address=\
    9C:14:63:7E:91:XX server=defconf
add address=192.168.88.25 client-id=1:d0:76:58:10:60:d5 lease-time=5m \
    mac-address=D0:76:58:10:60:XX server=defconf
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
add action=accept chain=input dst-port=8291 protocol=tcp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=\
    bridge
add action=accept chain=prerouting dst-address=192.168.99.0/24 in-interface=\
    bridge
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=yes
    in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=yes
    dst-address-type=!local in-interface=bridge new-connection-mark=WAN1_conn \
    passthrough=yes per-connection-classifier=both-addresses:2/0
    dst-address-type=!local in-interface=bridge new-connection-mark=WAN2_conn \
    passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=bridge new-routing-mark=WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=bridge new-routing-mark=WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.1.1 pref-src="" routing-table=WAN1 scope=30 suppress-hw-offload=\
    no target-scope=10
    192.168.99.1 pref-src="" routing-table=WAN2 scope=30 suppress-hw-offload=\
    no target-scope=10
    no target-scope=11
    no target-scope=11
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Skopje
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.europe.pool.ntp.org
add address=1.europe.pool.ntp.org
/tool mac-server
192.168.88.25 is fixed IP for Android TV box i set.
Set 30 min lease time just for that static IP adress 192.168.88.25 . No need to set 30 min lease time for entire DHCP server.
and this is after Android Box is powered ON. Still stuck on waiting status
deanMK
Thu Jun 01, 2023 1:21 pm
@Amm0 after 30 mins. Box dont renew the lease and status still stuck on "waiting". Box is connected directly to MTK.
Also noticed this. Why box get IPv6 ? when box connect successfully ipv6 is not shown there.
Amm0
Thu Jun 01, 2023 5:38 pm
The IPv6 fe80::/64 is what's called the link local address. Basically same as a 169.254.0.0/16 address that happens in IPv4 without DHCP. So that's unrelated.
Did you try setting the netmask in the DHCP Server to "24" instead of blank? Not sure that fix, but has help with DHCP in past for me.
Also, you might want to add "dhcp" as a topic for memory log in /system/logging. And perhaps shorten the lease-time to 5m so you can see more transitions in the logs. It seem like it gets the address but the acknowledgement packet is either not sent or recieved or not updated in RouterOS.
You can also try just deleting the client-id in the reservations and see if it then registers.
deanMK
Thu Jun 01, 2023 10:25 pm
You meen on this netmask?
Set it to "24" and set lease time for that Fixed IP instead of setting of entire pool. Lets see what will happens.
Kentzo
Long time Member
Long time Member
Fri Jun 02, 2023 12:32 am
You may also try Torch (Tools -> Torch) to see whether TV tries to renew its lease:
deanMK
Fri Jun 02, 2023 9:08 am
@Amm0 tryed with netmask 24 and removing the device id. Not getting IP when lease is expiring. Other tip?
Amm0
Fri Jun 02, 2023 6:30 pm
If your not running latest stable, perhap try that.
I guess you can delete the reservation, and let it get dynamically assigned again. Then reassign it as a static after that.
Only other thing is as suggested logging, packet traces, or maybe torch. It appears like the AndroidTV box gets an address, but something not happen to cause to be tracked as such. Certainly could be a bug, someplace, but only logs/traces help to know.
deanMK
Fri Jun 02, 2023 9:25 pm
Really weird. Until device is power ON, it renew the lease automatically. Problem is when turn OFF, and after some time turn ON again. Then not get lease from DHCP automatically. Only way to back into online state is to unplug/plug the RJ45 connector from box.
deanMK
Sat Jun 17, 2023 3:05 pm
Resolved this by replacing with another Android TV box with gigabyte LAN port. No issues so far with connection after wake up from sleap. All works smoothly.
Users browsing this forum: No registered users and 39 guests
