own3r1138
Long time Member
Long time Member
Tunnel broker API script
Wed May 31, 2023 5:59 pm
I welcome any suggestions to improve the script.
:local  IPv6 "true"
:local APIurl "https://USER:TOKEN@ipv4.tunnelbroker.net/nic/update?hostname=TUNNEL-ID&myip="
:global WANInterface "PPPOE"
:local previousIP ""
:local WANip ""
:local ipN ""
:local APIn
:local APIu
:set $APIn "true"
:set $APIu "true"
:if ($IPv6 = "true") do={
    :local currentIP ([/interface pppoe-client monitor [find name=$WANInterface] once as-value]->"local-address")
    :set WANip $currentIP
    :set  ipN $currentIP
:if ([/file find name=disk/db/tb.tmp.txt] = "") do={
    :log error "No previous ip address file found, createing..."
    :set previousIP $WANip
    :execute script=":put $WANip" file="/disk/db/tb.tmp"
    #:error message="No previous ip address file found."
    :log warning ("TB API: Updating, please wait! Setting = $WANip")
    :do {/tool fetch output=none url="$APIurl$WANip"} on-error={
     :log error "IPv6: API is down!"
     :set $APIn "false"
:if ($APIn=true) do={
:log warning ("TB API: $WANip IP address seted.")
:set $APIn true
} else={
    :if ( [/file get [/file find name=disk/db/tb.tmp.txt] size] > 0 ) do={
    :global content [/file get [/file find name="disk/db/tb.tmp.txt"] contents]
    :global contentLen [ :len $content ] ;
    :global lineEnd 0
    :global line "";
    :global lastEnd 0
            :set lineEnd [:find $content "\n" $lastEnd ]
            :set line [:pick $content $lastEnd $lineEnd]
            :set lastEnd ( $lineEnd + 1 )
            :if ( [:pick $line 0 1] != "#" ) do={
                #:local previousIP [:pick $line 0 $lineEnd ]
                :set previousIP [:pick $line 0 $lineEnd ];
                :set previousIP [:pick $previousIP 0 [:find $previousIP "\r"]]
:if ($previousIP != $WANip) do={
    :set $APIu false
:if ($APIu=true) do={
    :log warning ("TB API: $WANip IP address updated.")
    /ip dns cache flush
        /file remove disk/db/tb.tmp.txt
  :set $APIu true
own3r1138
Long time Member
Long time Member
Re: Tunnel broker API script
Wed May 31, 2023 7:09 pm
I can NOT delete this.
Users browsing this forum: No registered users and 7 guests
