tspascoal
CAP AX mount distance between holes
Wed May 31, 2023 11:48 pm
An odd question, I know.
But I intend to buy a cAP ax ceiling mount but want to have the holes drilled before that (since a have a person here drilling some holes for installing a bunch of CAP AC (those ones I have already :))) I will take the opportunity to drill for the AX in advance).
But I can't find what is the distance between the screw holes for cAP ax ceiling mount
I have looked at the mounting instructions (https://i.mt.lv/cdn/product_files/cAPax ... 230526.pdf) but it has no dimensions.
Can someone point me to the distance between the 2 holes?
Thank you
holvoetn
Re: CAP AX mount distance between holes
Wed May 31, 2023 11:56 pm
The plastic mounting bracket ?
3.4 cm
(yeah, I need to clean the lens...)
tspascoal
Thu Jun 01, 2023 12:02 am
3.4 cm
Awesome. Thank you for the quick reply
Users browsing this forum: adwlodaro, Majestic-12 [Bot], unhuzpt and 115 guests
