stevester
Why isn't macvlan support a priority for MikroTik?
Thu Jun 01, 2023 1:39 am
There are multiple requests on here for this feature, but apparently it's not even on their development timeline. I find this puzzling given the number of use-cases, and this being a standard in Linux for some time. Not to mention the fact that most if not all of their major competitors offer this feature.
Anyone have any insight as to why they are not pursuing it?
Amm0
Re: Why isn't macvlan support a priority for MikroTik?
Thu Jun 01, 2023 2:20 am
Well, IMO VETH covers the need for containers (aka Docker) and VXLAN is the more standard way of using L2 over IP nowadays.
DarkNate
Fri Jun 02, 2023 1:42 pm
Who in their right mind uses macvlan in 2023?
VXLAN/EVPN/MPLS/SR?
stevester
Fri Jul 07, 2023 9:16 pm
VXLAN/EVPN/MPLS/SR?
If you search the forums, a common use case such as mine is where for some ISP's you need to present a second mac address to get a second public IP. Hence the usefulness of macvlan. There are other uses still too that are relevant. It's also worth noting that the other router OS's out there generally support it.
Larsa
Fri Jul 07, 2023 11:13 pm
In the meantime you might try this vrrp hack
Btw, virtual network devices (veth) could possibly be implemented using Linux Network Namespaces in the current kernel.
Amm0
Thu Aug 24, 2023 5:11 pm
FWIW, I just saw MACVLAN interfaces were added in the v7.12beta3. No docs or anything, but was in RN.
Larsa
Thu Aug 24, 2023 7:48 pm
tried using the CLI yet?
Amm0
Thu Aug 24, 2023 8:04 pm
I'm still not sure the use cases...just read and saw in winbox/cli:
/interface/macvlan/add <tab>
arp             comment       disabled         loop-protect-disable-time      mac-address     name
arp-timeout     copy-from     loop-protect     loop-protect-send-interval     mode            parent
Larsa
Thu Aug 24, 2023 8:49 pm
I'll check if I can find an MT box to play with at home. Our current ISP/CO can offer 4 IP addresses over the same cable using the media converter XG6846, but requires a distinct MAC addresse for each one.
stevester
Sun Aug 27, 2023 6:46 pm
Macvlan is working great! No need anymore for the VRRP hack, I can get multiple public IP's via dhcp from my ISP with this now.
Larsa
Sun Aug 27, 2023 9:57 pm
Great! I haven't had time to try it yet so It would be nice if you could share a sample config using export.
ToTheCLI
Tue Aug 29, 2023 1:53 pm
What's the difference between private and bridge modes?
Larsa
Mon Sep 04, 2023 7:58 pm
Has anyone gotten this to work yet using 7.12?
arainbow
Tue Sep 05, 2023 10:32 am
I have to say that macvlan is very useful, I am very happy to have this feature. But when I add another VLAN on the macvlan interface, the router restarts immediately.
rplant
Long time Member
Long time Member
Wed Sep 06, 2023 2:23 pm
Adding a macVlan onto eth1 of a hex PoE seems to work, however fastrack only seems to work in 1 direction.
From router towards upstream ok, downstream does not get fasttracked.
Larsa
Wed Sep 06, 2023 3:33 pm
Could you please share an export of just the MACVLAN config?
rplant
Long time Member
Long time Member
Thu Sep 07, 2023 3:09 am
/interface macvlan
add mac-address=CC:2D:E0:68:xx:xx name=ether1.macvlan1 parent=ether1
also
/ip dhcp-client
add add-default-route=no interface=ether1.macvlan1
Then on dhcp server I give it an alternate IP address.
add address=192.168.92.20 client-id=1:cc:2d:e0:68:xx:xx \
mac-address=CC:2D:E0:68:xx:xx server=defconf
add address=192.168.92.0/24
