tech172
VRF and failover
Thu Jun 01, 2023 10:34 am
Hi everyone !
I'm using a Hex Mikrotik Router. I'm pretty new on this field but I'm trying my best to make it work.
Here's what I wanted to do : Use 2 differents WANs for 2 LANs but the WANs have the same gateway and I can't change it. So I decided to use VRFs to fix this issue which worked (My 1st VRF has WAN1 and Bridge1 and the 2nd has WAN2 and Bridge2). But now I want to make a failover between my 2 VRFs.
How can I make a route between the two VRF so it can use the other WAN if it needs to ?
The gateways of the 2 WANs are 192.168.1.1
Bridge1 is 192.168.88.1
Bridge2 is 192.168.89.1
Here's my actual configuration :
# may/30/2023 13:56:23 by RouterOS 7.9.1
# software id = ZLYE-A3CY
# model = RB750Gr3
# serial number = 6F3807EAD74A
add admin-mac=64:D1:54:0A:94:C1 auto-mac=no comment=1 name=bridge-1
add comment=2 name=bridge-2
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=pool-1 ranges=192.168.88.10-192.168.88.254
add name=pool-2 ranges=192.168.89.10-192.168.89.254
add address-pool=pool-1 interface=bridge-1 name=DHCP-1
add address-pool=pool-2 interface=bridge-2 name=DHCP-2 server-address=\
    192.168.89.1
/ip vrf
add interfaces=ether2,bridge-2 name=vrf2
add interfaces=ether1,bridge-1 name=vrf1
/port
set 0 name=serial0
add bridge=bridge-1 comment=bridge-1 interface=ether3
add bridge=bridge-2 comment=bridge-2 interface=ether5
add bridge=bridge-1 interface=ether4
add comment=defconf interface=bridge-1 list=LAN
add interface=bridge-2 list=LAN
add interface=ether2 list=WAN
add address=192.168.88.1/24 comment="Bridge 1" interface=bridge-1 network=\
    192.168.88.0
add address=192.168.89.1/24 comment="Bridge 2" interface=bridge-2 network=\
    192.168.89.0
/ip dhcp-client
add comment="WAN 1" interface=ether1
add comment="WAN 2" interface=ether2 use-peer-dns=no use-peer-ntp=no
add address=192.168.88.0/24 comment="Bridge 1" dns-server=8.8.8.8,8.8.4.4 \
    gateway=192.168.88.1
add address=192.168.89.0/24 comment="Bridge 2" dns-server=8.8.8.8,8.8.4.4 \
    gateway=192.168.89.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=output disabled=yes dst-address=1.1.1.1 \
    new-connection-mark=test1111 passthrough=yes protocol=icmp
add action=mark-routing chain=prerouting connection-mark=test1111 disabled=\
    yes new-routing-mark=vrf2 passthrough=yes
add action=mark-routing chain=prerouting in-interface=bridge-1 \
    new-routing-mark=main passthrough=yes
add action=passthrough chain=prerouting dst-address=0.0.0.0/0 routing-mark=\
    main
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1@vrf1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.1.1@vrf2 \
    target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=yes down-script="" host=8.8.8.8 http-codes="" interval=10s \
    test-script="" type=simple up-script=""
add disabled=yes down-script="" host=1.1.1.1 http-codes="" test-script="" \
If you need more informations, feel free to ask.
mrz
Re: VRF and failover  [SOLVED]
Thu Jun 01, 2023 10:26 pm
you can set gateway to be resolved in another vrf x.x.x.x@vrf
More info with examples are in the manual
https://help.mikrotik.com/docs/pages/vi ... getreemode
Users browsing this forum: flyr, NetHorror, Renfrew and 101 guests
