AlexPebody
Can't upgrade Firmware
Thu Jun 01, 2023 4:32 pm
Hello. Some troubles with upgrading to 7.9.1 (I upgraded with Netinstall manually) and now to 7.9.2 too. Mikrotik 4011 with WiFi, just reboot and nothing, the same version Firmware... What can I do and why can it be? Thanks.
rextended
Re: Can't upgrade Firmware
Thu Jun 01, 2023 4:41 pm
Current RouterBOOT version? (firmware) ?
The logs just after the reboot?
What method you use for upgrade?
I do not see any space or memory problem...
AlexPebody
Thu Jun 01, 2023 4:51 pm
I am using default, select packages and stable channel and find upgrade and download and upgrade...
 20:43:17 system,info router rebooted
 20:43:20 interface,info WireGuard link up
 20:43:21 l2tp,ppp,info FastestVPN1: initializing...
 20:43:21 l2tp,ppp,info FastestVPN1: connecting...
 20:43:21 l2tp,ppp,info FastestVPN1: terminating... - could not resolve name
 20:43:21 l2tp,ppp,info FastestVPN1: disconnected
 20:43:23 l2tp,ppp,info FastestVPN1: initializing...
 20:43:23 l2tp,ppp,info FastestVPN1: connecting...
 20:43:23 l2tp,ppp,info FastestVPN1: terminating... - could not resolve name
 20:43:23 l2tp,ppp,info FastestVPN1: disconnected
 20:43:26 l2tp,ppp,info FastestVPN1: initializing...
 20:43:26 l2tp,ppp,info FastestVPN1: connecting...
 20:43:26 l2tp,ppp,info FastestVPN1: terminating... - could not resolve name
 20:43:26 l2tp,ppp,info FastestVPN1: disconnected
 20:43:30 bridge,info hardware offloading activated on bridge "LAN_bridge" ports: ether2,ether3,ether4
 20:43:30 caps,info WiFi_2-RB4011-1: selected channel 2442/20-Ce/gn(15dBm) (fixed)
 20:43:32 poe-out,info ether10 detected poe-out status: on
 20:43:33 l2tp,ppp,info FastestVPN1: initializing...
 20:43:33 interface,info ISP1 link up (speed 1G, full duplex)
 20:43:33 interface,info ether2 link up (speed 1G, full duplex)
 20:43:33 interface,info ether3 link up (speed 1G, full duplex)
 20:43:33 l2tp,ppp,info FastestVPN1: connecting...
 20:43:33 l2tp,ppp,info FastestVPN1: terminating... - could not resolve name
 20:43:33 bridge,info hardware offloading activated on bridge "LAN_bridge" ports: ether5,ether6,ether7,ether8,ether9,ether10
 20:43:33 interface,info ether6 link up (speed 1G, full duplex)
 20:43:33 l2tp,ppp,info FastestVPN1: disconnected
 20:43:33 interface,info ether9 link up (speed 1G, full duplex)
 20:43:36 caps,info WiFi_5-RB4011-1: selected channel 5200/20-eCeeeeee/ac/P(20dBm) (fixed)
 20:43:43 l2tp,ppp,info FastestVPN1: initializing...
 20:43:43 l2tp,ppp,info FastestVPN1: connecting...
 20:43:44 interface,info ether10 link up (speed 1G, full duplex)
 20:43:46 dhcp,info LAN_dhcp deassigned 192.168.1.226 for BC:DF:C2:23:93:75 ESP_239375
 20:43:46 dhcp,info LAN_dhcp assigned 192.168.1.226 for BC:DF:C2:23:93:75 ESP_239375
 20:43:48 dhcp,info LAN_dhcp deassigned 192.168.1.216 for 70:88:76:DB:45:C1
 20:43:48 dhcp,info LAN_dhcp assigned 192.168.1.216 for 70:88:76:DB:45:C1
 20:43:50 dhcp,info LAN_dhcp deassigned 192.168.1.227 for 52:FD:20:0E:50:3E Aqara
 20:43:50 dhcp,info LAN_dhcp assigned 192.168.1.227 for 52:FD:20:0E:50:3E Aqara
 20:43:50 dhcp,info LAN_dhcp deassigned 192.168.1.223 for E8:20:F2:92:06:24 webtlo
 20:43:50 dhcp,info LAN_dhcp assigned 192.168.1.223 for E8:20:F2:92:06:24 webtlo
 20:44:28 system,critical,info ntp change time Jun/01/2023 20:43:52 => Jun/01/2023 20:44:28
 20:44:28 dhcp,info LAN_dhcp deassigned 192.168.1.125 for 00:10:32:DB:59:F1 APS
 20:44:28 dhcp,info LAN_dhcp assigned 192.168.1.125 for 00:10:32:DB:59:F1 APS
 20:44:29 dhcp,info LAN_dhcp deassigned 192.168.1.214 for B8:81:6E:39:0A:F6 yandex-station-lite
 20:44:29 dhcp,info LAN_dhcp assigned 192.168.1.214 for B8:81:6E:39:0A:F6 yandex-station-lite
 20:44:34 system,info,account user alex logged in from 192.168.1.225 via winbox
 20:44:36 interface,info ether10 link down
 20:44:50 interface,info ether10 link up (speed 1G, full duplex)
 20:45:03 caps,info [::FDff:192.168.1.150:34209,Join,[C4:AA:34:AA:F6:6D]] joined, provides radio(s): C4:AA:34:AA:F6:6F,C4:AA:34:AA:F6:70
 20:45:04 caps,info WiFi_2-cAPac-1: selected channel 2422/20-Ce/gn(15dBm) (fixed)
 20:45:04 bridge,info "GUEST_bridge" mac address changed to C6:AA:34:AA:F6:6F
 20:45:04 caps,info WiFi_5-cAPac-1: selected channel 5300/20-eeCe/ac/P(20dBm) (fixed)
 20:45:50 system,info,account user alex logged in from 192.168.1.225 via local
rextended
Thu Jun 01, 2023 4:55 pm
You try with drag&drop file & reboot, or only with system package update?
AlexPebody
Thu Jun 01, 2023 4:56 pm
rextended
Re: Can't upgrade Firmware  [SOLVED]
Thu Jun 01, 2023 4:57 pm
Try with this:
https://download.mikrotik.com/routeros/ ... .2-arm.npk
without any windows open, drag&drop the file inside winbox, and reeboot.
If this upgrade after reboot, probably something corrupt update file on direct download from winbox/webfig
AlexPebody
Thu Jun 01, 2023 5:03 pm
Try with this:
Thx! Yes it works for me. Strange, why I can't upgrade default method twice... ( something corrupted from 7.9.1 FW?
rextended
Thu Jun 01, 2023 5:06 pm
I deduced from the logs, probably the RouterBOARD doesn't use the VPN (or annoys it) compared to the other devices on the network...
AlexPebody
Thu Jun 01, 2023 5:08 pm
Yes I thinked about it... Will try next time! See ya and thx!
rextended
Thu Jun 01, 2023 5:09 pm
PLEASE,
try this on terminal and see what is inside the test.txt file, and if is downloaded of the right size...
/tool fetch ur="https://download.mikrotik.com/routeros/7.9.2/routeros-7.9.2-arm.npk" dst-path="/test.txt"
AlexPebody
Thu Jun 01, 2023 5:11 pm
PLEASE,
All is ok as I see.
rextended
Thu Jun 01, 2023 5:13 pm
Can you have the patience to zip the file and put it on forum? (on attachments section of the new post)
I want compare what your routerboard download and the correct file on the mikrotik site.
Thanks.
Or, better, if you can already do, please compare on binary way the two files for see if is present any difference....
AlexPebody
Thu Jun 01, 2023 5:20 pm
I want compare what your routerboard downoad and the correct file on the mikrotik site.
Thanks.
Yes sure, here is URL: https://drive.google.com/file/d/1DBAYM- ... sp=sharing
But MD5 is the same.
rextended
Thu Jun 01, 2023 5:23 pm
Thanks, better than I expect ;)
Ok, the problem is clear: RouterOS upgrade procedure, not the file download section...
AlexPebody
Thu Jun 01, 2023 5:25 pm
Ok, the problem is clear: RouterOS, not the file download section...
Yeah, maybe something with boot and VPN issues... Maybe, I try with another upgrade ver.
Users browsing this forum: Bing [Bot], darkusas, Semrush [Bot] and 42 guests
