cpg
RouterOS 7.9.2 x86 disk issue
Fri Jun 02, 2023 1:46 am
I am running RouterOS x86 in a VirtualBox VM. The storage controller is AHCI (SATA).
Since upgrading RouterOS from 7.8 to 7.9.2, after every reboot a new entry appears in the Disk List.
Initially it was:
/disk
set slot1 slot=slot1 type=hardware
After reboot it has two:
/disk
set slot2 slot=slot2 type=hardware
After another reboot:
/disk
set slot3 slot=slot3 type=hardware
In RouterOS 7.8 there is no /disk in the exported configuration.
In the disk list in WinBox I see only 1 entry which has Slot: sata1.
cpg
Re: RouterOS 7.9.2 x86 disk issue
Fri Jun 16, 2023 3:56 am
The same issue is present in 7.10 stable.
That's expected since there is nothing disk related in the changelog.
holvoetn
Fri Jun 16, 2023 11:54 am
Best to contact support about it with supout.rif so they can check why it happens.
cpg
Wed Nov 15, 2023 7:50 pm
I just want to mention that the issue is still present in RouterOS 7.12 Stable.
The same issue happens in both VirtualBox and VMware.
After every reboot a new disk appears in /disk and they build up.
Thanks for the suggestion to contact the MikroTik support, however I don't think I'm eligible for such.
I have a couple of hardware MikroTik routers, but for the VMs I use demo keys.
holvoetn
Wed Nov 15, 2023 8:45 pm
Why not ?
A reported bug is a reported bug. Doesn't matter where it comes from.
Yuanandyuan
Sat Feb 10, 2024 4:06 am
I found Routeros keeps adding disk slots for dvd drive or sd card drive even they are empy. So remove the DVD drive in vmware will fix your issue.
cpg
Mon Feb 12, 2024 10:59 pm
Wow, thank you, that's a great find!
It fixes the issue indeed and I needed the DVD only for the initial installation anyway.
Users browsing this forum: Google [Bot], holla29, jaclaz, JeffreyAxori, markinhusxp and 191 guests
