Rohllik28
Getting into a loop when using multiple "trunk" ports
Fri Jun 02, 2023 11:54 am
I have a RoaS (MT router, switch some better L3 TP-link) and I'm trying to set up some basic VLANs. I followed the procedure on our goldstandard see viewtopic.php?f=13&t=143620
a) one "base_vlan" which has .1 on the router and .2 on the switches to communicate with each other on L3. The rest of the VLANs are simply over L2.
b) I have all the ports except the WAN on one bridge.
c) In "/interface bridge vlan" I have all VLANs tagged on the selected trunk ports and bridge.
d) The bridge is on "admit only tagged" and VLAN Filtering is enabled.
Now to the problem. As long as I only have one trunk port active (either physically connected UTP or disabled ifc on the router), everything works as I would expect. But when I turn on the other trunk port, the ping starts to double and after a few minutes, errors start popping up in the log for both trunks
"ether10: bridge port received packet with own address as source address (e4:8d:8c:a9:3a:e5), probably loop".
Before I started using VLAN filtering, turning on the second trunk kicked me off the router completely.
I know that I could get by with one trunk with such a small network, but my point is that I'm obviously setting something wrong and it can lead to other problems, so I want to fix it...plus it's making me angry ;)
The config is exported in a defective state and only the most basic stuff is in it.
add admin-mac=E4:8D:8C:A9:3A:E5 auto-mac=no comment=defconf frame-types=admit-only-vlan-tagged name=\
    bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan5 vlan-id=5
add interface=bridge name=vlan99 vlan-id=99
add interface=bridge name=vlan200 vlan-id=200
add name=dhcp_pool0 ranges=192.168.5.100-192.168.5.254
add name=dhcp_pool1 ranges=192.168.99.100-192.168.99.254
add name=dhcp_pool2 ranges=192.168.20.100-192.168.20.254
add address-pool=dhcp_pool0 disabled=no interface=vlan5 name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=vlan99 name=dhcp2
add address-pool=dhcp_pool2 disabled=no interface=vlan200 name=dhcp3
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=ether10 trusted=yes
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=sfp1 trusted=yes
add bridge=bridge tagged=ether10,sfp1,bridge vlan-ids=5
add bridge=bridge tagged=ether10,sfp1,bridge vlan-ids=99
add bridge=bridge tagged=ether10,sfp1,bridge vlan-ids=200
add address=192.168.5.1/24 interface=vlan5 network=192.168.5.0
add address=192.168.99.1/24 interface=vlan99 network=192.168.99.0
add address=192.168.20.1/24 interface=vlan200 network=192.168.20.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.5.0/24 gateway=192.168.5.1
add address=192.168.20.0/24 gateway=192.168.20.1
add address=192.168.99.0/24 gateway=192.168.99.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
tdw
Re: Getting into a loop when using multiple "trunk" ports
Fri Jun 02, 2023 2:46 pm
You can't just connect multiple links between a pair of devices, as you have found this leads to loops and broadcast storms swamping the network.
You can aggregate multiple physical links into a single virtual link and use this as the trunk. See https://help.mikrotik.com/docs/display/ROS/Bonding
Rohllik28
Fri Jun 02, 2023 4:04 pm
Ok, thanks for the reply, it makes sense that way. Anyway, does that mean the article is wrong? It says that all physical ports are on one bridge and serve as a trunk, and at the same time (according to the article) all VLANs are supposed to be on the same bridge - no mention of bonding. In the config it reads as follows
add bridge=BR1 tagged=BR1,ether2,ether3,ether4,ether5,ether6,ether7,sfp1 vlan-ids=10
add bridge=BR1 tagged=BR1,ether2,ether3,ether4,ether5,ether6,ether7,sfp1 vlan-ids=20
/interface vlan add interface=BR1 name=BLUE_VLAN vlan-id=10
/interface vlan add interface=BR1 name=GREEN_VLAN vlan-id=20
what am I missing?
And one offtopic question, because I can't find a clear answer, and that's just about the number of trunks. In my small network - max 4 VLANs and max around 50 network devices running at any one time, do I need more than one trunk?
k6ccc
Fri Jun 02, 2023 5:07 pm
That entirely depends on traffic. I'm weird and have six switches on my extended home network. The very least is around 10 VLANs and most are closer to two dozen VLANs. Most are running a single 1 Gig electrical connection between switches. There are something close to 100 devices connected at any given time. The only time any of the trunks are at or near capacity is when I am backup up my file server in the data cabinet to an external drive plugged into the family room computer.
Users browsing this forum: bdivrik, jaclaz, viacheslav1988, yan and 197 guests
