Rox169
Which POE switch is better?
Mon Jun 05, 2023 11:00 am
I can not make my mind to chose from those two POE swtiched. Which is please better? Which on would you chose?
Cloud Smart Switch CSS610-8P-2S+IN
https://mikrotik.com/product/css610_8p_2s_in
vs
MikroTik CRS112-8P-4S-IN
https://mikrotik.com/product/crs112_8p_4s_in
pcunite
Re: Which POE switch is better?
Tue Jun 06, 2023 12:35 am
The hardware is better on the CSS610, the software is better on the CRS112.
holvoetn
Tue Jun 06, 2023 8:42 am
Take note of the added comment on CRS112:
CRS112-8P-4S-IN can power 802.3af/at devices if 48-57 V DC input is used
But that power input is a separate purchase. Default it comes with 24V power adapter.
There is secondary DC jack on the back of the enclosure that supports 48-57 V power supply (not included, can be purchased separately - product codes 48POW (1.46A 70W) and 48V2A96W (2A 96W))
Ca6ko
Tue Jun 06, 2023 10:36 am
You didn't provide any criteria to choose from.
1. Number of devices, connection ports.
2. required POE standards, characteristics of the equipment to be connected
3. bandwidth requirements.
gotsprings
Sun Jun 11, 2023 2:48 pm
Users browsing this forum: Mosmos and 8 guests
