JRJakkals
L2TP Server Setup with LTE\DMZ
Mon Jun 05, 2023 3:05 pm
Hello Everybody
I need help. I have setup the following.
1. LTE Internet Router with DMZ
2. Mikrotik with L2TP Server
Test
1. Internet is working
2. Test VPN locally working using Windows VPN client
Problem
L2TP client doesnt want to connect from internet
Amm0
Re: L2TP Server Setup with LTE\DMZ
Mon Jun 05, 2023 7:33 pm
The router's DMZ feature isn't going to help if the LTE connection uses a CGNAT (which is typically for consumer LTE SIMs). You can check this by seeing if the LTE router is getting a private address (10.x, 192.x) or 100.64.0.0-100.127.255.255 from the LTE WAN connection.
rextended
Mon Jun 05, 2023 7:35 pm
(or 172.16......)
JRJakkals
Mon Jun 05, 2023 7:40 pm
LTE Router is getting public(WAN) IP address, internet is working....
Amm0
Mon Jun 05, 2023 7:53 pm
Is there a way to enable "passthrough" on your LTE router so the Mikrotik get the public IP?
Otherwise, your Mikrotik config looks pretty standard/correct at first glance, so looks like issue may be how the DMZ works on the Huawei...
Amm0
Mon Jun 05, 2023 7:57 pm
Also, don't know if you're running V7, but if LTE is a real public IP, you might want to try Wireguard. That might work better with the DMZ since Wiregard just needs one port through to work, not the complex dance the L2TP/IPSec needs. If the Mikrotik is ARM or ARM64, ZeroTier be another option that get you Layer2/Ethernet like L2TP.
JRJakkals
Mon Jun 05, 2023 8:01 pm
# jun/05/2023 13:46:03 by RouterOS 6.49.8
# software id = 5W3V-FDGK
# model = RB941-2nD
# serial number = HD7087BDQZT
add admin-mac=18:FD:74:BA:A0:36 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country="south africa" disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=Office wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key= \
wpa2-pre-shared-key=
add name=dhcp ranges=192.168.1.20-192.168.1.199
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE dns-server=192.168.1.1 local-address=192.168.89.1 \
remote-address=vpn
add bridge=bridge comment=defconf interface=pwr-line1
/interface l2tp-server server
set enabled=yes ipsec-secret= one-session-per-host=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=192.168.8.5/24 interface=ether1 network=192.168.8.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
add distance=1 gateway=192.168.8.1
/ppp secret
add name=vpn password= profile=default-encryption service=l2tp
add name=jaco password= profile=default-encryption service=l2tp
add name=mari password= profile=default-encryption service=l2tp
add name=mariette password= profile=default-encryption service=l2tp
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
# jun/05/2023 14:00:56 by RouterOS 6.49.8
# model = RB941-2nD
protocol=udp
invalid
192.168.89.0/24
JRJakkals
Mon Jun 05, 2023 9:41 pm
Maybe I explained wrong. Mikrotik is getting public IP. DMZ is pushing internet traffic to Mikrotik...
Amm0
Mon Jun 05, 2023 9:49 pm
Ah, so the public IP is coming via DHCP client on ether1...
In that case, I'd change your /ip route to use a distance=2, so the DHCP one with a public is one used for outbound traffic. Otherwise, it will load balance (ECMP) between using the public IP and 192.168.8.5 as the src address to LTE...
e.g. /ip route add distance=1 gateway=192.168.8.1
should be
/ip route add distance=2 gateway=192.168.8.1
JRJakkals
Re: L2TP Server Setup with LTE\DMZ  [SOLVED]
Tue Jun 06, 2023 11:47 am
I have resolved the problem
Telkom Incoming Ports blocked - use 'unrestricted' APN
https://mybroadband.co.za/forum/threads ... 185/page-3
https://archie22is.medium.com/how-to-se ... 34ef53af00
Users browsing this forum: Amazon [Bot], Bing [Bot], kobuki, rkau045, TheCat12 and 29 guests
