wintech2003
BGP filters from v6 -> v7 high CPU
Mon Jun 05, 2023 8:08 pm
I recently switched from a CCR1036 running RouterOS 6, to a CCR2004 running ROS v7.8
On RouterOS 6 I used the following filters to reject bogons from eBGP peers in an IXP:
add action=discard chain=own-prefix_discard_IPv4 prefix=[my_prefix]/24 prefix-length=24-32
add action=discard chain=rfc5735_discard_IPv4 prefix=0.0.0.0/8 prefix-length=8-32
add action=discard chain=rfc5735_discard_IPv4 prefix=10.0.0.0/8 prefix-length=8-32
add action=discard chain=rfc5735_discard_IPv4 prefix=100.64.0.0/10 prefix-length=10-32
add action=discard chain=rfc5735_discard_IPv4 prefix=127.0.0.0/8 prefix-length=8-32
add action=discard chain=rfc5735_discard_IPv4 prefix=169.254.0.0/16 prefix-length=16-32
add action=discard chain=rfc5735_discard_IPv4 prefix=172.16.0.0/12 prefix-length=12-32
add action=discard chain=rfc5735_discard_IPv4 prefix=192.0.0.0/24 prefix-length=24-32
add action=discard chain=rfc5735_discard_IPv4 prefix=192.0.2.0/24 prefix-length=24-32
add action=discard chain=rfc5735_discard_IPv4 prefix=192.88.99.0/24 prefix-length=24-32
add action=discard chain=rfc5735_discard_IPv4 prefix=192.168.0.0/16 prefix-length=16-32
add action=discard chain=rfc5735_discard_IPv4 prefix=198.18.0.0/15 prefix-length=15-32
add action=discard chain=rfc5735_discard_IPv4 prefix=198.51.0.0/24 prefix-length=24-32
add action=discard chain=rfc5735_discard_IPv4 prefix=203.0.113.0/24 prefix-length=24-32
add action=discard chain=rfc5735_discard_IPv4 prefix=224.0.0.0/4 prefix-length=4-32
add action=discard chain=rfc5735_discard_IPv4 prefix=240.0.0.0/4 prefix-length=4-32
add action=discard chain=PEER_IPv4_IN prefix=0.0.0.0/0
add action=jump chain=PEER_IPv4_IN jump-target=own-prefix_discard_IPv4
add action=jump chain=PEER_IPv4_IN jump-target=rfc5735_discard_IPv4
add action=accept chain=PEER_IPv4_IN set-bgp-local-pref=150
In ROS7 I used a similar approach, first reject the default router, then my own prefix and bogons and finally accept everything else. The bogons filter looks like this:
if (dst in 0.0.0.0/8 && dst-len in 8-32) {
    reject;
if (dst in 10.0.0.0/8 && dst-len in 8-32) {
    reject;
if (dst in 100.64.0.0/10 && dst-len in 10-32) {
    reject;
if (dst in 127.0.0.0/8 && dst-len in 8-32) {
    reject;
if (dst in 169.254.0.0/16 && dst-len in 16-32) {
    reject;
if (dst in 172.16.0.0/12 && dst-len in 12-32) {
    reject;
if (dst in 192.0.0.0/24 && dst-len in 24-32) {
    reject;
if (dst in 192.0.2.0/24 && dst-len in 24-32) {
    reject;
if (dst in 192.88.99.0/24 && dst-len in 24-32) {
    reject;
if (dst in 192.168.0.0/16 && dst-len in 16-32) {
    reject;
if (dst in 198.18.0.0/15 && dst-len in 15-32) {
    reject;
if (dst in 198.51.0.0/24 && dst-len in 24-32) {
    reject;
if (dst in 203.0.113.0/24 && dst-len in 24-32) {
    reject;
if (dst in 224.0.0.0/4 && dst-len in 4-32) {
    reject;
if (dst in 240.0.0.0/4 && dst-len in 4-32) {
    reject;
Unfortunately, applying the above into the filter chain, increases CPU very much. From ~20% without this filter to 60-80%.
The above is with one transit (default route only) and one IXP; traffic levels are 200-300Mbps.
I've gotten various tips on how to optimize this:
- drop bogons with raw firewall
- put all prefixes in address lists and change it to a single "if (dst in [address_list]) { reject; }" but the documentation says that this will only match the exact prefix
- blackhole bogon prefixes using the Cymru full bogons feed
So I have two questions:
1) Why is this happening? I practically copied the same logic that was working perfectly fine in ros6 to ros7, and get a huge increase in CPU load. Is this expected or could it be a bug?
2) What is the recommended way to go for an edge router? As a principle I try to avoid using firewall on the edges, but I'm open to suggestions.
Thanks,
George
wiseroute
Re: BGP filters from v6 -> v7 high CPU
Tue Jun 06, 2023 8:29 am
hello George,
maybe @ mrz can help you with this
but for this one,
it is obvious that the high cpu usage maybe came from your suboptimal ix peering (to crowded)?
as for v6 to v7 different cpu utilization - maybe @ mrz could give you an insight.
if you really need to migrate to v7 - maybe you could lab it first, and try to find the performance bottleneck point - before going live.
just a thought 🤔
Users browsing this forum: No registered users and 55 guests
