pthunya
Trainer
Trainer
Anyone got terminal within Winbox immediately disconnected when connect Winbox with MAC Address?
Mon Jun 05, 2023 9:13 pm
When I'm opened terminal within Winbox it's disconnected immediately as screenshot, it's happened when connect Winbox with MAC address.
How to avoid this problem?
Thank you.
holvoetn
Re: Anyone got terminal within Winbox immediately disconnected when connect Winbox with MAC Address?
Tue Jun 06, 2023 8:04 pm
Related to this ?
viewtopic.php?t=196852
Kentzo
Long time Member
Long time Member
Tue Jun 06, 2023 9:03 pm
Hmm, in my case I get an error.
Does /user/active/pring detail report the connection?
deejaysanoj
Fri Jun 09, 2023 6:53 pm
same after i update into 7.9.2 this time..
EDIT: it works now in a couple of minutes.
Buford
Mon Jul 17, 2023 4:48 am
hello there
i have an RB951G-2HnD-IN
i get the same error after i upgraded to 7.9.1 when I first experienced this.
i upgraded to 7.10, no dice.
i upgraded to 7.10.2, still the same error.
does anyone have an idea on how to fix this?
i also experience this with my CCR2004-1G-12S+2XS, CRS328-24P-4S+RM, and cAP ac.
Buford
Mon Jul 17, 2023 5:19 am
I downgraded to version 7.7
terminal now works.
I upgraded to version 7.8
terminal still works.
I guess this is a bug in version 7.9 and up?
konstantinas
Wed Aug 16, 2023 5:14 am
I had the same problem with v7.11. The only way to fix it was to reset configuration and re-apply if from script backup. Hope this will help you.
Users browsing this forum: Bing [Bot], edielson_atm, syslog and 100 guests
