Sohraab
Desktop SSH Client Error
Mon Jun 05, 2023 9:24 pm
Hi every one
I have a X86 ROS as SSH server. On Android Devices and Apple IOS, SSH client APPs works fine.
On windows 10, I use Bitvise SSH client. But i can't connect to the server and this error is shown;
“The SSH connection has terminated with error. Reason: Error class: LocalSshDisconn, code: KeyExchangeFailed, message: FlowSshTransport: no mutually supported inbound MAC algorithm. Local list: hmac-sha2-256-etm,hmac-sha2-512-etm,hmac-sha2-256,hmac-sha2-512. Remote list: hmac-sha1,hmac-md5”
On ROS Side this log is shown; “can't agree on KEX algorithms”
I googled on this community and many other forums, But none of them were useful.
Can you please help?
R1CH
Re: Desktop SSH Client Error
Mon Jun 05, 2023 10:27 pm
RouterOS SSHD uses weak and outdated algorithms by default, you need to set /ip ssh set strong-crypto=yes
Sohraab
Fri Jun 16, 2023 8:56 pm
Thanks for your replay
when I set /ip ssh set strong-crypto=yes The desktop client problem is not solved and the same error message is displayed. Also, Android users cannot connect.
own3r1138
Long time Member
Long time Member
Fri Jun 16, 2023 9:06 pm
Mine is working correctly.
V7.7, V7.10
strong-crypto=yes
Bitvise Client log
Sohraab
Fri Jun 16, 2023 11:40 pm
I can connect to server using putty.
But my Bitvise does not connect.
I have attached two pictures of the problem. Maybe looking at these pictures will help.
Users browsing this forum: Bing [Bot], PLJ020 and 98 guests
