Stourview
AP ax^2 Default config
Wed Jun 07, 2023 4:52 am
Hi All
First I would like to say that I am new to ROS7, but looks good and I particularly wanted to explore wireguard BUT ...
I'm not sure what the original config of the AX2 was but I have reset it several times due to errors I have made and it does not come back with any default config - or at least nothing I was expecting.
When using a HapLite in ROS6 it would install a default config with basic wireless, all lan ports bridged, DHCP, NAT and function as a basic AP/Router.
This AX2 does none of that. I'm struggling to get basic functionality out of it, Does anyone have a basic setup I can load into it please?
Also when I use the system/Reset Configuration option it seems to screw up the password so that I cant get in, I have to do a hard reset and wipe the thing. Am I missing something?
The AX2 looks good, great spec but so far not doing anything for me but consuming all the spare time I have.
Would appreciate any help anyone can give to get me (re)started.
Many thanks
Dave
holvoetn
Re: AP ax^2 Default config
Wed Jun 07, 2023 6:42 am
Which version is currently on the device ?
You may want to start with netinstall, I recommend version 7.8 as latest or if you're adventurous, use 7.10rc3.
Avoid 7.9-chain (my view).
The fact you can not get in after changing the password sounds familiar to me ... (created sup-ticket for 3 AX devices with similar behavior after upgrading from 7.8 to 7.10rc3. But netinstall to 7.10rc3 went flawless, go figure...).
Stourview
Wed Jun 07, 2023 8:36 am
7.92 currently. I'll start with 7.8 and see what happens, thanks.
holvoetn
Wed Jun 07, 2023 8:45 am
For completeness, default script on AX2 attached (based on 7.10rc1 but should not be that much difference).
a13antichrist
Wed Jun 07, 2023 12:08 pm
Also great as a learning reference to understand how everything is "meant" to be put together. Thanks! 8)
Users browsing this forum: McSee, unhuzpt and 98 guests
