ffries
OQEE free Ip Tv tunnel with IPv4/ipv6
Fri Jun 09, 2023 12:29 am
Dear all,
"home" is my main house.
"coutryside" is my house on the countryside.
Both are equipped with recent Mikrotik hardware and connected with wireguard.
HOME
I can watch two IP TV screen simultaneously (OQEE) on a local vlan.
Authentication is done over ipv4 and IPtv needs ipv6.
COUNTRYSIDE
On the countryside I am using a very cheap fiber access without any IP TV and two Amazon TV sticks.
I would like to watch OQEE using my main fiber connection home, preferably on the same vlan.
I see at least 4 solutions :
A) WIREGUARD
The easy solution would be to install wireguard on the Amazon TV sticks and connect directly to my router home.
B) VXLAN
A better solution would be to use vxlan. I created a vxlan interface on both rpiters (home/countryside) with two IPv4 and I can ping each router IP from each router. But I am not sure how to do it with IPv6 and then route IPv4 and IPv6 over my home router.
C) EOIP
Is there an easy way to create an interface inside a VLAN home and link with a tunnel (EoIP ?) an interface remotely the countryside on an interface. This way it could be very safe as my OQEE is alredy inside a vlan home.
D) Span the Ip TV vlan home and on the country side.
Please advise,
FFries
ffries
Re: OQEE free Ip Tv tunnel with IPv4/ipv6
Sun Jun 11, 2023 12:00 pm
End of story, I need EoIP with vlan tagging.
I will publish my configuration when finished.
A lot of users need such a feature.
Users browsing this forum: Bing [Bot], ernieball17, Google [Bot], Ogebalara, wsantos and 73 guests
