Datanav
Wireguard: Cannot reach Internal LAN
Fri Jun 09, 2023 12:35 pm
Hi all,
I have setup site2site VPN via wireguard, here is what i can achieve:
1. I can only ping router 2 from router1's interface and vice versa.
What i have been unable to achieve:
1. Cannot reach internal LAN devices from either side i.e from router1, i cannot reach devices in the LAN of router 2 and vice versa
I would like to be able to reach devices on both ends.
Below are my configs:
Router1:
# jun/09/2023 12:17:04 by RouterOS 7.9.2
# software id = 141B-TTYI
# model = RB951G-2HnD
# serial number = XXXXXXX
add admin-mac=xxxxx auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=XXXXX wireless-protocol=802.11
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguardVPN_to_Bandari
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip ipsec peer
add address=xx.xxxx.xxx.xx/32 exchange-mode=ike2 name="XXXXXi"
add address=xx.90.xxx.xx/32 exchange-mode=ike2 name=XXXX
add address=xx.72.xxxx.xxx/32 exchange-mode=ike2 name=XXX
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 \
    hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc \
    pfs-group=modp2048
add name=dhcp ranges=192.168.170.10-192.168.170.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.10.10.0/30,192.168.172.0/24 endpoint-address=\
    41.90.248.49 endpoint-port=13231 interface=wireguardVPN_to_Bandari \
    persistent-keepalive=10s public-key=\
    "publickey"
add address=192.168.170.1/24 comment=defconf interface=bridge network=\
    192.168.170.0
add address=10.10.10.1/30 interface=wireguardVPN_to_Bandari network=\
    10.10.10.0
/ip dhcp-client
add address=192.168.170.0/24 comment=defconf dns-server=192.168.170.1 \
    gateway=192.168.170.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.170.1 comment=defconf name=router.lan
add action=accept chain=input dst-port=13231 protocol=udp src-address=\
    41.90.248.49
add action=accept chain=forward dst-address=192.168.170.0/24 src-address=\
    192.168.172.0/24
add action=accept chain=forward dst-address=192.168.172.0/24 src-address=\
    192.168.170.0/24
add action=accept chain=input comment="For Winbox Access" dst-address=\
    192.168.170.0/24 dst-port=8291 protocol=tcp src-address=192.168.1.0/24
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=srcnat disabled=yes dst-address=192.168.170.0/24 \
    src-address=192.168.172.0/24
/ip ipsec identity
add peer=xxx
add peer="xxxxx"
add peer=xxxx
/ip ipsec policy
add dst-address=192.168.1.0/24 peer=xxxx src-address=192.168.170.0/24 tunnel=\
    yes
add dst-address=192.168.171.0/24 peer="xxxxxx" src-address=\
    192.168.170.0/24 tunnel=yes
add dst-address=192.168.172.0/24 peer=xxxx src-address=192.168.170.0/24 \
    tunnel=yes
add disabled=no dst-address=192.168.172.0/24 gateway=10.10.10.2 \
    routing-table=main suppress-hw-offload=no
/system clock
set time-zone-name=Africa/Nairobi
/system identity
set name="xxxxxx"
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Router 2:
# jun/09/2023 12:22:13 by RouterOS 7.9.2
# software id = 645K-5L30
# model = RB951Ui-2HnD
# serial number = xxxxx
add admin-mac=xxxxxx auto-mac=no comment=defconf name=bridge
/interface wireless
    ap-bridge ssid=Pharmaplus wireless-protocol=802.11
add listen-port=13231 mtu=1420 name=wireguard_to_Nyali
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk group-ciphers=\
    tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
    unicast-ciphers=tkip,aes-ccm
/ip ipsec peer
add address=xxxxxx/32 exchange-mode=ike2 name=\
    "xxxxxxxx"
add address=xxxxxxx/32 exchange-mode=ike2 name="xxxxxxx"
add address=xxxxxx/32 exchange-mode=ike2 name=xxxxx
/ip ipsec profile
/ip ipsec proposal
    pfs-group=modp2048
add name=dhcp ranges=192.168.172.10-192.168.172.254
/ip settings
/ipv6 settings
set auth=sha1,md5
add allowed-address=10.10.10.0/30,192.168.170.0/24 endpoint-address=\
    197.232.146.177 endpoint-port=13231 interface=wireguard_to_Nyali \
    "publickey2"
add address=192.168.172.1/24 comment=defconf interface=bridge network=\
    192.168.172.0
add address=10.10.10.2/30 interface=wireguard_to_Nyali network=10.10.10.0
/ip dhcp-client
add address=192.168.172.0/24 comment=defconf gateway=192.168.172.1 netmask=24
/ip dns static
add address=192.168.172.1 comment=defconf name=router.lan
    197.232.146.177
add action=accept chain=input dst-address=192.168.172.0/24 dst-port=8291 \
    invalid
    192.168.170.0/24
    192.168.172.0/24
/ip ipsec identity
add peer="xxxxx"
add peer="xxxxx"
add peer=xxxx
/ip ipsec policy
add dst-address=192.168.160.0/24 peer="xxxxx" src-address=\
    192.168.172.0/24 tunnel=yes
add dst-address=192.168.170.0/24 peer="xxxxx" src-address=\
add dst-address=192.168.1.0/24 peer=xxxx src-address=192.168.172.0/24 tunnel=\
    yes
add disabled=no dst-address=192.168.170.0/24 gateway=10.10.10.1 \
/system clock
/system identity
set name="xxxxxx"
/system note
/tool mac-server
Thanks.
anav
Re: Wireguard: Cannot reach Internal LAN
Fri Jun 09, 2023 1:26 pm
1. Do both have publicly accessible IP addresses?
2. Did you want both to be clients and servers or just one has client and one as server for initial handshake?
The reason I ask is both have input chain rules for wireguard whereas normally only one needs it to establish a connection.
Datanav
Fri Jun 09, 2023 1:29 pm
Below are the answers:
1. Yes both have publicly accessible IP addresses
2. I want router 1 to be the server while router 2 to be the client, however the end goal is that the 2 LANS can talk to each other
Just to add that i can ping both gateways(10.10.10.1 and 10.10.10.2) from LAN side of each router. Just cant reach any devices...
anav
Fri Jun 09, 2023 9:14 pm
(1) The rules for input chain access to the router from Wireguard are incorrect. Remember that the Input chain is for traffic to the router, not to a subnet..............
Remove these
and
protocol=tcp src-address=192.168.1.0/24[/
i]
and replace with ( always change default port to a unique port )
There is no need provide all users access to config (bad security practice) and thus limited by address list.
R1 -->add action=accept chain=input comment="For Winbox Access" src-address-list=Authorized
R2 -->add action=accept chain=input comment="For Winbox Access" src-address-list=Authorized
Where the source address list is comprised of admin devices with IPs statically set leases on each router.
Consider that via wireguard an admin IP can be used on both Routers addresss lists, for example, if an admin on R1 requires the ability to config R2.
(2) Slight modification for routes
R1
add disabled=no dst-address=192.168.172.0/24 gateway=wireguardVPN_to_Bandari \
R2
add disabled=no dst-address=192.168.170.0/24 gateway=wireguard_to_Nyali \
wireguard_to_Nyali
(3) To ensure clarity and to support both being able to initiate a connection use different listening ports....... So....
R1
add action=accept chain=input dst-port=13231 protocol=udp ( src address optional but if fixed not a bad idea! )
41.90.248.49 endpoint-port=14231 interface=wireguardVPN_to_Bandari \
"publickey"
R2
add listen-port=14231 mtu=1420 name=wireguard_to_Nyali
add action=accept chain=input dst-port=14231 protocol=udp (src address optional but not a bad idea)
"publickey2"
Datanav
Sat Jun 10, 2023 1:05 pm
@anav, Have done as you have recommended but still no traffic between subnets:
Below are the current configs:
# jun/10/2023 12:50:46 by RouterOS 7.9.2
add admin-mac=18:FD:74:2F:82:xx auto-mac=no comment=defconf name=bridge
/interface wireless
    ap-bridge ssid=xxxxx-protocol=802.11
add listen-port=14231 mtu=1420 name=Wireguard_to_bandari
/interface lte apn
/ip ipsec peer
add address=xxxx/32 exchange-mode=ike2 name="Pharmaplus Likoni"
add address=xxxxx/32 exchange-mode=ike2 name=Bandari
add address=xxxxxx/32 exchange-mode=ike2 name=PRD \
    send-initial-contact=no
/ip ipsec profile
/ip ipsec proposal
    pfs-group=modp2048
/ip settings
/ipv6 settings
set auth=sha1,md5
    41.90.248.49 endpoint-port=14231 interface=Wireguard_to_bandari \
    "public key"
    192.168.170.0
add address=10.10.10.1/30 interface=Wireguard_to_bandari network=10.10.10.0
/ip dhcp-client
/ip dns static
    192.168.170.0/24 dst-port=8291 protocol=tcp src-address=192.168.1.0/24(will sort this later)
    invalid
add action=accept chain=input dst-address=192.168.170.0/24 src-address=\
    192.168.172.0/24
/ip ipsec identity
add peer=xxxx
add peer="xxxxx"
add peer=xxxxx
/ip ipsec policy
    yes
add dst-address=192.168.171.0/24 peer="xxxxx" src-address=\
    tunnel=yes
add disabled=yes distance=1 dst-address=192.168.172.0/24 gateway=10.10.10.2 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=no dst-address=192.168.172.0/24 gateway=Wireguard_to_bandari \
/system clock
/system identity
set name="xxxxx"
/system note
/tool mac-server
Router 2:
# jun/10/2023 12:58:41 by RouterOS 7.9.2
add admin-mac=18:FD:74:A1:30:xxx auto-mac=no comment=defconf name=bridge
/interface wireless
    ap-bridge ssid=xxxx wireless-protocol=802.11
add listen-port=14231 mtu=1420 name=Wiregurad_to_nyali
/interface lte apn
/ip ipsec peer
add address=197.248.99.69/32 exchange-mode=ike2 name=\
    "xxxxxx"
add address=xxxx/32 exchange-mode=ike2 name="xxxx"
add address=xxxx/32 exchange-mode=ike2 name=xxx
/ip ipsec profile
/ip ipsec proposal
    pfs-group=modp2048
/ip settings
/ipv6 settings
set auth=sha1,md5
    197.232.146.177 endpoint-port=14231 interface=Wiregurad_to_nyali \
    "publickey2"
    192.168.172.0
add address=10.10.10.2/30 interface=Wiregurad_to_nyali network=10.10.10.0
/ip dhcp-client
/ip dns static
    invalid
/ip ipsec identity
add peer="xxxx"
add peer="xxxx"
add peer=xxxx
/ip ipsec policy
add dst-address=192.168.160.0/24 peer="xxxx" src-address=\
add dst-address=192.168.170.0/24 peer="xxxx" src-address=\
    yes
add disabled=yes distance=1 dst-address=192.168.170.0/24 gateway=10.10.10.1 \
    target-scope=10
add disabled=no dst-address=192.168.170.0/24 gateway=Wiregurad_to_nyali \
/system clock
/system identity
set name="xxxx"
/system note
/tool mac-server
anav
Sat Jun 10, 2023 5:08 pm
Actually you didnt, the listening port was NOT supposed to change on R1, just on R2.
The input chain rule for wireguard port in concert was NOT supposed to change on R1, just on R2
( In both cases above it was supposed to stay at 13231 ).
The only thing that was supposed to change was
a. the peer setting for endpoint port on R1 to 14231
b. the listening port and input chain rule for wireguard port on R2 to 14231
The allowed addresses holds the key to the issue....
Note the allowed IP for the subnets is identical on both config and thus we can conclude is WRONG
The local subnet on R1 is 192.168.170.0 and should be the remote IP subnet identified on R2
The local subnet on R2 is 192.168.172.0/24 and should be the remote IPsubnet identified on R1
Thus on R1
"public key"
Thus on R2
"public key"
anav
Sat Jun 10, 2023 5:57 pm
Also, recommend that each router identify the other router in allowed IPs by its IP address X/32 vice X/30.
This should not be an issue.
Datanav
Sat Jun 10, 2023 10:20 pm
Thus on R1
"public key"
Thus on R2
"public key"
@Anav
If you check correctly:
on R1:
The allowed Address is the subnet of R2: 192.168.172.0/24
While on R2:
The allowed Address is the subnet of R1: 192.168.170.0/24
Kindly just check the configs again as from your current suggestion the allowed subnet remain the same on both, that part is confusing to me.
Thanks.
anav
Sun Jun 11, 2023 3:21 pm
Hmm I swore it was not the case, but after checking for the 10th time LOL, It does indeed look fine.
My observations regarding the port numbers still stands to have clear difference. ( first half of post 6 )
Did you try setting both peers to .X/32 vice 0/30 for allowed addresses ???
Datanav
Mon Jun 12, 2023 9:59 am
Update:
@anav the solutions did not work, was forced to revert back to using ipsec since I don't have enough time to troubleshoot the issue.
Thanks for taking your time to have a look at my issue and for trying to help me out. Totally appreciated.
anav
Mon Jun 12, 2023 2:28 pm
Okay when you get more time, I am willing to assist, skype, discord, teamviewer etc............. it should work!!
Datanav
Mon Jul 03, 2023 4:06 pm
@Anav
I want to revisit this issue. Let me know how we can connect and maybe schedule a session we go through the setup. Would like also to know how to connect link wireguard via CGNAT.
anav
Mon Jul 03, 2023 6:29 pm
CGNAT isnt possible that I am aware of....... only as a client but not as a Server in that
a. its not a public IP
b. assuming you cannot forward a port on that type of device.
anav
Mon Jul 03, 2023 6:32 pm
anav_ds on discord in Mikrotik forum, contact me there........
Users browsing this forum: karlisi, unhuzpt and 122 guests
