fragtion
Getting status values for wifiwave interface using script?
Fri Jun 09, 2023 4:27 pm
There does not yet seem to be any way, using a script, to obtain the values for a wifiwave interface which Winbox shows under the "Status" tab. For example, "State", "Channel", "Tx Power"
This makes it difficult to, for instance, know if the interface is broadcasting SSID (running mode) or searching DFS radar (cac), etc. Anyone know a workaround for this?
Edit: Okay looks like I can get what I need from /interface/wifiwave2/monitor wifi1 as-value once. It would be nice to get these values using get instead of monitor, however?
rextended
Re: Getting status values for wifiwave interface using script?
Fri Jun 09, 2023 5:33 pm
not, because only monitoring that interface you can get that info... is not like read how one parameter is set....
holvoetn
Fri Jun 09, 2023 5:37 pm
Also seems to be version dependent.
When I use "as-value", I get zip nada nothing.
Leaving out "as-value" I get output.
AX3, 7.10rc1
[xyz@AX3-Office] /interface/wifiwave2> monitor wifi1 once as-value
state: running
channel: 5260/ax/Ceee
registered-peers: 0
authorized-peers: 0
tx-power: 17
available-channels: 5260/ax/Ceee
rextended
Fri Jun 09, 2023 5:40 pm
Try to print the array....
:put [monitor wifi1 once as-value]
holvoetn
Fri Jun 09, 2023 5:44 pm
Gotcha ! 8)
[xyz@AX3-Office] /interface/wifiwave2> :put [monitor wifi2 once as-value]
.id=*7;authorized-peers=2;available-channels=2462/ax/eC;channel=2462/ax/eC;comment=;registered-peers=2;state=running;tx-power=15
Users browsing this forum: No registered users and 34 guests
