g22113
"Feature" request: Improve discovery (LLDP) compatibility with TP-Link
Thu Jun 22, 2023 6:52 pm
We use TP-Link JetStream switches, and they appear to be sending NUL-padded device name (identity) field in LLDP. This is even with latest switch firmware; newer models only add more padding (presumably to support longer switch names). Because of this, the default tabular view of /ip/neighbor/print becomes useless as the "IDENTITY" column doesn't fit at all (and RouterOS just omits it instead of truncating).
It would be nice if RouterOS could ignore \00 NUL padding for compatibility with these devices.
14 interface=ether5 address=10.128.x.x address4=10.128.x.x
   mac-address=B0:4E:26:xx:xx:xx
   identity="UK-SW-Bas56-Net\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\0
         0\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\0
         0"
   platform="" version="" unpack=none age=7s interface-name="GigabitEthernet1/0/19"
   system-description="JetStream 24-Port Gigabit L2 Managed Switch with 4 SFP Slots"
   system-caps=bridge,router system-caps-enabled=bridge,router discovered-by=lldp
 5 interface=ether1-uk address=10.128.x.x address4=10.128.x.x
   mac-address=30:DE:4B:xx:xx:xx
   identity="UK-SW-Bas56-Serv\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\
         00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\
         00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00"
   platform="" version="" unpack=none age=16s interface-name="gigabitEthernet 1/0/20"
   system-description="JetStream 24-Port Gigabit L2+ Managed Switch with 4 10GE SFP+ Slots"
rplant
Re: "Feature" request: Improve discovery (LLDP) compatibility with TP-Link
Wed Jun 28, 2023 7:21 am
While Mikrotik are looking into this :)
I have a Xirrus AP, the Mikrotik seems to see it only with LLDP, while the Xirrus is also sending CDP.
Also, the Xirrus provides a system description entry that is only visible from the CLI, not from winbox
or webfig (Not sure how it should be displayed, perhaps like a comment on a line by itself as it is quite big)
system-description="Xirrus XD2-240, 1.0GB (1.0GHz), Version: Xirrus AOS 8.7.0
(Feb 24 2023), Build: 8176"
Users browsing this forum: No registered users and 5 guests
