Hi everyone,
I have already used OpenVPN with Mikrotik products for many projects, but all with version 6.XX
Given the release of V 7.XX I decided to do some tests on a simple application for the interconnection of two networks, however I'm having many problems with packet delivery.
Situation
# Router A
LAN 192.168.16.0/24
WAN XXX.XXX.XXX.XXX
OpenVPN server (TCP Protocol, IP Mode) 172.16.17.1 (Pool Client /26)
# Router B
LAN 192.168.0.0/24
YYY.YYY.YYY.YYY
Open VPN client (Client IP 172.16.17.5)
The goal of my setup is to make devices on the 192.168.16.0 network reachable from hosts on the 192.168.0.0 network through the VPN tunnel.
To do this I configured these static routes:
# Router A --> dst-add=192.168.0.0/24 gateway=172.16.17.5
# Router B --> dst-add=192.168.16.0/24 gateway=172.16.17.1
the anomalous thing that's happening to me and that makes me think it's not a route problem but something else is that if I do a simple test with ICMP packets (I cross-ping devices on different LANs) it works perfectly. Instead if I go to open WEB interfaces they load in part without ever completing the connection.
I checked the various IPs src and dst in the two "connection-traking" and everything seems to come back ... but it doesn't work.
Am I missing some additional configuration? Has a similar thing happened to anyone?
Thank you
