I have ax3, with 32GB USB 3.0 stick plugged in and at the end I get error message in log: "not enough disk space to download layer"
Here is my configuration:
Code: Select all
# 2023-07-16 08:39:39 by RouterOS 7.11beta4
# software id =
# model = C53UiG+5HPaxD2HPaxD
# serial number =
/container mounts
add dst=/var/log/nginx name=openspeed src=/usb1-part1/openspeed/var
/disk
set usb1 type=hardware
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
"30 943 995 392" type=partition
set usb2 type=hardware
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=TRUNK
set [ find default-name=ether3 ] comment=VLAN10_TEA_RADNI_PC
set [ find default-name=ether4 ] comment=VLAN88_HOME
set [ find default-name=ether5 ] comment=VLAN88_HOME
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
disabled .width=20/40/80mhz comment="5 GHz" configuration.country=Croatia \
.manager=local .mode=ap .ssid=Mikrotik mtu=1500 \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2412 \
.skip-dfs-channels=disabled .width=20mhz comment="2.4 GHz" \
configuration.country=Croatia .manager=local .mode=ap .ssid=Mikrotik \
/interface veth
add address=10.10.88.100/24 comment=IPERF3 gateway=10.10.88.1 name=\
veth1-iperf3
add address=10.10.88.110/24 comment=OPENSPEEDTEST gateway=10.10.88.1 name=\
veth2-openspeedtest
/interface wireguard
add comment="cloud vpn" listen-port=XXXXX mtu=1420 name=freevpn-wg
/interface vlan
add interface=bridge name=VLAN10_TEA_PC vlan-id=10
add interface=bridge name=VLAN20_SECURITY vlan-id=20
add interface=bridge name=VLAN30_IOT vlan-id=30
add interface=bridge name=VLAN40_IPTV vlan-id=40
add interface=bridge name=VLAN88_HOME vlan-id=88
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=HOME
/interface wifiwave2 configuration
add channel.band=5ghz-ax .frequency=5220 .width=20/40/80mhz country=Croatia \
disabled=no mode=ap name=cfg1-5 security.authentication-types=\
wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes ssid="Gazdin WiFi"
add channel.band=2ghz-ax .frequency=2437 .width=20mhz country=Croatia \
disabled=no mode=ap name=cfg2-2.4 security.authentication-types=\
add channel.band=2ghz-ax .frequency=2412 .width=20mhz country=Croatia \
disabled=no mode=ap name=cfg3-2.4@2412MHz security.authentication-types=\
add channel.band=5ghz-ax .frequency=5745 .width=20/40/80mhz country=Croatia \
disabled=no mode=ap name=cfg4-5@5745MHz security.authentication-types=\
add channel.frequency=5745 comment=AP_Kat_5GHz configuration=cfg4-5@5745MHz \
configuration.mode=ap disabled=no name=cap-wifi1
add channel.frequency=2412 comment=AP_Kat_2.4GHz configuration=\
cfg3-2.4@2412MHz configuration.mode=ap disabled=no name=cap-wifi2
add channel.frequency=5220 comment=AP_Prizemlje_5GHz configuration=cfg1-5 \
configuration.mode=ap disabled=no name=cap-wifi3
add channel.frequency=2437 comment=AP_Prizemlje_2.4GHz configuration=cfg2-2.4 \
configuration.mode=ap disabled=no name=cap-wifi4
/interface wifiwave2 datapath
add bridge=bridge disabled=no interface-list=LAN name=datapath_VLAN30 \
vlan-id=30
add bridge=bridge disabled=no interface-list=LAN name=datapath_VLAN20 \
vlan-id=20
add comment=IoT_WiFi configuration.mode=ap .ssid=IoT datapath=datapath_VLAN30 \
disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=cap-wifi4 \
name=cap-wifi5 security.authentication-types=wpa-psk,wpa2-psk
add comment=WiFi_CCTV configuration.mode=ap .ssid=WiFi_CCTV datapath=\
datapath_VLAN20 disabled=no mac-address=XX:XX:XX:XX:XX:XX \
master-interface=cap-wifi4 name=cap-wifi6 security.authentication-types=\
wpa-psk,wpa2-psk
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.5
add name=dhcp_pool2 ranges=10.10.20.2-10.10.20.150
add name=dhcp_pool3 ranges=10.10.30.2-10.10.30.254
add name=dhcp_pool4 ranges=10.10.40.2-10.10.40.50
add name=dhcp_pool5 ranges=10.10.88.2-10.10.88.254
add address-pool=dhcp_pool1 interface=VLAN10_TEA_PC lease-time=1d name=\
dhcp_VLAN10
add address-pool=dhcp_pool2 interface=VLAN20_SECURITY lease-time=1d name=\
dhcp_VLAN20
add address-pool=dhcp_pool3 interface=VLAN30_IOT lease-time=1d name=\
dhcp_VLAN30
add address-pool=dhcp_pool4 interface=VLAN40_IPTV lease-time=1d name=\
dhcp_VLAN40
add address-pool=dhcp_pool5 interface=VLAN88_HOME lease-time=1d name=\
dhcp_VLAN88
/port
set 0 name=serial0
/container
add interface=veth1-iperf3 logging=yes start-on-boot=yes workdir=/
add dns=8.8.8.8 envlist=speedtest_envs interface=veth2-openspeedtest \
root-dir=usb1-part1/speedtest start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1
/container envs
add key=TZ name=speedtest_envs value=Europe/Zagreb
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether2
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
admit-only-untagged-and-priority-tagged interface=ether4 pvid=88
admit-only-untagged-and-priority-tagged interface=ether5 pvid=88
admit-only-untagged-and-priority-tagged interface=wifi1 pvid=88
admit-only-untagged-and-priority-tagged interface=wifi2 pvid=88
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=veth1-iperf3 pvid=88
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2 untagged=wifi1,wifi2,ether4,ether5 \
vlan-ids=88
add bridge=bridge tagged=bridge untagged=ether3 vlan-ids=10
add bridge=bridge tagged=bridge,ether2 vlan-ids=20
add bridge=bridge tagged=bridge,ether2 vlan-ids=30
add bridge=bridge tagged=bridge,ether2 vlan-ids=40
add interface=VLAN10_TEA_PC list=LAN
add interface=VLAN20_SECURITY list=LAN
add interface=VLAN30_IOT list=LAN
add interface=VLAN40_IPTV list=LAN
add interface=VLAN88_HOME list=LAN
add interface=VLAN88_HOME list=HOME
add interface=veth1-iperf3 list=LAN
add interface=*F list=LAN
add interface=*11 list=LAN
/interface wifiwave2 access-list
add action=accept allow-signal-out-of-range=30s disabled=no interface=any \
mac-address=00:C3:0A:B7:ED:1C signal-range=-67..0
add action=reject allow-signal-out-of-range=1s disabled=no interface=any \
mac-address=00:C3:0A:B7:ED:1C signal-range=-120..-68
/interface wifiwave2 capsman
set ca-certificate=auto enabled=yes package-path="" require-peer-certificate=\
no upgrade-policy=none
/interface wifiwave2 provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg1-5 \
slave-configurations=cfg4-5@5745MHz supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=cfg2-2.4 \
slave-configurations=cfg3-2.4@2412MHz supported-bands=2ghz-ax
/interface wireguard peers
add address=10.10.10.0/24 gateway=10.10.10.1
add address=10.10.20.0/24 gateway=10.10.20.1
add address=10.10.30.0/24 gateway=10.10.30.1
add address=10.10.40.0/24 gateway=10.10.40.1
add address=10.10.88.0/24 dns-server=10.10.88.13 gateway=10.10.88.1
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="Prekid prometa od VLAN10 na VLAN88" \
in-interface=VLAN10_TEA_PC out-interface=VLAN88_HOME
add action=drop chain=forward comment="Prekid prometa od VLAN20 na VLAN88" \
in-interface=VLAN20_SECURITY out-interface=VLAN88_HOME
add action=drop chain=forward comment="Prekid prometa od VLAN30 na VLAN88" \
in-interface=VLAN30_IOT out-interface=VLAN88_HOME
add action=drop chain=forward comment="Prekid prometa od VLAN40 na VLAN88" \
in-interface=VLAN40_IPTV out-interface=VLAN88_HOME
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=hAP_ax3_router
/system note
set show-at-login=no
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=HOME
