The $CHALK function can be used inline/interpolation to add a <color> to text in a string like so:
Code: Select all
:put "$[$CHALK blue]hello world$[$CHALK no-style]"
Or, If <text> is provided as the 2nd argument to $CHALK function, it will be output via a :put in one-line.
Code: Select all
$CHALK red "hello world" bold=yes inverse=yes
Another use case is using debug=yes as an option $CHALK, this will output the ANSI escape code formatted for use in a Mikrotik script – e.g. you can use $CHALK to make an ANSI string WITHOUT having CHALK function load "at runtime".
Code: Select all
[amm0@Mikrotik] /> $CHALK red debug=yes
\1B[31;49m
[amm0@Mikrotik] /> $CHALK no-style debug=yes
\1B[39;49m
[amm0@Mikrotik] /> :put "\1B[31;49mcut-and-pasted-codes\1B[39;49m"
cut-and-pasted-codes # (in bold red)
The available color are available using "$CHALK colors":
As a bonus, there a "url" option that will generate a "clickable" URL in a modern terminal:
Code: Select all
$CHALK url "http://example.com" text="Example Link"
To see some examples, you can use "$CHALK help"...
The actual code for the $CHALK function that will be have to add to the RouterOS, either by cut-and-paste to test, or via /system/script or /system/scheduler so it's always loaded:
CHALK colorizing function code
:global CHALK do={ # we may call ourselves for control codes, so declare that :global CHALK :local helptext "\ \r\n \$CHALK \r\n generates ANSI codes that can be used in a string to add colorized text\ \r\n \ \r\n Basic Syntax:\ \r\n \$CHALK <text-color> [<text>] [inverse=yes] [[bold=yes]|[dim=yes]]\ \r\n \ \r\n Alternatively, use set background (bg=) color, instead of inverse=yes:\ \r\n \$CHALK <text-color> [<text>] bg=<text-color> [[bold=yes]|[dim=yes]]\ \r\n \ \r\n View possible values of <text-color>:\ \r\n \$CHALK colors\ \r\n \ \r\n Clear all ANSI formatting:\ \r\n \$CHALK reset\ \r\n \ \r\n Clear only foreground and background colors:\ \r\n \$CHALK no-style\ \r\n \ \r\n Generate a \"clickable\" URL (in select terminals only):\ \r\n \$CHALK url \"http://example.com\" text=\"Example Link\"\ \r\n \ \r\n To see this page, use:\ \r\n \$CHALK help\ \r\n \ \r\n Example: \ \r\n Print (\"put\") some text in cyan -\ \r\n \$CHALK cyan \"hello world\" \ \r\n \ \r\n Output blue text inside a string -\ \r\n :put \"\$[\$CHALK blue]hello world\$[\$CHALK no-style]\"\ \r\n \ \r\n Shout bold text with background color (using inverse=yes) -\ \r\n :put \"\$[\$CHALK red inverse=yes bold=yes]HELLO WORLD\$[\$CHALK no-style]\"\ \r\n \ \r\n Create a click-able URL -\ \r\n :put \"\$[\$CHALK url \"http://www.mikrotik.com\" text=\"Go to Mikrotik Website\"]\" \ \r\n ** only works when connected via SSH & using \"modern\" terminal\ \r\n \ \r\n Show example colors -\ \r\n \$CHALK colors \ \r\n " # handle 8-bit color names :local lookupcolor8 do={ :local color8 { black={30;40}; red={31;41}; green={32;42}; yellow={33;43}; blue={34;44}; magenta={35;45}; cyan={36;46}; white={37;47}; "no-style"={39;49}; reset={0;0}; "bright-black"={90;0}; "gray"={90;100}; "grey"={90;100}; "bright-red"={91;101}; "bright-green"={92;103}; "bright-yellow"={93;104}; "bright-blue"={94;104}; "bright-magenta"={95;105}; "bright-cyan"={96;106}; "bright-white"={97;107} } :if ($1 = "as-array") do={:return $color8} :if ([:typeof ($color8->$1)]="array") do={ :return ($color8->$1) } else={ :return [:nothing] } } :if ($1 = "color") do={ :if ([:typeof $2] = "str") do={ :local ccode [$lookupcolor8 $2] :if ([:len $ccode] > 0) do={ :put $ccode :return [:nothing] } else={$CHALK colors} } else={$CHALK colors} } :if ($1 = "colors") do={ :put "\t <color>\t\t $[$CHALK no-style inverse=yes]inverse=yes$[$CHALK reset]\t\t $[$CHALK no-style bold=yes]bold=yes$[$CHALK reset]\t\t $[$CHALK no-style dim=yes]dim=yes$[$CHALK reset]" :foreach k,v in=[$lookupcolor8 as-array] do={ :local ntabs "\t" :if ([:len $k] < 8 ) do={ :set ntabs "\t\t" } :put "\t$[$CHALK $k]$k$[$CHALK reset]$ntabs$[$CHALK $k inverse=yes]\t$k$[$CHALK reset]\t$[$CHALK $k bold=yes]$ntabs$k$[$CHALK reset]\t$[$CHALK $k dim=yes]$ntabs$k$[$CHALK reset]" } :return [:nothing] } :if ($1 = "help") do={ :put $helptext :return [:nothing] } # handle clickable URLs :if ($1 = "url") do={ :local lurl "http://example.com" :if ([:typeof $2]="str") do={ :set lurl $2 } else={ :if ([:typeof $url]="str") do={ :set lurl $url } } :local ltxt $lurl :if ([:typeof $text]="str") do={ :set ltxt $text } :return "\1B]8;;$lurl\07$ltxt\1B]8;;\07" } # set default colors :local c8str {mod="";fg="$([$lookupcolor8 no-style]->0)";bg="$([$lookupcolor8 no-style]->1)"} # if the color name is the 1st arg, make the the foreground color :if ([:typeof [$lookupcolor8 $1]] = "array") do={ :set ($c8str->"fg") ([$lookupcolor8 $1]->0) } # set default colors # set the modifier... # hidden= :if ($hidden="yes") do={ :set ($c8str->"mod") "8;" } else={ # inverse= :if ($inverse="yes") do={ :set ($c8str->"mod") "7;" } # bold= :if ($bold="yes") do={ :set ($c8str->"mod") "$($c8str->"mod")1;" # set both bold=yes and light=yes? bold wins... } else={ # dim= :if ($dim="yes") do={ :set ($c8str->"mod") "$($c8str->"mod")2;" } } } # if bg= set, apply color :if ([:typeof $bg]="str") do={ :if ([:typeof [$lookupcolor8 $bg]] = "array") do={ :set ($c8str->"bg") ([$lookupcolor8 $bg]->1) } else={:error "bg=$bg is not a valid color"} } # build the output :local rv "\1B[$($c8str->"mod")$($c8str->"fg");$($c8str->"bg")m" # if debug=yes, show the ANSI codes instead :if ($debug = "yes") do={ :return [:put "\\1B[$[:pick $rv 2 80]"] } # if the 2nd arg is text, or text= set, :local ltext $2 :if ([:typeof $text]="str") do={ :set ltext $text } :if ([:typeof $ltext] = "str") do={ :return [:put "$rv$2$[$CHALK reset]"] } :return $rv }The following GitHub gist was used as reference for the ANSI codes used here: https://gist.github.com/fnky/458719343a ... a4f7296797
TODO
- support "cls" and/or"clear-screen" to wipe screen
- reset should be just ]0m not ]0,49m
- debug=yes does not work with URL nor includes text if there was text provided
- add RGB support if an 3 element array is provided {R;G;B} as a color name
- should support ascii name for control codes (e.g. $CHALK esc or $CHALK bel)
- incorporate some "color prefix code" like + - etc to avoid needing inverse= dim=
- help should use $0 instead of assuming name is CHALK
edit 1/2: updated TODOs
