tobcon
CSS610 LAG VLAN confusion
Thu Jul 20, 2023 3:50 pm
Hello
I have a CSS610-8P-2S+IN. I'm confused about its LAG IEEE 802.3ad (LACP) feature.
In the Tab LAG, I have configured two ports to be in the same Group in the mode static.
I want this LAG to be Tagged with the VLAN. How is this reflected in the VLAN Tab? The VLAN Tab just supports the ports.
k6ccc
Re: CSS610 LAG VLAN confusion  [SOLVED]
Thu Jul 20, 2023 11:52 pm
When I have run a LAG under SwitchOS (on a VLAN trunk), I have set the VLAN and VLANs tabs to match each other for the two ports that are part of the LAG - it worked that way. I have never tried any other way and there is no setting on either the LAG or VLAN tabs to reflect that a specific VLAN is on the LAG - only the ports.
This was done on CSS326 switches.
tobcon
Fri Jul 21, 2023 1:22 am
In the end, I did the same. Configured the LAG and just put all ports of the LAG into the VLAN. Seems to work.
Still would be great to get this documented if this is the correct way of handling it.
