foffa
loadbalancing work fine but with hotspot :( :(
Mon Nov 12, 2007 4:34 am
hello guyess
i hav load balancing
it is working fine
but after enableing hotspot
all peers work with the active routes (D,A) ROUTE
when i disable hotspot
load balancing goes fine and the ip range i marked goes where i configured too
ANY IDEAS I GO COMPELETLY MAD MAD
BY THE WAY LETNI MAKES ME DISCOVER THIS ISSUE
BECAUSE I CHEcKD LOAD BALANCE BEFORE ENABLING HOTSPOT
foffa
Re: loadbalancing work fine but with hotspot :( :(
Mon Nov 12, 2007 8:29 pm
i got a solution by my self
but i need to hear another ideas
the solution i figured is so so simple
bimwilly
Wed Oct 14, 2009 7:38 pm
hello i have similar problem, i have load balancing and when i enable hotspot, the entire network goes slow.
did u find a solution to yours.
bimwilly
Wed Oct 14, 2009 7:44 pm
hello folks, did u get solution to loadbalancing with hotspot enabled.
fewi
Wed Oct 14, 2009 8:18 pm
What kind of load-balancing? The below works for PCC and Hotspot:
add address=1.1.1.2/24 disabled=no interface=outside1
add address=1.1.2.2/24 disabled=no interface=outside2
add address=10.0.0.1/24 disabled=no interface=hotspot
add address=10.0.1.1/24 disabled=no interface=hotspot2
/ip firewall address-list
add address=10.0.0.0/24 disabled=no list=Local_NAT_Networks
add address=10.0.1.0/24 disabled=no list=Local_NAT_Networks
/ip firewall mangle
add action=mark-connection chain=input connection-state=new disabled=no in-interface=outside1 new-connection-mark=outside1_connection passthrough=yes
add action=mark-connection chain=input connection-state=new disabled=no in-interface=outside2 new-connection-mark=outside2_connection passthrough=yes
add action=mark-routing chain=output connection-mark=outside1_connection disabled=no new-routing-mark=to_outside1 passthrough=yes
add action=mark-routing chain=output connection-mark=outside2_connection disabled=no new-routing-mark=to_outside2 passthrough=yes
add action=accept chain=prerouting disabled=no dst-address=1.1.1.0/24 src-address-list=Local_NAT_Networks
add action=accept chain=prerouting disabled=no dst-address=1.1.2.0/24 src-address-list=Local_NAT_Networks
add action=mark-connection chain=prerouting connection-state=new disabled=no dst-address-type=!local hotspot=auth new-connection-mark=outside1_connection passthrough=yes per-connection-classifier=src-address:2/0 src-address-list=Local_NAT_Networks
add action=mark-connection chain=prerouting connection-state=new disabled=no dst-address-type=!local hotspot=auth new-connection-mark=outside2_connection passthrough=yes per-connection-classifier=src-address:2/1 src-address-list=Local_NAT_Networks
add action=mark-routing chain=prerouting connection-mark=outside1_connection disabled=no new-routing-mark=to_outside1 passthrough=yes src-address-list=Local_NAT_Networks
add action=mark-routing chain=prerouting connection-mark=outside2_connection disabled=no new-routing-mark=to_outside2 passthrough=yes src-address-list=Local_NAT_Networks
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.1.1.1 routing-mark=to_outside1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.1.2.1 routing-mark=to_outside2 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=5 dst-address=0.0.0.0/0 gateway=1.1.1.1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=10 dst-address=0.0.0.0/0 gateway=1.1.2.1 scope=30 target-scope=10
Unauthenticated Hotspot connections will not be load-balanced, but everything else will be.
bimwilly
Thu Oct 15, 2009 11:28 am
hello folks,
this post is meant for 2 isp and 2 lan, can it work for 2 isp and one lan ,
pls post the rules for that and also that will work with hotspot.
thanks
fewi
Thu Oct 15, 2009 6:06 pm
hello folks,
thanks
Yes, it will. It's the exact same mangle rules, just build the address-list Local_NAT_Networks with only one network. You could change the rules to refer to the LAN directly, but I see no benefit to that - using those rules as is allows you to expand to more LANs just by adding interfaces and adding the networks to the address-list.
bimwilly
Thu Oct 15, 2009 8:26 pm
i tried it and it didnt work,
the rule i tried was simple. and it worked. u segment the 192.168.0.0/24 to groups and route each isp to the different group.
i hope u understand
fewi
Thu Oct 15, 2009 8:31 pm
I do not.
bimwilly
Thu Oct 15, 2009 9:20 pm
ok,
lets start like this, post rule that will work on 2wan and one lan and if hotspot is enabled, it will still work. and it wont slow the network
pls post .
thanks
fewi
Thu Oct 15, 2009 9:36 pm
/ip firewall mangle
Works for me on 3.30. Unauthenticated Hotspot connections will not be load-balanced, but all authenticated traffic from the Hotspot will be.
bimwilly
Thu Oct 15, 2009 10:41 pm
thanks folks, i will try, but before then, let me ask you, will it work fine on 2.9.27 version.
thanks
fewi
Thu Oct 15, 2009 10:46 pm
No. PCC got added way later. 2.9.27 is way out of support. No 2.x version is supported anymore at all since 4.0 got released.
Update.
CastorTroy
Wed Oct 28, 2009 9:56 pm
fewi,
Would you mind posting a sample hotspot config to go along with your PCC config?
I'd greatly appreciate it.
fewi
Wed Oct 28, 2009 10:04 pm
Simple hotspot config, no RADIUS. One profile for 1mbps up and down, a user 'hotspot' with password 'hotspot'. Even unauthenticated users can ping.
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-pap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
ssl-certificate=none use-radius=no
add dns-name=hotspot.example.com hotspot-address=0.0.0.0 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=https name=hotspot rate-limit=5m/5m smtp-server=0.0.0.0 \
split-user-domain=no use-radius=no
/ip hotspot
add disabled=no idle-timeout=30m interface=hotspot keepalive-timeout=5m name=hotspot profile=hotspot
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default rate-limit=64k/64k shared-users=unlimited status-autorefresh=1m transparent-proxy=no
add idle-timeout=none keepalive-timeout=15m name=hotspot rate-limit=1m/1m shared-users=unlimited status-autorefresh=1m transparent-proxy=no
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add comment="" disabled=no name=hotspot password=hotspot profile=hotspot
/ip hotspot walled-garden ip
add action=accept comment="Allow hotspot users to ping for troubleshooting purposes" disabled=no protocol=icmp
And for completion's sake here DHCP, DNS and NAT:
add name=DHCP-Pool-Hotspot ranges=10.0.0.2-10.0.0.254
add address-pool=DHCP-Pool-Hotspot authoritative=yes bootp-support=static disabled=no interface=hotspot lease-time=3h name=DHCP-Hotspot
/ip dhcp-server config
set store-leases-disk=5m
add address=10.0.0.0/24 comment="" dns-server=10.0.0.1 domain=example.com gateway=10.0.0.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 primary-dns=1.1.1.3 secondary-dns=1.1.2.3
/ip dns static
add address=10.0.0.1 disabled=no name=hotspot.example.com ttl=1d
add chain=srcnat action=masquerade disabled=no out-interface=outside1
add chain=srcnat action=masquerade disabled=no out-interface=outside2
But really the wizard does a decent enough job of filling all that out for you.
CastorTroy
Wed Oct 28, 2009 10:48 pm
The issue I am having currently is that with the hotspot enabled, users are not able to resolve DNS. Users can ping DNS servers, but aren't able to resolve anything.
Disable the hotspot, and DNS works fine.
fewi
Wed Oct 28, 2009 11:44 pm
Post the output of "/ip dns". As per the manual that section _must_ be set up right for Hotspots to function.
Enabling a Hotspot brings up dynamic rules in the firewall, one of which redirects DNS. That redirection in turn uses the internal DNS proxy, so if that doesn't function right, the clients have DNS issues.
CastorTroy
Thu Oct 29, 2009 12:14 am
I upgraded the box to 4.2 (was running 3.27 :? ), and now DNS is working fine with the hotspot
The next issue I am having is regarding the load balancing itself.
I have WAN1, WAN2, and LAN1.
Using the ping utility, if I specify to ping out to the internet from WAN1, it can get out just fine. However, if I specify to ping out to the internet from WAN2, it cannot. I can ping the WAN2 gateway from WAN2, but no internet addresses.
If I disable WAN1, WAN2 then works with no issue, and I can ping out to the internet
CastorTroy
Thu Oct 29, 2009 9:06 pm
I am still running into DNS issues.....
Output of ip dns:
primary-dns: 67.91.XXX.XXX
secondary-dns: 67.91.XXX.XXX
allow-remote-requests: no
max-udp-packet-size: 512
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 4KiB
fewi
Thu Oct 29, 2009 9:12 pm
As I said, for Hotspot to function right you _must_ set up the DNS proxy.
/ip dns set allow-remote-request=yes
CastorTroy
Fri Oct 30, 2009 6:27 pm
fewi, no change. hosts are still unable to resolve DNS. can ping out just fine...
fewi
Fri Oct 30, 2009 6:31 pm
Try adding
/ip hotspot walled-garden ip add protocol=udp dst-port=53 action=accept
/ip firewall filter add chain=input action=accept protocol=udp dst-port=53 place-before=0
as a wild stab without seeing your actual configuration.
CastorTroy
Fri Oct 30, 2009 7:02 pm
No luck there either.
If I clear out the DNS cache on the Mikrotik, and try to get to a website while running the torch, I see the DNS request come in, and I see the DNS cache add the proper entry. However, while monitoring the torch, the Mikrotik never sends out a response with the DNS reply.
If I disable the hotspot, while monitoring the torch, I see both the request, and the reply, on the hotspot's interface.
fewi
Fri Oct 30, 2009 7:04 pm
Post the output of "/ip hotspot export", "/ip firewall export", "/ip dns export", "/ip address export", "/ip dhcp-server export", "/ip pool export", "/interface print detail" and "/ip route print detail"
CastorTroy
Fri Oct 30, 2009 7:15 pm
ether1 is wan1
ether2 is wan2
wlan1 is lan/hotspot
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
add dns-name="" hotspot-address=10.0.0.1 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=hsprof1 rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot
add address-pool=pool1 addresses-per-mac=2 disabled=no idle-timeout=5m interface=wlan1 keepalive-timeout=none name=hotspot1 profile=hsprof1
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip hotspot user
add comment="" disabled=no name=admin password=password profile=default
add action=accept comment="" disabled=no protocol=icmp
add action=accept comment="" disabled=no dst-port=53 protocol=udp
add address=10.0.0.0/24 comment="" disabled=no list=Local_NAT_Networks
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=ether1 new-connection-mark=outside1_connection passthrough=yes
add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=ether2 new-connection-mark=outside2_connection passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=outside1_connection disabled=no new-routing-mark=to_outside1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=outside2_connection disabled=no new-routing-mark=to_outside2 passthrough=yes
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.16.0/24 src-address-list=Local_NAT_Networks
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.50.0/24 src-address-list=Local_NAT_Networks
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-type=!local hotspot=auth new-connection-mark=outside1_connection passthrough=yes per-connection-classifier=src-address:2/0 src-address-list=\
    Local_NAT_Networks
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-type=!local hotspot=auth new-connection-mark=outside2_connection passthrough=yes per-connection-classifier=src-address:2/1 src-address-list=\
    Local_NAT_Networks
add action=mark-routing chain=prerouting comment="" connection-mark=outside1_connection disabled=no new-routing-mark=to_outside1 passthrough=yes src-address-list=Local_NAT_Networks
add action=mark-routing chain=prerouting comment="" connection-mark=outside2_connection disabled=no new-routing-mark=to_outside2 passthrough=yes src-address-list=Local_NAT_Networks
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=10.0.0.0/24
/ip firewall service-port
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 primary-dns=67.91.XX.XX secondary-dns=67.91.XX.XX
add address-pool=pool1 authoritative=after-2sec-delay bootp-support=static disabled=no interface=wlan1 lease-time=3d name=server1
add address=10.0.0.0/24 comment="hotspot network" gateway=10.0.0.1
[admin@wfgy-wfgtwoharbomn-02] > /interface print detail
 0  R  name="ether1" type="ether" mtu=1500 l2mtu=1526
 1  R  name="ether2" type="ether" mtu=1500 l2mtu=1522
 2     name="ether3" type="ether" mtu=1500 l2mtu=1522
 3  R  name="wlan1" type="wlan" mtu=1500 l2mtu=2290
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  dst-address=0.0.0.0/0 gateway=192.168.16.1 gateway-status=192.168.16.1 reachable ether1 check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_outside1
 1 A S  dst-address=0.0.0.0/0 gateway=192.168.50.1 gateway-status=192.168.50.1 reachable ether2 check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_outside2
 2 A S  dst-address=0.0.0.0/0 gateway=192.168.16.1 gateway-status=192.168.16.1 reachable ether1 check-gateway=ping distance=5 scope=30 target-scope=10
 3   S  dst-address=0.0.0.0/0 gateway=192.168.50.1 gateway-status=192.168.50.1 reachable ether2 check-gateway=ping distance=10 scope=30 target-scope=10
 4 ADC  dst-address=10.0.0.0/24 pref-src=10.0.0.1 gateway=wlan1 gateway-status=wlan1 reachable distance=0 scope=10
 5 ADC  dst-address=192.168.16.0/24 pref-src=192.168.16.25 gateway=ether1 gateway-status=ether1 reachable distance=0 scope=10
 6 ADC  dst-address=192.168.50.0/24 pref-src=192.168.50.25 gateway=ether2 gateway-status=ether2 reachable distance=0 scope=10
CastorTroy
Fri Oct 30, 2009 8:55 pm
We got it working.....
The problem is that the host computer I was using had a statically defined DNS server, while using DHCP for the IP and gateway, the DNS proxy does not work. Setting DNS to DHCP, instead of static, and I can
Creating a NAT rule to simply pass through DNS traffic, instead of using the proxy, and everything works fine.
fewi
Thu Jun 03, 2010 3:55 pm
This thread contains a working configuration for Hotspot + PCC using 3.30, it also works in later versions. The configuration worked for me, as well as someone else once unrelated issues were fixed.
I don't know what else you want.
fewi
Fri Jun 04, 2010 4:01 pm
I would help you if you didn't make it impossible to do so.
Again, this thread contains a working configuration specifically for 3.30 and your scenario. You're not giving any details on how you determined load balancing isn't working for you, and didn't even just post a copy of your configuration.
What are you expecting people to do, and how are you expecting them to help you?
fewi
Fri Jun 04, 2010 4:25 pm
If you had indicated that several days ago instead of just asking the same question over and over you would have received help days ago.
Post the output of "/ip address print detail", "/interface print", "/ip firewall mangle print detail" and "/ip route print detail".
fewi
Fri Jun 04, 2010 4:52 pm
I understand that.
PCC + Hotspot requires some additional configuration of PCC. I've asked you to post your PCC configuration so I can tell you what changes to make so that it looks like the configuration further above in this thread.
fewi
Fri Jun 04, 2010 5:03 pm
Then read the post from "Wed Oct 14, 2009 10:18 am" in this thread and apply it.
I cannot help you beyond that.
fewi
Fri Jun 04, 2010 5:09 pm
That post contains the configuration. There is nothing else to send.
JCesar
Tue Oct 19, 2010 10:46 am
How i can create the nat rule? i have the same problem with 3 wan load balance PCC + 1 lan with hotspot. but the hotspot dont redirect to login page, i try to put the ip directly on the webbroser and i can login sucess and browse internet fine, the only problem is the redirect hotspot login page. help please :P
JCesar
Fri Oct 22, 2010 8:42 am
fewi you can explain why you use the DNS 1.1.1.3?? 1.1.2.3? i can use 1.1.11 and 1.1.2.1??
or maybe DNS 8.8.8.8 ? please help me
fewi
Fri Oct 22, 2010 3:07 pm
It's an example. Those are not real DNS servers. Substitute your own.
Feklar
Fri Oct 22, 2010 11:50 pm
add action=accept chain=hotspot comment="Allow DNS to pass through for guests \
    that have been authed on the network." disabled=no dst-port=53 hotspot=\
    auth protocol=udp
add action=accept chain=hotspot comment="" disabled=no dst-port=53 hotspot=\
    auth protocol=tcp
You could also use NAT rules to redirect all DNS requests to one of your servers.
JCesar
Sun Oct 24, 2010 10:05 am
thanks i will try
aislecom
Sun Mar 20, 2011 4:48 am
I have the following and my customers are staring to hate me.
1) slow connection
2) Some customer cannot get login page
3) server not found after customer starts to browse
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default \
set default idle-timeout=10m keepalive-timeout=5m name=default rate-limit=386k/1024k session-timeout=2m shared-users=1 status-autorefresh=1m \
add idle-timeout=10m keepalive-timeout=2m name=multi-user rate-limit=256k/1024k session-timeout=2m shared-users=2 status-autorefresh=1m transparent-proxy=no
/ip hotspot profile
add dns-name="" hotspot-address=10.0.0.138 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap,https,http-pap,trial name=hsprof1 nas-port-type=\
cable radius-accounting=yes radius-default-domain="" radius-interim-update=received radius-location-id="" radius-location-name="" radius-mac-format=\
XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no ssl-certificate=none trial-uptime=30m/1w trial-user-profile=default use-radius=\
yes
/ip hotspot
add disabled=no idle-timeout=10m interface=bridge1 keepalive-timeout=none name="AI Broadband" profile=hsprof1
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
add name=aislecom-pool ranges=10.0.0.2-10.0.0.137,10.0.0.140-10.0.0.150
add address-pool=aislecom-pool authoritative=after-2sec-delay bootp-support=static disabled=no interface=bridge1 lease-time=2h name=dhcp1
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.0.0.138/24 broadcast=10.0.0.255 comment="" disabled=no interface=bridge1 network=10.0.0.0
add address=63.245.x.24/26 broadcast=63.245.x.x comment="" disabled=no interface=ether1 network=63.245.x.0
add address=10.0.0.0/24 comment="" dns-server=4.2.2.1,205.214.x.x gateway=10.0.0.138 netmask=24
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 servers=4.2.2.1,205.214.x.x
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m \
udp-timeout=10s
/ip firewall mangle
add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=ether1 new-connection-mark=ether1_connection passthrough=yes
add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=pppoe1 new-connection-mark=pppoe1_connection passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=ether1_connection disabled=no new-routing-mark=to_ether1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=pppoe1_connection disabled=no new-routing-mark=to_pppoe1 passthrough=yes
add action=accept chain=prerouting comment="" disabled=no dst-address=63.245.x.24/26 src-address-list=Local_NAT_Networks
add action=accept chain=prerouting comment="" disabled=no dst-address=216.110.x.1/24 src-address-list=Local_NAT_Networks
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-type=!local hotspot=auth new-connection-mark=\
ether1_connection passthrough=yes per-connection-classifier=src-address:2/0 src-address-list=Local_NAT_Networks
pppoe1_connection passthrough=yes per-connection-classifier=src-address:2/1 src-address-list=Local_NAT_Networks
add action=mark-routing chain=prerouting comment="" connection-mark=ether1_connection disabled=no new-routing-mark=to_ether1 passthrough=yes \
add action=mark-routing chain=prerouting comment="" connection-mark=pppoe1_connection disabled=no new-routing-mark=to_pppoe1 passthrough=yes \
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5900 in-interface=ether1 protocol=tcp to-addresses=10.0.0.245 to-ports=5900
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5900 in-interface=pppoe1 protocol=tcp to-addresses=10.0.0.245 to-ports=5900
add action=masquerade chain=srcnat comment="Masq for GW1" disabled=no out-interface=ether1
add action=masquerade chain=srcnat comment="Masq for GW2" disabled=no out-interface=pppoe1
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set bridge1 discover=yes
set pppoe1 discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 \
max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=63.245.x.1 routing-mark=to_ether1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=205.214.x.1 routing-mark=to_pppoe1 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=5 dst-address=0.0.0.0/0 gateway=63.245.x.1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=10 dst-address=0.0.0.0/0 gateway=205.214.x.1 scope=30 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
Feklar
Mon Mar 21, 2011 3:36 pm
I'd try and isolate where the potential problem lies. Disable one of the links and see if the problem continues, if it doesn't swap over to the other link and see if the problem is still there or not. Dissable load balancing while you do these tests. If it works on both links, that tells you your load balancing setup may be incorrect, if it continues to happen on one link but not the other, that tells you where to look. If the problem is on both links, try plugging your computer directly into those links and try it out yourself to determine if it's a possible router configuration.
Also since you are using PPPoE I'm assuming you have a DSL line, be sure no other device is acting as a PPPoE client on the same line. Make sure your modem is in transparent bridge mode as well.
Users browsing this forum: alidamji, Droemel, mrshaba, OlofL and 150 guests
